Hilux & LPG
Submitted: Thursday, Jun 26, 2008 at 21:41
garbage
I searched the forums, but couldn't find much on this topic.
Has anyone had LPG installed on a Hilux dual cab 4WD or similar? Where size
tank did you get and where did it go? How has performance and economy been petrol vs LPG? Any engine longevity issues with LPG?
Reply By: Stephen M (NSW) - Friday, Jun 27, 2008 at 19:03
Not sure what model you have but if its the latest with the 4 litre motor you can only run the injected system which is around 5g,s. You cant run the Vapour system as the 4 litre has a plastic intake manifold and not compatible with the LPG due to the heat. I am having myn done by a mob called Gas N Go at Prestons here in
Sydney (not sure where you are) If you give them a call 96089889 and ask for Greg he will take the time to explain it all to you. Regards Steve M
312612
