Goog's Track
Planning to do Goog's mid September towing camper. Six vehilces, 3 with trailers. Any one done it recently. Hearing reports that it is pretty soft and some of the longer hills difficult even without trailer.
Reply By: Crackles - Monday, Aug 18, 2008 at 21:26
Even when dry & cut up Googs track is very straight forward & not particually difficult if you let your tyres down. After completing it most people wonder what all the fuss was about. As a comparison the Vic/SA border track is far more challenging.
Cheers Craig...........
AnswerID: 321209
Follow Up By: Twinkles - Monday, Aug 18, 2008 at 22:32
Thanks Craig. I have done the Border track, but not with camper.
FollowupID: 588035
Reply By: Voxson - Monday, Aug 18, 2008 at 22:45
You will do Googs with a trailer no probs...
Low tyre pressure and all will be fine..
AnswerID: 321228
Reply By: Member - Mick O (VIC) - Tuesday, Aug 19, 2008 at 06:45
Twinkles,
I've done Googs towing a Tambo camper trailer with a Navarra STR. It's an easier run heading north than it is coming south. The main problems are on the second half of the track north of Googs Lake. There are some large dunes with long sandy run-ups. As long as the tyres are right down, you should be OK. I was down to 15psi in the vheilce for these. Make sure you do the drive into Mt Finke.
Cheers. Mick
AnswerID: 321236
Follow Up By: Member - Pesty (SA) - Tuesday, Aug 26, 2008 at 19:08
Sorry MickO, gunna take you to task there, the best way is from north to south, as the southern sides of the dunes get cut up and can be difficult for trailer people.
The other reason is that when you finnish your out in the middle of nowhere.
By going south you end up on the coast at ceduna, where there are many more options for things to do and see. We usually enter via Mt Ive road and work our way across and down the track.
We have done the track many times over the last 7-8 years.
Have see it so cut up that good 4by's without trailers could hardly make it through from the south, because wankers dont let there tyres down.
Cheers Pesty
FollowupID: 589322
Reply By: Twinkles - Tuesday, Aug 19, 2008 at 07:04
Thanks for the replies. I usually let my tyres down to about 14psi, so should be right. I have new Dick Cepec (Mickey Thompson) PC-II's and Procomp muddies on trailer.
AnswerID: 321238
Follow Up By: Member - Jeff O (VIC) - Tuesday, Aug 19, 2008 at 16:26
Twinkles.
I did Googs Track South to North last November in my 2007 Hilux.
Tyres down to 18psi.no problems.I camped at Googs Lake and had dinner with millions of flies.I also recommend a trip out to Mount Finke
Jeff.o
FollowupID: 588104
Follow Up By: Member - Mick O (VIC) - Tuesday, Aug 26, 2008 at 21:31
Twinkles,
I've just put the FC II's on myself. Let me (and the forum) know what you think of them over the next 12 months.
Cheers. Mick
FollowupID: 589378
Reply By: Member - Prickle (SA) - Tuesday, Aug 26, 2008 at 18:24
Twinkles,
We have just arrive home from this trip. Travelled North to South (as did it south to north last year). Better drive than from south to north. It was a lot softer and corrugated on the southern approaches last year. They have obviously had a reasonable spot of rain but still drop your tyres down to save the track.
Stayed 2 nights at Mt Fink and 2 at Goog's Lake. The lake is very pretty and I would go back there just to spend more time there, bird watching etc.
Enjoy.
Russ
Life-often hell but never boring.
AnswerID: 322321
