solar/ generator
Submitted: Sunday, Jul 13, 2008 at 20:48
ThreadID: 59742 Views:6020 Replies:8 FollowUps:10
after some comments from my fellow knowledgeable forum people, it looks like my daily amp draw is about 25-30 amps per day. (24hrs)
for charging the batteries out bush, would i be better using a 1000 watt Yamaha generator, (real quite) a 3500 watt generator (scorpion) or a solar panel?
if a solar panel which size?
I have a 25 watt 3 way charger that is mounted in the van, i use to keep batteries topped up when not using the van.
cheers Shane.
Reply By: Affordable Batteries & Radiators - Sunday, Jul 13, 2008 at 21:16
You would get away with a 80W panel but if you already have the generator and are allowed to use it where you go then do that.
Derek.
AnswerID: 315169
Follow Up By: Member - shane (SA) - Sunday, Jul 13, 2008 at 21:27
thanks for reply Derek, would this be plenty or just? not sure which way your meaning "would get away with"
does an 80W panel put out 80W per hour or is this just a figure for the ideal world.
i already have the generator, i also have never seen a sign saying no generators, could you explain?
cheers shane.
FollowupID: 581304
Follow Up By: Affordable Batteries & Radiators - Sunday, Jul 13, 2008 at 21:50
Hi Shane
Most National Parks now don't allow generators and other campers may object in other places. On my last Birdsville trip I had to rely on the 100W Bi-Fold to power the 90L Engel caravan fridge as we could not use the generator in the Birdsville Caravan Park especially when the park filled up.
80W will give you approx 5 amps per hour in bright sunlight. This would return around 35 amps a day to your battery.
Derek.
FollowupID: 581317
Follow Up By: Affordable Batteries & Radiators - Sunday, Jul 13, 2008 at 21:54
Early morning at Birdsville Caravan Park. Campers are to close to each other to run generators.
FollowupID: 581319
Follow Up By: oldtrack123 - Sunday, Jul 13, 2008 at 21:58
Hi Shane
Generators are banned in nat parks.
80W solar gives about 4.5 amps in full sunlight for an average of about7hrs ie31 amp /hs on a GOOD day. You would need 2x 85 +solar regulator to be safe & I would still take the genny on case the sun went out .
FollowupID: 581320
Follow Up By: wigger - Sunday, Jul 13, 2008 at 23:02
If the sun goes out you will need more than a genny, more like a couple of fur coats and a hot water bag.
FollowupID: 581336
Follow Up By: Member Brian (Gold Coast) - Monday, Jul 14, 2008 at 07:10
Hi Shane,
I'll second what Derek says above. I bought one of the 100w Bi-Fold solar panel that Derek sells, and when we are stationary it keeps my batteries charged enough to run our 70L Trailblaza. As great a fridge as the Trailblaza is, it is hungry for amps, and the 100W panel is ample for this. Being Bi-Fold, it fits neatly in the truck.
We were camped at Neil Turner Weir, near Mitchell, Qld just last week and a couple of gennies were running. Even though they were switched off by 8pm, it was still irritating to be sitting by our fire, listening to a gennie off in the distance. IMO, unless someone needs a gennie to run medical machinery, they should be left at home. Just My Opinion remember...... LOL.....
FollowupID: 581348
Follow Up By: Member - Norm C (QLD) - Tuesday, Jul 15, 2008 at 15:02
Hi Brian, I see you made it to Big Red (and back). Hope you had a good trip.
While I agree on using solar in preference to the generator, I would not be leaving the gennie at home. Even up here in the NT, we have recently had a couple of cloudy days that got a few gennies running for a couple of hours - even by those with pretty good solar systems.
But I know what you mean.
I'll be looking to set up better with solar before we hit the road for next year's trip. But got to get home from this one first.
Norm C
FollowupID: 581549
Follow Up By: Member Brian (Gold Coast) - Tuesday, Jul 15, 2008 at 17:19
Hiya Norm!!!!
Good to see ya there matey!
