Friday, Mar 28, 2008 at 18:26
we went down the GRR last September. We stopped to check out a bloke who shredded a tyre going over a dry
river crossing and spoke to another couple who who had a flat and wanted to know where the closest repair service was and then whether it was worth going back the twenty Ks to have it fixed.
We stayed at one of the stations overnight where the lady said that the road was being graded. She said that grading left rocks pointy side up and care should be taken. When we were in
Derby I discovered damage to one tyre that almost penetrated to the inside and I changed the tyre and kept the damaged case for spare. I chucked it when we got back to
Perth.
Conditions on the road change with weather and use. They usually start grading shortly after the wet to facilitate the cattle trucks getting in to the stations. I recommend you call the local cops or a caravan
park to find out just what the conditions are when you are close to the time of travelling the road.
Many vehicles will go down the road without a problem and you might be the unlucky one so be prepared to suffer at least two flats including irreparable casings. I think thats a reasonable precaution and I always carry the means to get through two bad flats.
Plenty of caravans have been down the road no problems but the road can be tough on the undercarriage sometimes. I dont think caravans are advisable if no other reason than the stuff we carry in them is likely to end up all over the floor. The bloke with the first flat we saw confirmed this. He was very cross with the way we look after our roads in WA!
The worst road we ever went along was the one up the cape in Qld. No sharp rocks but the corrugations were a real test of the vehicle, the camper trailer and the driver. Me.
Yeah tyres are expensive but if want that good feeling that "bin there done that" gives, and you are a risk taker (prepared), then its all in a good adventure and lived to tell the tales.
Lastly, drive carefully and keep the speed down. No point in stretching one's luck too far.
But this is what bush travelling is about, isn't it? You may the bloke giving the advice on this
forum in times to come.
good luck and happy travels.
Owen
561244
