Sensitive subject - toilet paper
Submitted: Friday, Aug 08, 2008 at 07:28
Bunny
We are curious as to whether ordinary
toilet paper is suitable for our onboard
toilet (Thetford). We are
well aware of the environmental issues/requirements when off road and the special paper available, however, given that we will not be venturing off road on our initial trip, will the
toilet system (with the appropriate addditives) cope with ordinary paper to be dispensed with at appropriate dump sites at caravan parks?
Reply By: Mad Cowz (VIC) - Friday, Aug 08, 2008 at 07:47
works for us, it goes to nothing once it has been in liquid for a while
MC
319692
Reply By: guzzi - Friday, Aug 08, 2008 at 07:59
The only trouble I have had with "normal"
toilet paper is the speed the waste
tank fills up. 1 wife + 2 kids+ the 3 ply she insists on = 2.5 days for the 21 ltr
tank.
The next trip is planned with a light weight paper.
319694
Follow Up By: Bunny - Friday, Aug 08, 2008 at 08:03
We will be only using our
toilet sparingly so can probably avoid this problem. Thanks....never thought about the "ply" bit.
586303
Follow Up By: Ozboc - Friday, Aug 08, 2008 at 08:25
lmao -- lighter paper usually ends in
messy fingers .... teach the scrunchers to become folders and you should use less :)
Boc
586310
Follow Up By: Bunny - Friday, Aug 08, 2008 at 08:34
This subject could certainly "open a can of worms" so to speak )(*&*&^$%^%@$
586314
Reply By: Member - Troll 81 (QLD) - Friday, Aug 08, 2008 at 08:49
We used normal paper once in our porta poti before we knew we had to use special paper and when it came time to clean her out there was lots of blockages because the paper didn't dissolve.
319707
Follow Up By: Bunny - Friday, Aug 08, 2008 at 09:17
Is there a bit difference between a porta poti and a Thetford? I'm not sure. Also, were you using the suggested chemicals. We have two lots, one for the cistern and one for the
water tank.
586325
Follow Up By: Member - Troll 81 (QLD) - Friday, Aug 08, 2008 at 09:20
not sure about the differences and yes we use the correct chemicals green stuff in the bottom pink in the top. Once we started using the special paper there was no problem and everything dissolved properly
586326
Reply By: Trev (SA) - Friday, Aug 08, 2008 at 09:21
Bunny
I would steer clear of Cottonelle as it has a chemical called Kymene in it which strengthens the paper 'stops your finger going through easily', the same as tissues. This brand is not good on septic systems.
The best way to check your paper is to half fill a jar with
water, add a few bits of paper and give it a good shake.
If it turns into a sludge it's ok, but if it's stringy I wouldn't use it.
trev.
319716
Reply By: Bat - Friday, Aug 08, 2008 at 09:31
A lots of people put the paper in a bag and get rid of it,that way the
toilet is easily to empty
319719
Reply By: Hairy (NT) - Friday, Aug 08, 2008 at 17:41
Gday,
Kim ( and damn dog) once suggested wet and dry sand paper....
Apparently no one uses too much of it, your finger wont go through it and you can rinse it under the tap and use it over and over.
Might be worth a try....
319813
Follow Up By: Member - barry F (NSW) - Friday, Aug 08, 2008 at 17:51
Sounds like the stuff you used to get at some Servos back in the 60's !!
586415
Follow Up By: Kim and Damn Dog - Friday, Aug 08, 2008 at 19:00
Hairy
Moved on from that. We now dry the dishes with the Hessian cloth, and after a bog, give the bum a scrub with it out in the bush.
Clean the cloth up next morning with a bit of left over Billy
water and things are fine.
Can't understand what the fuss is about.
LOL
PS Your a right bloody dill
Kim
586425
Reply By: Member - Bucky (VIC) - Saturday, Aug 09, 2008 at 03:58
Get a Jimmy's Thunderbox !
End of story, and carry a small bucket of lime with you as
After each deposit, sprinkle a desert spoon of lime on it..
Brilliant, and virtually no smell.
We also have a Porta-Pottie, and use Reece Chemical, in it. But as soon as it was setup, women and kids just fill the bloody thing, and then we end up using the "thunderbox" anyway, so now that's all I take !
If we feel we have to take the porta-pottie, then I just use normal paper..."Safe for septic tank" written on it !
Bucky
319882