An interesting thing is that the 100W Bi-Fold that we bought runs quite well in overcast conditions. The weekend that we bought it, I set the Trailblaza in the back of the truck, loaded it with room temp water bottles so the fridge had to work harder than normal, and let it sit there for three days on the panel. It kept up beautifully and there were many times when the sky was quite overcast.
When you get back, give me a yell and we'll bring the panel up to your place and show it off.
Hope all is well up there mate, see ya when you return.
Say Hi to Kathryn for us.
FollowupID: 581583
Reply By: Member - Netnut (VIC) - Sunday, Jul 13, 2008 at 21:41
Hello Shane,
I was at a camping and caravan show recently and I got talking with a camper trailer manufacturer on the same dilemna you are facing. He advised me to use a 25amp/hour multi-stage charger with my generator to top up my 105 Amp/hr AGM battery as it is capable of doing this within a couple of hours.
I was planning to purchase a fold-up 80 amp monocrystaline solar panel kit. However, the rep. explained that there are limitations with solar charging, especially the need to have sunlight to optimise charging, the need to camp out in the open and the need to secure the equipment from low life.
I already have a Honda Eu1000 watt generator - which like the Yamaha is very quiet - and with a commonsense approach to camping near others, I use it as necessary for lighting, charging laptop batteries, TV etc. Having recently purchased a 15 amp/hr C-Tek multi-stage charger, I can now charge up the camper trailer and fridge batteries, sun or no sun - while I light the camp, fiddle with my laptop and cheer on Essendon.
If you go the generator path, consider the 2000 watt option as there is not a lot of difference in price and weight between it and the 1000 watt model. With the higher capacity generator you can run power-hungry caravan appliances as well as use your lights, watch TV etc.
The cost of the 1000w generator is only about $300 more than an 80 amp/hr solar kit.
Security is well worth considering. The generator would top up your batteries far quicker than a solar panel which needs to be left out - and regularly repositioned - during the day. The generator could then be put away after it's done its job.
I hope my comments will help your decision.
Netnut
AnswerID: 315173
Follow Up By: Member - shane (SA) - Sunday, Jul 13, 2008 at 22:13
thanks again Derek and Nutnet, already have the generators. i don't have anything in the van we use that's not gas or twelve volts. our usage is very minimal, with the two batteries going from 12.7 to 11.3 over six days kind of through me. But did read that the car alt would not charge them up real well, but on the way home after five hours driving they went back to 13v then 12.6 with the 22w fluro on.
cheers shane.
FollowupID: 581326
Reply By: Sand Man (SA) - Monday, Jul 14, 2008 at 12:20
Shane,
One thing hasn't been covered.
A bi-fold solar panel takes up far less room than a generator and its fuel container.
Have just returned from the National Gathering at Innamincka.
I have an 80 watt bi-fold solar panel which kept the battery pack changed sufficiently enough for nearly a week, running a 40 litre Engel and two 1 amp lights.
Some days were somewhat overcast and I received shade from a nearby tree for part of the day. The lowest the battery pack got was 12.3 volts and charged up to 12.7 volts the next day while running the fridge at the same time.
I am convinced an 80 watt panel is enough for a 40 litre fridge.
Bigger fridges (or less efficient ones) may require a higher capacity panel.
And yes, there is the problem in securing equipment from "low life" but that is the same whether the equipment is solar panels, battery packs, fridges, generators, or anything else at your campsite.
I run a stainless steel stranded cable through the more expensive gear and padlock "the string" to the camper trailer chassis.
This wont stop a dedicated thief, but it will make it harder. They would need cable cutters or an angle grinder to shear through the cable.
Hey, I just thought of something else-
If you don't have a gennie, the mongrels can't run the angle grinder from it:-))
See ya!!!
Bill.
Bill
AnswerID: 315234
Reply By: Rod - Monday, Jul 14, 2008 at 15:59
My fridge _Affordable_Storage_Drawers.aspx about 29A in 24 hours and tried unsuccessfully for 2-3 years to keep it charged using 80W of solar. I believe 100-120W is a more realistic figure unless you spend all day chasing the sun and repositioning panels. Not how I want to spend my days.
