Tyre puncture repair kits
Submitted: Thursday, Aug 14, 2008 at 13:58
ThreadID: 60761 Views:10118 Replies:8 FollowUps:11
Given the variety of puncture kits ranging from plugs for stake holes to squirt in goo I would be interested to know of others' experiences with these puncture solutions and what they would recommend as essential carry items.
(Curious note: It used to be that earlier last century the English and Australian wrote `tire' for those things we put on cars etc and the Americans wrote `tyre'. And then it flipped and today we write `tyre' and the Americans write `tire.')
Reply By: Member - Howard (ACT) - Thursday, Aug 14, 2008 at 14:31
harryopal,
I carry a suercheap tubless repair kit (under $20 ) for plugging tryes.
I also carry a pair of tyre levers , a rubber mallet , a selection of patches and a tin of rubber glue.I use either a 6 ton hydrulic bottle jack or the high lift to break beads.
most important i carry a couple of spare tubes .
in the bush i prefer to fit a tube if a repair beyond plug is required . this is because it can be awkward to reseat tubless tryes when useing small compressor.
works for me
Howard
Resigned to Retirement
AnswerID: 320675
Follow Up By: Robin Miller - Thursday, Aug 14, 2008 at 14:53
Much like Howard here , but I find tyre pliers to be very effetive in bead removal , and I use transfer hose to spare which rely helps
with re-seating.
The other thing I have found is that my low cost plug insertion tool just isn't up to it when I plug thru the tread.
This requires a lot of force and needs a very strong heavy duty unit, fortunately my last leak was repaired at home but it still took my electric drill some time to force a pluggable hole thru the twin steel belts.
FollowupID: 587458
Follow Up By: harryopal - Thursday, Aug 14, 2008 at 14:54
Thanks, Howard. Over some 45 and more years and rather a lot of off road travel I have been amazingly lucky and never had a blow out or off road puncture. Have only ever carried a spare and I guess that is pushing it.
FollowupID: 587459
Follow Up By: Member - Matt M (ACT) - Thursday, Aug 14, 2008 at 15:09
I will back up Robin's point about cheapy ones. I had the plastic handle break trying to insert a plug which resulted in a lot of swearing and sweating. Get one with a decent solid metal handle.
Matt.
FollowupID: 587460
Follow Up By: Member - Phil G (SA) - Thursday, Aug 14, 2008 at 19:32
Gday Robin,
you can get thinner plugs - I get the extra long black thin ones on the BushRanger stand at the 4wd shops. I try not to use the reamer too much - creates more damage.
FollowupID: 587479
Reply By: Smudger - Thursday, Aug 14, 2008 at 15:28
The best emergency repair kit I've used is the pressure cans of goop. The tyre bods hate 'em coz they fill the tyre/tube up with sticky muck. But they'll get you out of trouble. They'll even put a bit of pressure in the tyre, but best if you have a compressor in the kit.
Let's face it, changing a tyre is no fun, especially on the track. But just in case, I also carry a tyre plug kit (5 years old and still brand new) and 2 spares when we go off the beaten track.
AnswerID: 320678
Reply By: Tony MD - Thursday, Aug 14, 2008 at 16:24
Hi Harry.
This is slightly on the overkill side of things but...
I carry tyre pliers, 2 x 900mm & 1 x 600mm tubeless rim tyre levers & 1 x 600mm split rim tyre lever.
For inflation I use a Max Air compressor. The ARB compressor is primarily for the diff lockers but can be used as a spare. Also carry a transfer hose. I have had a compressor air hose blow out (too hot!)
One job for the future is to make up an adapter or similar so that any air hose will fit any compressor.
For repairs I have the super seal plug kit, 2 x spare tubes & a range of radial tyre repair patches, tube patches, glue, inner liner sealant, stitching tool, cordless drill & buffing wheel, wire brush... See Rema Tip Top for this stuff & they will take phone orders & provide delivery.
There are also spare valves and tubless tyre valve assemblies.
I carry two spares as well.
Most of this kit, not the spare wheels of course, fits between the back seat & the cargo barrier.
I don't like the goo option. Once had a can of it "go off" & the mess was horrendous!
Cheers, Tony - Back from the Great Victoria Desert.
AnswerID: 320682
Follow Up By: Member - Bucky (VIC) - Thursday, Aug 14, 2008 at 17:26
Good call Tony
Go the Tyre Plier Kit, everything you need is in the kit, but I do carry spare bits and pieces, and a good heavy rubber mallet...
I'm still fit enuf to use mine, and hope to continue to do the same for many years to come.
One thing I also carry is about 1kg of LUX flakes. I make up a slurry, and slop it on around the rim, making refitting as easy as, and it backs up for washing clothes too.
Can take tyre off rim in about 2 minutes flat, and replace it even quicker. Keeping in mind, that it's not always necessary to take tyre off rim, just roll the tyre, find the puncture, and plug it.
All too good.
