Slowing down really does save you money. I tried it.
Submitted: Thursday, Jun 19, 2008 at 20:24
wigger
Have resisted the idea of slowing down for quite a while but now that diesel is ranging between 171.9 and 178.9 on the
Gold Coast, and I'm do 2000kms per week, the idea of cutting costs has resurfaced. Have been doing only 90kph fr M.bah to
Southport on the M1, hacking (stop/ start stuff) around G.C for another third of total mileage and then running up to Yatala and return at 90.
Lot of
vehicleson the freeway seemed to have slowed down and 90 is what a lot of people seem to be doing now.
Ford
Ranger 2.5 diesel and it did 16.86 kms per litre on the last fill. that's 5.93 litres per 100kms. Isn't this Prius territory ?
Trouble is I'm bored out of my brain driving at this speed.
Reply By: Michael ( Moss Vale NSW) - Thursday, Jun 19, 2008 at 20:42
I have tried the same between
Sydney and Moss Vale on the Hume Horrorway!! It's actually quite liberating with almost everything passing you,all the speed limit drivers and the odd fool doing 140kph. Without the need to navigate the slow drivers in the fast lane and keeping up with the normal maximum speed drivers tha seem to do 9 k's over the limit. It definately saves you
fuel and relieves the stress but it is boooorrring!! Michael
311035
Reply By: rumpig - Thursday, Jun 19, 2008 at 20:42
when we went up to
cape york, for a day i tried driving at 100 klm / hr instead of my usual 105 - 110 klm /hr, got an extra 100 klms out of the
fuel tanks that day.
311036
Follow Up By: wigger - Thursday, Jun 19, 2008 at 21:16
Yeh, but was it booooring.
Apparently the wind resistance increases as the square of the speed so 120 kph produces 4 times that of driving at 60 and the power required is 8 times.
Does anyone know if their is a linear realationship (rough) between
fuel consumed and reduction in speed i. e if you reduce your speed by 10% fr. 100 to 90, is there a reduction in consumption of 10%. If there was I could formulate a mantra to embrace the idea and keep reciting it as I drove along (booringly)
577045
Follow Up By: Eric Experience - Thursday, Jun 19, 2008 at 21:32
Wigger
Newton told us that E=MVsquared
E= Energy. M= Mass. V= Velocity. Eric.
577051
Follow Up By: wigger - Thursday, Jun 19, 2008 at 21:45
Eric,
and............ (for dummies)
577055
Follow Up By: Eric Experience - Thursday, Jun 19, 2008 at 22:10
Wigger.
Energy=
fuel. Mass is the weight of the vehicle. Velocity is the speed you drive at. Eric.
577060
Follow Up By: wigger - Thursday, Jun 19, 2008 at 22:16
Prof Eric,
can't picture what the graph looks like. Is it linear or exponential curve. You need to talk us dummies through it
577063
Follow Up By: EscapeArtists - Thursday, Jun 19, 2008 at 23:28
Ford
Ranger 2.5 diesel, Isint that what the Wiggles Use to get around
Melbourne?
577092
Follow Up By: wigger - Friday, Jun 20, 2008 at 20:13
Dunno,
but there's four of them and they couldn't all get in the front and I don't think you're allowed to stick them in the back.
Ranger 2.5's are for sad bast###s.
577299
Follow Up By: Eric Experience - Friday, Jun 20, 2008 at 21:33
Wigger.
Sorry I did not make clear.
E= MxV squared.
The energy used is linear with mass, that is double the load and you double the
fuel, but the velocity or speed is a square law, that is double the speed and you use 4 times the
fuel, and halve the speed and use 1/4
fuel.
This is not absolutely true in a car because the efficiency of the transmission can vary with speed, if you had lots of gears like a road
ranger it would be true,
The rule is very close though and will hold if the motor is doing the same revs.
Transmission efficiency is, that is converting
fuel into forward motion varies hugely between vehicles, German vehicles in general are about double the efficiency of others. Eric
577327
Follow Up By: wigger - Friday, Jun 20, 2008 at 22:18
Prof E E,
Thanks, that's a good explanation and it seems that you are saying that the line(or curve)is roughly linear or straight line.
With this bit of info it seems I can make meaningful decisions
about choosing a speed.
