portable showers
Submitted: Wednesday, Jan 23, 2008 at 10:06
ThreadID: 53821 Views:3872 Replies:18 FollowUps:13
What are the best portable hot shower units around? Not necessarily the most expensive! Have a Subaru Outback and a Jayco Dove.
Tasman
Reply By: Member - bushfix - Wednesday, Jan 23, 2008 at 10:11
err.... billy and sponge or 5L garden sprayer for me.
otherwise, twine, glind, helton etc. seem popular.
AnswerID: 283269
Follow Up By: Shaker - Wednesday, Jan 23, 2008 at 11:02
Twnie, Glind, Helton ..... Portable??
FollowupID: 547888
Follow Up By: Member - Brian (WA) - Wednesday, Jan 23, 2008 at 11:05
I back the garden sprayer up.In line tap,rose and tree, Pump up pressure away ya go
FollowupID: 547890
Reply By: RosscoH - Wednesday, Jan 23, 2008 at 10:43
Coleman portable hot water unit with shower attachment
AnswerID: 283275
Follow Up By: Wizard1 - Wednesday, Jan 23, 2008 at 11:05
At over $300 the aren't what I'd call cheap.
FollowupID: 547891
Reply By: Vince NSW - Wednesday, Jan 23, 2008 at 10:44
I use a $20 12V unit from K Mart. Heat the water via the Colman, drop in the little pump, plug into 12 V outlet & nice hot shower. We find that a 9 Lt bucket is more than enought for 2 showers, with a bit left over. Light weight, get a new one if it buggers up, you don't have to shower at the bull Bar.
Vince
AnswerID: 283276
Follow Up By: Wizard1 - Wednesday, Jan 23, 2008 at 11:04
What do you mean by "the Colman"?
FollowupID: 547889
Follow Up By: Vince NSW - Wednesday, Jan 23, 2008 at 11:06
Coleman water heater. I know that you can get the shower attachment for the Colman, buit the one that a mate had, was lacking in head height.
FollowupID: 547892
Follow Up By: Wizard1 - Wednesday, Jan 23, 2008 at 12:48
How bizarre...
You buy a Coleman HWOD then spend another $20 on a 12V shower pump unit.
You heat get the water from the Coleman, which is designed to act as a shower, then put the water in a bucket and use another 12V pump type shower. Is that right?
Why not get a longer hose for the shower attachment?
I thought my setup was cumbersome and time consuming.
FollowupID: 547913
Follow Up By: Vince NSW - Wednesday, Jan 23, 2008 at 13:58
Not Bizarre at all. If I had used My Coleman the way you want, I would have had to have about 10 feet of hose. My way, I used the toilet tent (about 3 mt away from the CT) as a shower tent. I would have had to move the Coleman with it's water container out next to the shower tent. Much less with to take the bucket out as I have an extra long power lead for the little shower pump.
To do it your way , you would have to lug the Coleman and a bucket.
Each to their own, but not Bizarre. If we all did things the same way there would be NO progress.
Vince
FollowupID: 547930
Follow Up By: Wizard1 - Wednesday, Jan 23, 2008 at 14:09
Which only goes to show how cumbersome and limited these units can be. Its either shower or hot water for washing up not both. Unless you think outside the sqaure.
Sorry but it isn't being used how "I want". It's the way the are designed to operate with the shower attachment.
It was hard to uderstand why you did what you did. Now it makes sense. Still bizarre though.
FollowupID: 547933
Reply By: flappa - Wednesday, Jan 23, 2008 at 10:53
Depends on your use and requirements.
IMO , the best units are the onboard vehicle units, glind, twine etc but requires vehicle mods (although fairly minor) to work.
If you want a stand alone unit , the Coleman Gas units get good reviews
AnswerID: 283278
Reply By: Member - Captain (WA) - Wednesday, Jan 23, 2008 at 10:57
Hi Tasman,
I had a Primus hot water system but found it to much hassle and took up too much space for what it does. Now I simply use a 20L plastic jerry can and 12V powered shower pump (~$30). We heat ~4L of water to boiling on the camper stove and tip it in the jerry to get 20L of warm water - have found 20L will do fine for a family of 4.