I now have 145W of solar and have no problems but admit this is overkill for the load.
AnswerID: 315269
Reply By: lizard - Monday, Jul 14, 2008 at 17:47
Having gone the solar panel , and generator route myself , I am starting to think a Chescold is the way to go .... run on gas when staying put . No more chasing sun , or carrying petrol..... just a gas bottle - people usually have one or two or more of these ....(Icurrently have a 110 lt Waeco + Kipor + Solar on Van roof) as well as van fridges
AnswerID: 315285
Reply By: Member - shane (SA) - Monday, Jul 14, 2008 at 20:43
thanks guys, this running the generator all night or till late. if it only takes 2-3 hours to recharge the batteries then why would they run them for that long? The answer must be that they don't have batteries and or are using 240volt stuff. this type of user would get up my nose as well, but if one is only running the generator for a few hours every other day just to charge the batteries i cant see a problem. this ofcourse should be done in the late morning sometime i would say.
The use of the fridge i think comes down to how long one would stay in the one spot. after two trips with the evakool now i think it is ideal for one to two day then moving, but any more time in the one spot i think i will take my chest cold.
cheers shane.
AnswerID: 315318
Reply By: kcandco - Monday, Jul 14, 2008 at 21:34
Hi Everyone
With petrol fast approaching $2 a litre and expected to get much dearer, I can't understand why a generator based setup would be considered a good one, especially when they are not allowed in caravan parks and national parks and annoy most campers... not to mention the risk of electrocution if not properly earth staked and let's admit it, whoever does that!!!
Am I missing something??? I personally use a 12v bushman in the car with a dual battery system and if staying put more than 2 days use a chescold 3 way fridge freezer..... no noise, one dollar a day to use gas and reliable.
regards
Kc
AnswerID: 315325
Follow Up By: Member - shane (SA) - Monday, Jul 14, 2008 at 22:05
Hi Kc, you are right in what you say but it comes down to what suits you at the time. i think its a natural progression as you needs get more, when i go by myself or mates its the less is more type thing. when the wife goes and your normally away a bit longer, the extras come into it. ( a happy wife is a peaceful life). but looking at the expense of it, its use the generator i have or go and spend about $1400.00 on solar to use about 3-4 weeks a year.
cheers Shane.
FollowupID: 581485
Reply By: Outa Bounds - Tuesday, Jul 15, 2008 at 10:01
We went the generator way, back when we were looking at our power options. We decided on the honda 10i and a Durst battery charger. But I can say that it ended up mainly being there for an emergency (ie flat car batteries in the middle of nowhere). It's acurally been more useful at home, the battery charger to charge car batteries fully in general and the genny also as to run the frozen meat in the engel in power outages like the recent 24plus hour one we experienced. The honda 10i is good for what I described but not really enough juice to say run the kettle (hi wattage) or even a toaster, we'll be getting a 5kva when the house is built and probably not bother with once for camping as we're not likely to camp or travel as much any more. The fuel usage of the 10i isn't too bad, I think about 3L in 24hrs - but this is a guestimate from what it used during the recent power outage, and it was running the engel full ball and also a laptop computer (I didn't let hubby even think about plugging the tv in!).
Anyway I have always liked the idea of solar, but drawbacks others have described have put me off. I suppose you can't go too wrong if you have one of each. And if you find yourself staying at caravan parks regularly then it wouldn't be too much trouble to get a powered site so this would negate the need for a genny. So for us we went for a genny mainly because we could see potential use outside of camping.
Now my dream is to get a solar set up for the house, independent of the grid to provide for ALL our power needs.
Whilst I'm rambling on and still on the topic, anyone see on the TV that they are likely to have more efficient solar panels in about 3yrs? They are going to be glass painted with a dye, the dye concentrates the sunlight and it then goes to the solar cells on the side which convert it to electricity. They said these will be able to be added to work with existing solar panels, and supposedly cheaper to manufacture - and I guess cheaper to buy!
AnswerID: 315392