Don't get the last bit though. I thought petrol engines had an efficiency factor of about 15% as a general guide so how can you say that "german" engines have double this. The
ranger has a european MRZ diesel and probably achieves its low
fuel consumption through the use of variable geometry turbos and very high pressure injection , rather than being the byproduct of a tuetonic prestige engineering.
"the efficiency of the transmission can vary with speed" - are you saying that the ideal is for the cogs to be turning at low speeds.
577339
Follow Up By: Eric Experience - Friday, Jun 20, 2008 at 22:51
Wigger.
Efficiency is not just about engines, it includes rolling resistance and aerodynamics. The Europeans have always had expensive
fuel so they have evolved there vehicles in that environment. I sometimes drive a tow truck and use a winch to load vehicles, the load on the winch is a very good indicator of rolling resistance, some cars cause the winch to realy struggle whereas Volvo's or Mercs of the same weight are easy on the winch. Eric.
577348
Follow Up By: howie - Saturday, Jun 21, 2008 at 10:51
not sure about the mv squared bit.
the speed squared law applies to resistance to the movement of any object through air or
water.
the graph concerns aircraft obv, so you can ignore the 'lift induced drag'.
i suppose just the profile drag applies to vehicles.
this would explain the increased energy(
fuel) required to push a vehicle past its best drag speed to 30 kph more.
as for mantra's, i set the cruise control for 90 kph, grit my teeth and try not to touch the loud pedal.
meanwhile softly repeating the words of the great prophet," i know i can, i'm sure i can, i know i can, i'm sure i can"
577394
Follow Up By: wigger - Saturday, Jun 21, 2008 at 15:41
Tks Howie,
Was just about to go down to the tatoo
shop and get this diagram done on my forehead so that I could then swivel the rear view mirror and see it as I drove along . Then just in time I realised that it would be back the front and I would only be able to drive at about 30kph in order to focus on it and realy suss it out.
The mantra will be great though.
577425
Follow Up By: Member - Mike DID - Saturday, Jun 21, 2008 at 16:23
"Eric Experience posted:
Wigger
E= Energy. M= Mass. V= Velocity. "
This describes the energy that a moving body has. All this energy is recovered when you slow down. It tells you nothing about how much energy is needed to keep it moving against wind and frictional losses.
577435
Reply By: madfisher - Thursday, Jun 19, 2008 at 21:35
Biggest problem I have is concentrating on the road at 80 to 90 as I find my mind wanders off. If I am pushing it a bit I have 100 %concentation . I have already slowed down towing my boat to 90.
Cheers Pete
311054
Follow Up By: wigger - Thursday, Jun 19, 2008 at 21:49
Ah, yes . The old inverse relationship between speed and concentration. I think I'm at my best in terms of concentration
when I'm doing a white knuckled 160 down the freeway.
577057
Follow Up By: Shaker - Thursday, Jun 19, 2008 at 22:32
So, on the premise of your theory, the faster we drive, the safer we will be ...what a load of cr@p!
577067
Follow Up By: wigger - Thursday, Jun 19, 2008 at 22:35
Absolutely,
grand prix drivers have proved it Crank up the speed each year but the crash rate goes down.
577069
Follow Up By: Shaker - Thursday, Jun 19, 2008 at 22:42
You put yourself in the same category as the most elite drivers on the planet ... give me a break!
Also, correct me if I'm wrong, but ever since they banned 'ground effects' the F1 cars have been restricted almost every year.
If they hadn't been slowed, there wouldn't be track on Earth that could handle them.
577071
Follow Up By: wigger - Thursday, Jun 19, 2008 at 22:54
Well seems I lost that one
score : S 1 W 0
577080
Follow Up By: Member - Serg (VIC) - Friday, Jun 20, 2008 at 09:55
Shaker posted:
“So, on the premise of your theory, the faster we drive, the safer we will be ...what a load of cr@p!”
You may be laughing, but up until certain degree going faster equals safer. For long trips like from
Melbourne to
Gold Coast (have done 5, all of them in one day) I personally do not get tired of driving, but rather my eyes and brain get tired from continuous concentration. Therefore if I travel faster, I will spend less time on the road, that translates to being less time nuisance to others and to less time of hard concentrating. As result it is SAFER in my strongest opinion. Certainly “top safe speed” vary greatly because road condition, whether, car condition and driver him(her)self. When we been in NT some years back with no speed limits it is appears like most comfortable speed to drive is about 150-160 km/hr. More then that does not seem that safe and concentration need to be increased dramatically. Proof of my theory is simple – lots of German autobans has no speed restriction and I do not recall any news about their high accident level. And NT (wile being speed limits free) never been on first pages in our news about incredibly high fatality. “Speed kills” slogan invented by stupid TAC, if it would be true there will be no alive pilots by now.