IMHO, this method is far less hassle, cheaper, takes up less space and is more reliable than a shower unit.
Captain
AnswerID: 283279
Follow Up By: Leroy - Wednesday, Jan 23, 2008 at 14:32
K.I.S.S. - that's how we camp.
Leroy
FollowupID: 547939
Reply By: Wizard1 - Wednesday, Jan 23, 2008 at 11:00
After a long stinking hot day on the road the good old canvas bag type is just the thing.
Simple ones like a solar shower bag can be just as effective and cleansing.
We used a 12V pump shower from Dick Smith's for years. Just drop the pump into a bucket of warm water.
We moved onto a Coleman Hot Water on Demand, although good, it can be a little more cumbersome and time consuming to setup. You still have to drop a pump into a bucket of water.
AnswerID: 283282
Reply By: Shaker - Wednesday, Jan 23, 2008 at 11:01
COLEMAN!
I had a Primus unit, as above it was way too much hassle.
AnswerID: 283283
Reply By: Joe - Wednesday, Jan 23, 2008 at 11:56
Instead of plugging into the cigarette lighter, the alternative unit runs on a couple of "D" type batteries,less wiring to deal with and the proximity of the car no longer an issue.
Simply drop the pump into a bucket with pre heated water to right temp.
Price less than $30 from memeroy.plus shower tent.
Joe
AnswerID: 283293
Follow Up By: Nick R (VIC) - Wednesday, Jan 23, 2008 at 16:56
We have one of these too, they are good, we have a stainless 20 litre bucket we put on the fire first to warm the water which does the whole family easily with plenty left for dishes etc.
Nick
Carpe Cerevisi
FollowupID: 547967
Follow Up By: Member - Roachie (SA) - Wednesday, Jan 23, 2008 at 21:13
I'll bet the taxman doesn't know you're using tax-deductible stainless steel buckets from the farm for the purposes of enjoying yourself!!! I wish I could take some of the "stock" or P&E from _my_ work place (but I'd get locked away for a vewee, vewee long time!!! hahahaha)........... Do you use the same bucket to milk the ol' cow/s when ya get back home??? ;-))
FollowupID: 548023
Follow Up By: Nick R (VIC) - Wednesday, Jan 23, 2008 at 21:47
I have the use of the bucket on a novated lease!!!
My employer (me, errr or is it swmbo, she does the pays) picks up the running costs of the said bucket, it is also understood that I will be using the bucket for the collection of milk from time to time when the need arises.
City folk can rest assured that the milk collected in the said bucket is not used for human consumption, although it could be, we cook with it, make coffee and gravy with the water boiled in it!
so nah nah n nah nah!!! ;-)
Carpe Cerevisi
FollowupID: 548031
Reply By: TerraFirma - Wednesday, Jan 23, 2008 at 12:23
I use the $10 solar ones, take 3 away with me and have them filled and heating all the time. Mind you I only typically go camping where there is water and you can't beat a swim after a million Jimmies and a fly blown hangover..!
AnswerID: 283303
Reply By: madcow - Wednesday, Jan 23, 2008 at 12:23
have a look here
http://www.mcs.net.au/~grungle/tips.html
some i car shower setups that may give you an idea.
i have a Twine in mine and its bloody great mate
AnswerID: 283304
Reply By: Hairy (NT) - Wednesday, Jan 23, 2008 at 12:48
SHOWER ?????
When in Rome.......
AnswerID: 283308
Reply By: Member - joc45 (WA) - Wednesday, Jan 23, 2008 at 14:07
Hi Tasman,
Like many of the above, I use a $20 12v shower from Jaycar or camping stores. I also carry a solar shower, which I only use to heat the water if sunny, otherwise I boil the billy on the fire. Empty the hot water into a 10L bucket and add enough cold, drop the shower in and you're there. Wet down, soap up, wash off. While soaping, drop the shower head back in the bucket so water's not wasted.
Men can get about 3-4 showers out of a single bucketful, women, well, about one ;-) - esp if you want to keep them happy in the bush!
