Monday, Jun 23, 2008 at 12:49
pville,
having previously used the Liemack (50 Lt fridge/freezer) for a few years and presently the even more *technically advanced* Reefer PREMIER (70 Lt fridge/freezer) 12/240v fridge, I can say in all confidence the superior technical electronics advances and actual fridge *performance* in the Premier 12/240v fridge is even far ahead of the Liemack too !!
After all you buy a fridge either because it's with-in your (limited) "budget" ($999)
OR
because the fridge is required to do a specific job, even with it's high price ($2,250)
In my case it's to *quickly* freeze food and KEEP it frozen, while the food in the fridge compartment remains at a constant temperature.
Published tests were done way back in 1995 showing the Liemack was undoubtedly the fastest to freeze 12v fridge available in those early days.
However the more recently designed and far more technically advanced Reefer PREMIER would have to have been the *fastest* 12v freezer ever made !!
In the case of my 70Lt Reefer fridge/freezer, the fridge is set to maintain cabinet temperatures of +1° to +6° while the freezer cabinet stays at -18° simply because of it's independent all stainless steel cabinet construction and the much larger capacity Mitsubishi rotary compressor.
(now we can all have opinions, but the technical facts just can't be disputed, but I'm sure they 'will' be strongly challenged :-))
some actual pictures on my "members profile" do show my Premier fridge performance *numbers*
Yes, they use more current when running, but because they run for LESS time due to their much larger capacity compressor, they use just 2.8ah while maintaining the fridge compartment under 7° max, and they are also designed to RECHARGE the 12v battery system when running on 240v )
Mainey . . .
577741