Serg
577139
Follow Up By: Shaker - Friday, Jun 20, 2008 at 13:57
Serg, correct me if I am wrong, but isn't here a huge difference in the road quality between an Autobahn & an Australian country 'highway' ?
Also the NT isn't exactly over populated!
You also showed a distinct shortage of
grey matter in comparing the speed of planes with road vehicles.
What worries me the most though, is that you may have a driver's license!
577189
Follow Up By: Member - Serg (VIC) - Friday, Jun 20, 2008 at 14:23
Shaker,
I do have driver license and *LOVE* fast driving. Furthermore - I have it for more then 25 years and never managed put vehicle out of control in whole my life. In fact I never even been involve in an accident. Your points are valid about NT
population and about quality of German autobans versus out rural road. But tell me – do you believe that 110 is adequate speed limit on excellent stretches of Hume highway? I do not think so. BTW from curiosity I managed 210 km/hr when been in NT (actually was trying to make more then speedo shows (220), but it started getting too unstable to push envelop any future and I give up), and I would not consider such speed as “safe”. But I cannot understand what so wrong about having 150 on road as Hume highway (divided by natural strip, two lines each way, excellent surface, ample shoulders).
“You also showed a distinct shortage of
grey matter in comparing the speed of planes with road vehicles.”
Please, no personal attacks – I have not provoked you, have I? :-)))))). You just miss whole point – speed does not kill, but speed treated improperly kills. I give you another examples – you can be electrocuted if treat electricity improperly. Therefore we should not use any voltage above 36V. You can fall from tall building and kill yourself – therefore we need to construct only single-story buildings. You can fall into pool and drowned – so we have to restrict pool to 0.5m. I recon you can continue list by yourself.
Serg
577196
Follow Up By: madfisher - Friday, Jun 20, 2008 at 22:05
Shaker you demean your self by attacking others. Serge did not attack you but you insult him. I have found Serge to have a lot o0f
grey matter actually.
Pete
577335
Follow Up By: Shaker - Friday, Jun 20, 2008 at 23:16
Well he let himself down with this statement .....
" “Speed kills” slogan invented by stupid TAC, if it would be true there will be no alive pilots by now."
Having lost a stepson due to a speeding driver it is subject that I am quite passionate about.
577350
Follow Up By: Member - Serg (VIC) - Monday, Jun 23, 2008 at 10:12
Shaker,
I am deeply sorry to hear about you loss and please make no mistake about my believing – each and every death on the road is unnecessarily and avoidable tragedy. However I am still in believing that above-mention slogan is wrong. Actually depends of their target – from perspective of reducing of road toll it is way too misleading while from perspective to collect more money it is spot on. It is amazed me how much emphasize they give for speeding, when at the same time I have not seen/hear from them *AT ALL* anything (I stress it again *ANYTHING*) about critical importance of good properly inflated tyres, brake and shocker absorbers condition. Lets leave alone skills and awareness discussion above! Surely poor maintained car with dodgy brakes and bald rubber in wet condition cannot handle speed as high as properly maintained one with good rubber in perfect condition, but in my strong opinion it would be wrong to restrict speed basing on poor driver who drives dodgy cars with bald tyres at the beginning of the rain on road surrounded with eucalyptuses.
Best Regards
Serg.
PS. There is another discussion – why using mobiles behind wheel so deadly wrong while eating, drinking, smoking and fiddling with MP3 player is perfectly fine? IMHO it makes no sense at all and I believe that all this activities should be banned.
577718
Reply By: Stu-k - Thursday, Jun 19, 2008 at 21:36
For the boredom most people chat or send text messages on there phone. Eating and shaving are also good options
311055
Follow Up By: Michael ( Moss Vale NSW) - Friday, Jun 20, 2008 at 08:10
LOL!!
577114
Reply By: Crackles - Thursday, Jun 19, 2008 at 21:45
Have noticed quite a few driving between 80 & 90kph locally. No doubt great for fuel consumption but on the winding single lane roads where it's difficult to pass they often get a fair queue behind them. To avoid aggro & dangerous passing maneuvers it wouldn't hurt if they moved over now & then.
