Help on split rims vs standard steel
Submitted: Monday, Jun 23, 2008 at 08:46
ThreadID: 59102 Views:4740 Replies:8 FollowUps:4
Hi there, I am currently looking at some new rims for the Patrol. I have the opportunity to acquire either splits or standard steel rims. Currently have the standard Nissan alloys which are fine for around town, but not what I want for outback touring.
I am looking for advice on which is the best way to go. Now without getting into the old tyre debate, I have always run BFG AT's until my last set of tyres where I put Maxxis 751's on. The Maxxis are ok around town, although feel a little spongy around corners, as well as being skatey on gravel. If I go with standard steel rims I will go back to BFG as I got 112,000 kms from my last set and over 100,000 from the set before that.
What are my options if I go splits as far as tyre choice is concerned? What is the best solution for extended touring, mainly dirt, some.
At the moment I am keeping a very open mind and will welcome any suggestions from those more experienced than me in this area.
Thanks and I look forward to all your replies.
Reply By: traveller2 - Monday, Jun 23, 2008 at 09:10
After running splits for 30 odd years I'd now go with one piece wheels and tubeless.
The ability to plug holes on the go is priceless.
Flats on splits tend to go down very quickly where flats on tubeless tend to leak slowly unless you've trashed the tyre.
On the other hand if you need to change tyres on the rims then he splits are easier if doing it on the side of the road.
Why not stick to alloys? The wheelnuts come loose on both wheel types on Patrols;-)))
AnswerID: 311740
Follow Up By: Member - RFLundgren (WA) - Monday, Jun 23, 2008 at 09:17
Traveller
I just dont think that alloys stand up to the pounding they can get when taken remote. As well as that the current tyres on the truck still have loads of life in them so I dont want to replace those. Have only done about 20K on them, but I just dont think that the Maxxis are going to be suitable for remote travel. As I said they just seem quite spongy and skatey so if I were to go to standard steel rims I will be putting BFG's back on as they have never given me any issues to speak of at all.
I agree that the ability to plug holes is definitely priceless and have done that many times in the past. Its just that I have the opportunity to choose between either rim at the moment so just gathering opinions before I take the plunge.
FollowupID: 577707
Oh and by the way in almost 4 years I have not had a wheelnut come loose on the Patrol, and thats ion over 180,000 kms of driving :)
FollowupID: 577709
Follow Up By: traveller2 - Monday, Jun 23, 2008 at 11:31
I wa sonly aware of the Nissan wheel nut problem when on last years trip with a Nissan checked them every morning and there was always at least one loose throughout the three week trip.
That was with standard steel rims, but mostly on rough conditions.
FollowupID: 577732
Reply By: Sand Man (SA) - Monday, Jun 23, 2008 at 09:11
Richard,
I believe both have their advantages.
Standard rims use tubeless tyres (usually) while split rims require tubes in them.
When you get a puncture in a tubeless tyre, you can usually repair it with a plug without taking the tyre off the rim.
When you get a puncture in a tubed tyre (split rim) you have to remove the tube and patch, or replace it. This is a fairly simple exercise however, so it's no big deal.
I run tubeless alloys on the Jack, but the camper has split rims. I was going to replace the splits with standard rims until I check the cost of doing so. Kept the splits.
One other advantage of split rims is they are narrower (6") than the standard rims. (7")
This enables me to run Desert Duelers on the camper which were much cheaper ($168) than the 693/694 Duelers. ($225)
If I could run the DD's on the jack's rims safely, I would use them.
Bill.
Bill
AnswerID: 311741
Follow Up By: Sand Man (SA) - Monday, Jun 23, 2008 at 09:15
A negative of split rims is they are heavier and a mongrel to lift up onto a spare mounting point.
Bill.
Bill
FollowupID: 577706
Reply By: Robin Miller - Monday, Jun 23, 2008 at 10:40
I really wouldn't consider splits Richard.
They are just to heavy and limited in the availabilty of sizes and offset.
I stick with 16X7 Trak 2 rims on my GU with 10mm negative offset for all the sets of wheels I have including the trailer.
AnswerID: 311752
Reply By: Member - Footloose - Monday, Jun 23, 2008 at 11:05
Did you read Thread 59092 ? Compelling arguements for not using splits under most circumstances.
Use steel tubeless rims. They will withstand all that remote track travel can throw at them, and are easier to fix.
AnswerID: 311754
Reply By: Splits - Monday, Jun 23, 2008 at 14:51
Richard
Think about what type, not necessarily brand at this stage, of tyre you want to use.
The split rims on Cruisers and Patrols use a 7.50x16. They come in a wide range of tread patterns in both steel belted, all steel and bias ply construction. Most of the popular 4wd tyres only come in steel belted. All of the 7.50s have their place in the outback. The steel belted will cover all general travel. The all steel is very good at resisting punctures while carrying extreme loads on both the street and rough conditions and a heavy bias ply is the only one to use in cross country work where there are no tracks. If any of them look ideal for where you intend going and the loads you will be carrying then you may need split rims because some of those tyres are too heavy to get on and off a single piece rim. That is why manufacturers continue to fit split rims to new cars.
If on the other hand you prefer a larger size in steel belted construction then you will almost certainly need a wider rim and it will most likely have to be a single piece.
The tyre is the thing that has to do the job so think tyre first then find a rim to suit.
Brian
AnswerID: 311780
Reply By: RobAck - Monday, Jun 23, 2008 at 16:27
Richard some good comment here and I can add a few other things for you to consider.
Firstly from a safety point a spilt rim is an extremely dangerous thing to try and re-inflate a tyre on.
Secondly split rims are not technically designed for tubless tyres so be very careful on this point. Tubeless tyres have a specifically designed bead that holds it to a tubeless rim. This bead does not properly match a split rim design.
From a tyre perspective like most comments it really depends on what you are going to be doing. We recently sent two clients to the Kimberley for three months one vehicle had Bridgestone D 694's and the other had Bridgestone D661's. Both followed the proper discipline of adjusting tyre pressure and speed to the terrain and what do you know. Not a puncture in either vehicle in over 10000kms of travel.
We have also seen some excellent results from Toyo's as well
RobA
AnswerID: 311790
Reply By: Member - Davoe (Yalgoo) - Monday, Jun 23, 2008 at 18:13
having used both and got into arguments over their merits and draw backs Im pretty firm on my belliefs over this debate
- Split rims should be used in conjunction with crossply rag tyres for a no comparamize mostly bush work
-1 peice rims should be used for radial tyres where their on road advantages are neccessery
in short for the uses you describe the 1 peice rims are the way to go
AnswerID: 311824
Reply By: Member - RFLundgren (WA) - Monday, Jun 23, 2008 at 21:35
Thanks to everyone for your knowledgeable replies. Its an area that I had not ventured into before, and have now gained quite a bit of information in regards to it. Looks like the consensus is to stay with non splits. That's all I was looking for on this thread, was opinions on both pathways.
I am still looking at some steel rims for the Patrol to replace the alloys when going bush. Currently know where there is a set of 6, but on 16x6 which will limit my choice of tyre, so still on the search for some 16x7 which seem to be as rare as.........
Thanks again to all for your input :)
AnswerID: 311904
