Friday, Feb 29, 2008 at 20:40
Yeah I was talking in dollar terms peter.
I worked out with the assistance of a web site the following formula:
Diesel - distance - 120lt of diesel - $180.
Gas - distance 330km - 80lt of gas - $60
Based on these approximate figures, the gas returned 0.18 cents per km and the diesel returned 0.18.8 cents per km. The gas was 24lt/100 and the diesel was 12lt/100.
Now, I have yet to tow anything over 1.5 tonnes behind the cruiser yet, so I have no idea of what the figures will be then for the gas. I assume there will be little change as surely the cruiser
fuel consumption can't be much worse under tow.
Now based on the above figures, and I have been kind to the diesel at 12lt/100, I have heard the diesels under tow use around 15 - 16lt/100. If that is true and the I am about right for the gas figures, I am better off staying with the gas for reasons like less service intervals.
Thanks Rodeo - jayco for your reply, you are right there are more gas
servo's than people realise. I heard there is even gas in the centre. I have still yet to look further into ways to extract some more economy from the petrol like exhaust and a foam filter.
The injectors have been cleaned and the motor is serviced every 10 thousand.
I probably will not part with the petrol as I am a sucker for power and the 4.5 has plenty of that on tap, especially helpful when towing Nissan's out of the glue.
Thanks again gentlemen.
Brendan
555410