Cheers Craig................
311063
Follow Up By: madfisher - Friday, Jun 20, 2008 at 12:55
Agree
Pete
577178
Reply By: JimDi - Thursday, Jun 19, 2008 at 22:49
Well.......I have been driving slowly for years, old fool that I am.
My question to the forumites is....Does this mean I have to drive slower to maintain my reputaion or will I get a new reputation as a reckless speedster?
Jim
311087
Follow Up By: Michael ( Moss Vale NSW) - Friday, Jun 20, 2008 at 08:15
If you wear a hat, remove that, that will help. So now you will be seen as a tightwad, driving slower to save fuel. Like the rest of us!!. Michael
577119
Reply By: Member - Royce- Thursday, Jun 19, 2008 at 22:53
Diesel is just on 190cents here.... I've been driving slower and slower over the last weeks. I thought I was imagining things.... but now you lot have confirmed it... lots of others are too..
Hey... they're going to have to drop the speed limits cos the cameras won't catch anybody at this rate.
I have also been doing a bit of drafting behind big trucks as I travel up the Hume etc. saves a fair bit.... but for that you actually have to drive a lot faster! There's some more maths to consider.
311089
Follow Up By: wigger - Thursday, Jun 19, 2008 at 23:06
Looks like Eric's piked and gone to bed but I think we need to get him to explain a few more things.
diesel 190 !!!!!! and i thought 171 bad.
well it was actualyy 151 because Woolies liquor in NSW have special on where if you buy
6 wine you get 20c litre off. Good deal when you fill up with 150 litres.
577085
Follow Up By: Michael ( Moss Vale NSW) - Friday, Jun 20, 2008 at 08:12
Wigger!! The wine is so you forget about the high cost of the fuel!! Michael
577115
Follow Up By: Member - Oldplodder (QLD) - Friday, Jun 20, 2008 at 08:30
Friend on an economy run in the car club got 82mpg in a 1200 beetle going from
Brisbane to the North Coast, and was in the 1st five getting in.
He sat about a metre behind a
grey hound bus all the way.
For the run we swapped co-drivers. His was white and the knuckles were frozen, took all day for him to recover. Kept mumbling about buses for some reason. :o)
Don't know if I would recommend it.
577123
Follow Up By: Member - Matt M (ACT) - Tuesday, Jun 24, 2008 at 09:33
"Hey... they're going to have to drop the speed limits cos the cameras won't catch anybody at this rate."
That would be very funny Royce, if there wasn't a cold shred of credibility there. Maybe 'Low Speed Cameras' could be introduced to bump up the revenue stream?
Matt (Not a Conspiracy Theorist).
577926
Reply By: EscapeArtists - Friday, Jun 20, 2008 at 00:18
I filled up here in Kwinana Gull yesterday..
payed $1:78 Diesel, didnt bother topping up Sub.
its only going to get worse trendsetters :-(
311101
Reply By: Member - Oldplodder (QLD) - Friday, Jun 20, 2008 at 08:26
Slowed down a little while ago too. Fuel economy did improve.
To keep the drive interesting, and to save more fuel, don't slow down for the corners as much as you used to :o).
That way you save brakes going into the corner, and fuel accelerating out.
Doesn't impress the Coopers tyre people though when you go back with tyres that didn't reach the minimum milage and you want a pro-rata refund on the next set. :o))
311131
Reply By: MEMBER - Darian (SA) - Friday, Jun 20, 2008 at 08:51
See - it is true ! But I agree re the boredom - luckily, we seem to be doing 90kph when on holidays (its about all the driving we do now) so there are plenty of new things to see.... must be hell on the same road everyday....... re the physics lesson mentioned above (wind resistance) .......you should try 75-80kph (we did once) .... you'll end up apologising to the servo staff for not buying enough fuel :-o).
311138
Reply By: Member - Footloose - Friday, Jun 20, 2008 at 10:13
I am quite happy to toddle along at 80-90K on a trip. You may laugh at the old fool (with a HAT on I might add) as you zoom past at 130K dragging your camper behind, but it does have its benefits.
1) As you get older you don't need the white knuckle syndrome.
2) You become more self contained.