A useful addition is one of those pop-out screens for shower or dunny. Apart from the privacy thing (which I don't worry about - it's someone else's problem, not mine) it keeps the wind out when showering.
cheers, Gerry
AnswerID: 283325
Reply By: Willem - Wednesday, Jan 23, 2008 at 14:14
$15 12 volt shower from Jaycar
20lt plastic jerry
warm some water and use 5 litres for two showers
Shower hooks up on Hi Lift Jack which is mounted on trailer
When weather isn't agreeable for shower use a rag and soap and 1 litre of water for a Top and Tail
AnswerID: 283330
Reply By: Member - Oldbaz. NSW. - Wednesday, Jan 23, 2008 at 15:08
$35 12v Bilge pump..much better shower than the little units.
Plug into Battery Booster, no vehicle proximity issues. Heat the water if you must. The idea of the 5Litre pressure garden spray
would seem to be good one..will check that out...no pump or power required.. got to be good...oldbaz.
AnswerID: 283344
Follow Up By: Member - bushfix - Wednesday, Jan 23, 2008 at 15:22
G'day Oldbaz,
importantly, it has more than one purpose.mine sprayer sits on the drawbar as it is also my fire extinguisher if necessary.
FollowupID: 547948
Reply By: Sand Man (SA) - Wednesday, Jan 23, 2008 at 17:23
Ours is also a Coleman brand unit, but a portable battery operated one. Cost about $30. Uses 4 "D" size batteries which last ages.
I usually take a 45 litre tub with us and as well as storing things in, it is very practical for showering in.
Boil some water up on the fire, pour into the tub and add cold water until you have a sufficient amount of warm/hot water at the required temperature.
Drop the immersible pump in the tub, stand in it and proceed to shower. The water recirculates and serves the two of us without the need to add more water. The ground remains relatively dry and a perforated foam mat keeps the dirt off the tootsies while drying off.
This is all done in the shower/toilet tent if "modesty" is required.
If the shower packs it in, $30 is not a big investment to make for a replacement, but we have had the same unit for 6 years or so.
Bill
AnswerID: 283363
Reply By: Steve63 - Wednesday, Jan 23, 2008 at 17:32
We just boil the billy and add to a 10l collapable bucket that hangs from the tray. Have a portable shower pump that suction cups to the side of the camper. All sweet, pump was ~$30 from a camping show and it takes up almost no room. Not sure of the brand. Of course the occasional passerby may get an eyeful. But thats life.
The heaters tend to be pretty expensive and they are relatively heavy and bulky. We tend to be on the minimalist side to keep weight down. If I had to set up a speciel tent, heater etc it would probably never happen. We have a 10 minute rule. If the camp is not set up in 10 minutes I don't want it. I'm out there to enjoy myself not spend hours setting upcamp. But to each there own and if you want something more elaberate there is plenty to choose from.
Steve
AnswerID: 283367
Reply By: Member - Phil G (SA) - Wednesday, Jan 23, 2008 at 18:31
KISS
Buy a 10 litre Stainless steel crockpot from Cheap as Chips ($10) and a $20 12v shower. The crockpot in warm enough for a shower after 5 minutes on the fire, and the temperature is constant - not like all the fancy under-the-bonnet gizmos.
If the 12v shower siezes up, buy another one.
AnswerID: 283378
Reply By: Crackles - Wednesday, Jan 23, 2008 at 21:48
As Subaru's are very tight under the bonnat you can pretty much discount the Twine/Glind type heat exchange units as they'd be difficult to install.
The portable Primus & Coleman instantainious gas units are a bit bulky, expensive & can at times be temperamental to adjust. They can however be good for a large number of showers when working.(big family/group). If moneys no object an instant gas unit plumbed into the van would give hot water to the sink & and an outlet for the shower could be taken out the side.
The simple options are often seen as the best with the $20 elcheapo pumps drawing water out of a bucket heated on the gas or fire. After trying many of the above my preference is the canvas bucket shower pulled up over a tree branch. With one moving part there's not much to go wrong. I've fiddled with pumps, wires & hoses far too often.
Cheers Craig...........
AnswerID: 283426
