Intermittent oil leak 2002 Jackaroo
Submitted: Monday, Feb 18, 2008 at 21:55
Ali L
We have isolated the source of an oil leak that occurs during highway rather than city driving. It's in the high /low range selector. Because the oil leaks onto the front drive shaft there is oil everywhere from that point The actual oil level in the transfer case has not dropped markedly but it looks bad
We are also having difficulty finding a service manual.
Is there anyone out there with info or suggestions?.
Reply By: Member - Noldi (WA) - Monday, Feb 18, 2008 at 22:33
Hi Ali,
I am a member of the Holden 4wd club, have not heard of this problem from other members. Have you tried the specialist Jackaroo forums?
http://
forum.australia4wd.com/lofiversion/index.php?f10.html
and
http://www.planetisuzoo.com/
Good luck
288235
Reply By: Sand Man (SA) - Tuesday, Feb 19, 2008 at 08:48
Ali,
If you can supply an email address I can send you a .pdf file of a "Trooper" workshop manual which is to all intents the same.
This document contains both Right Hand and Left Hand models.
288262
Follow Up By: Ali L - Tuesday, Feb 19, 2008 at 11:21
Sand Man
That would be great. It's alcons@ozemail.com.au
Ali L
553568
Follow Up By: Sand Man (SA) - Tuesday, Feb 19, 2008 at 16:20
Bugger!!!
Tried to upload the pdf file but it's too big and just returns an error.
The file size is 121,285 KB.
I will try and find the source site I downloaded it from.
Sorry Ali, I thought it would be easy"-((
553606
Follow Up By: Ali L - Tuesday, Feb 19, 2008 at 17:55
Sandman
The source would be great or failing that is it possible to select and send the relevant pages only?
ali
553631
Reply By: Ole Grizzly - Tuesday, Feb 19, 2008 at 09:34
I'd be looking at all breathers G/Box Transfer Case..almost sounds like a pressure build up.
288271