3)No kids in the back to annoy you into speeding
4) Less finances, so you actually NEED to save fuel. Plus the thought of getting a speeding ticket frightens you. You can't afford it and you've never had one before LOL
5) You know you'll pass the speedsters as they drop into a
seat at the servo, resting their eyes and getting their java kickstart.
311154
Reply By: Member -Signman - Friday, Jun 20, 2008 at 10:27
I've been driving off the EGT gauge for the last couple of weeks.
I do spend about 1/2 hr on the Hume morning & arvos.
Normal(conservative) driving is about 11.5l/100k.
Driving off the EGT went to 9.6l/100k !!!! An improvement of about 15% !!
When the EGT starts to load up- I changed DOWN a gear- OK this increased RPM but must decrease fuel load...
Worked for me....
311157
Follow Up By: Member - Vince B (NSW) - Friday, Jun 20, 2008 at 20:52
Hi Signman.
Recently had a EGT fitted. Will be heading west in July & I will try driving off the EGT.(once I get west of
Tenterfield!!).
Cheers.
Vince
577316
Reply By: Member - Oldbaz. NSW. - Friday, Jun 20, 2008 at 10:37
I have joined the slow pokes too, & have previously mentioned the
measured improvement in fuel use. Dont wish to
bore you but...
last week on a trip to
Sydney & return..I stayed on the speed limit
,110...Hume..on the way down & got 14k to the litre. Coming back I stayed between 90 & 100, & got 16 k per L. Uphill by 600
metres on return journey. I make that an improvement of 14%.
Vehicle...Peugeot 405 auto 2L. Last year ,over 13k outback trip,
reduced usage from 5.5 k to a L to 7.1 by dropping speed from
100 plus to sub 100. A reduction 0f 29%....V6 Jack towing C/t.
So it works for me, I have decided to make 90kph my speed max
from now on & expect even greater reductions. I hope I dont
impede your progress.......oldbaz.
311158
Reply By: Member - Big Al. Gold Coast - Friday, Jun 20, 2008 at 15:46
We saw a Tan coloured Hummer on the M1 a few weeks ago doing around 90km he must have got around 5L/100
When they loaded it on the tilt tray!!!!!!!!!!
311230
Reply By: Member -Dodger - Friday, Jun 20, 2008 at 15:58
Just remember you all.
It's not the speed that kills it's the sudden deceleration on impact that does.
311232
Reply By: Pezza (Bris) - Friday, Jun 20, 2008 at 23:43
Ohhh My God !!!
Are you people serious ??????
So going by the above analogies does this mean that by the end of the year when petrol hits around $2/lt that we're going to have a whole bunch of senile old farts driving around at 45 kph with a 5km queue of frustrated motorists behind you, all because you wanna save yourself a few bucks in fuel ???
If a few extra dollars in fuel used by travelling at the speed limit is such a problem or so unaffordable for you, then do all the rest of us who have a life a favour and sell your 4by and replace it with a bloody prius or some other rice bubble !!!!
Pezza
311328
Follow Up By: wigger - Saturday, Jun 21, 2008 at 15:54
Oooooh Pezza, you're such a nasty man.
I buy 200 litres a week so it's not "a few dollars" More like 50
Look, I only do my 90kph thing now when there's at least a two lane freeway and when it widens out to 4/5 lanes like the M1 Nerang to Brizzy, then you're in no one's road. I agree that on single lane stuff then it's inconsiderate to drive at less than the legal limit.
The worst things is that some of the slowies dawdle along less than 100 on a single lane road and then boot it when they get to an overtaking lane. That really gives me the chits and must really p... truck drivers off.
577428
Follow Up By: Flash - Sunday, Jun 22, 2008 at 12:25
Oh Pezza, such an angry response!!!
Yes, we are all slowing down, to save our wallets, the environment, the balance of trade, and many other benefits.
No one is talking 45 km/h. We are mostly talking 85- 95 instead of 100 - 110, and saving a lot of fuel in the process.
And my prediction is that when fuel hits $5 a litre sooner, rather than later, we will all slow even further.
If you don't like that, then tough. Get used to it.
They reduced the national speed limit in the US years ago to save fuel- that may well happen again, who knows!
Relax, and be happy!
577569
Follow Up By: madfisher - Tuesday, Jun 24, 2008 at 08:22
Prezza you actually use more fuel at 45.lol
Cheers Pete
577916