Mate has the R & R Beadbreaker.. they are even better-er,
Bucky
FollowupID: 587467
Reply By: Splits - Thursday, Aug 14, 2008 at 18:10
Harryopal
I suppose it depends on where you are going. If you are an hour or so out of a major city then all you need is a spare wheel and the phone number of the NRMA. If you are in the remotest parts of the Outback then I don't think what Tony MD carries is going too far. You could easily use the lot in those conditions.
Have a look at the two links below. The first suggests that there is a lot more to it than meets the eye. A glance through the equipment available on the Rema site gives you an idea of what is available. There are plenty of plugs, patches etc listed there that I have never seen in a 4WD shop.
Give your nearest branch a ring or better still call in if you are close enough. Find out exactly what is needed for everything from a small nail hole to a worst case scenario then make sure you have it and know how to use it.
Brian
http://www.cityoffpeak.com/generalinterest.htm
http://www.rema-tiptop.com.au/portal/home-australia.html
AnswerID: 320697
Reply By: Sand Man (SA) - Thursday, Aug 14, 2008 at 18:46
Anything will do because once you have something you'll never need it:-))
OK, seriously, I have a set of tyre pliers, a Safety Seal plug kit, a spare tube, a good quality 12 volt compressor and two spare wheels/tyres as the spare from the trailer is interchangeable.
Having said that, I have only had one puncture, but as a rock sliced through the sidewall and the tyre crapped itself big time, no amount of repair work was going to fix the sucker.
All you can do is prepare yourself for the most common of situations.
Bill.
Bill
AnswerID: 320704
Reply By: RobAck - Thursday, Aug 14, 2008 at 20:26
Find your local Rema Tip Top supplier. They supply all tyre repair outlets in the country, well almost. German quality and been around for more years thany any of us. They supply all tyre puncture repair equipment and some darned good kits. We have been using their stuff exclusively for over ten years without hassle. Just remember to repalce the glues/adhesives every two years as they go off.
For tyre changing we carry both tyre pliers and the bead breaker kits. Both have their pros and cons and both definately require practice to get the best from
RobA
AnswerID: 320729
Follow Up By: harryopal - Friday, Aug 15, 2008 at 09:07
Thanks for all the information and suggestions. Now to make some decisions. I think I need to lie down and have a cup of tea.
FollowupID: 587537
Follow Up By: Member - Ed. C. (QLD) - Friday, Aug 15, 2008 at 11:49
Totally agree re the Rema Tip Top..........
I think you'll find that a travelling rep (with a fully stocked van) will visit most (if not all) areas on a regular basis.. A 'phone call to your state's head office will most likely put you in touch with said rep, and you can go from there:)
A rep visits here (Toowoomba) fortnightly, and if/when I need anything, I give him a call to confirm the date, and Bob's yer uncle;-))
_All_ of the stuff in my (comprehensive) tyre repair kit is from Rema Tip Top..
There may be other stuff as good, but none better, IMO............
Regards, Ed C
Confucius say.....
FollowupID: 587543
Follow Up By: Member - Phil G (SA) - Friday, Aug 15, 2008 at 12:53
Gday Rob,
I tried getting Rema stuff from the tyre shops, but they said they weren't allowed to sell some of the stuff, like the cans of glue.
Motor Traders in Adelaide were happy to sell whatever I wanted.
FollowupID: 587547
Follow Up By: harryopal - Friday, Aug 15, 2008 at 13:39
And thank you again, gentlemen. I am in Townsville and there is a Rema dealer so I will call in there.
In the theatre they wish you well by saying, `Break a leg.' Is there a motoring equivalent? Should I be saying, `Smash a windscreen' or `Blow your gasket' as the equivalent to happy motoring?
FollowupID: 587548
Follow Up By: Tony MD - Friday, Aug 15, 2008 at 14:51
Phil, Rema supplied me the Glue to me direct. They had to deliver it themselves as neither couriers nor Australia Post would not transport this type of flammable material.
Cheers, Tony.
FollowupID: 587553
Follow Up By: Member - Ed. C. (QLD) - Friday, Aug 15, 2008 at 16:19
Harry,
"Keep The Shiny Side Up!" does it for me;-))
Confucius say.....
FollowupID: 587566
Reply By: motor_head - Friday, Aug 15, 2008 at 20:24
Hey Harry, when i was shopping for puncture repair kit i went straight to supercheap auto, their kits didnt even look close to being adequate, so went to arb and bought a quality kit that works great and a spare tube completes my kit......ok i'm not set up for all occasions but i figure if i need to break the bead i will just do it with the jack or drive the vehicle onto it and reset the bead with a tie down and air, luckily ive never had to break the bead but am equipped to do so if neccesary, as for the reamer, i have used it each time but experience is telling me only use it when neccesary, reason being is because i have noticed strands of the steel belt retracking with the reamer when removing, dont think that is a good thing.
AnswerID: 320823
Reply By: richard - Friday, Aug 15, 2008 at 21:39
Perhaps if you contact them (Rema) direct you might get some where their Web site is a shocker and they don't answer emails.
Richard
AnswerID: 320838
