Pioneer Camper Trailer Owners?
Submitted: Friday, Aug 29, 2008 at 19:15
ThreadID: 61199 Views:6682 Replies:8 FollowUps:17
I have just purchased a Pioneer Argyle camper trailer & would like to make contact with somebody that owns one to try to sort out a few issues.
If you could email me a contact phone number to ..... patrol6atnetspacedotnetdotau ..... I would be mosy appreciative, thanks.
Reply By: Member - Redbakk (WA) - Friday, Aug 29, 2008 at 19:43
Hired one of their CT's once......did GCR, up to Kakadu, GRR and cape leveque, and home......great unit and would do it again
AnswerID: 322870
Follow Up By: Shaker - Friday, Aug 29, 2008 at 20:00
Thanks for the reply, I am looking for set up, packing & pack up advice etc.
FollowupID: 589939
Reply By: Austravel - Friday, Aug 29, 2008 at 20:38
Have the Pioneer prospector 4x4. The lower spec model but would expect build quality to be similar. I had nothing but trouble with mine. If you want negative feedback then I'll pass it on. If you're happy with the unit and don't want info I'll keep it to myself.
AnswerID: 322883
Reply By: Mogul - Friday, Aug 29, 2008 at 21:12
What issues are you having?
AnswerID: 322894
Follow Up By: Shaker - Friday, Aug 29, 2008 at 22:39
As I mentioned above, I'm not really having any issues, would really like to talk to an owner to get some tips & ideas.
FollowupID: 589987
Reply By: Austravel - Saturday, Aug 30, 2008 at 11:06
Ok can't help myself. Gather you don't want the faults and that's ok. However there are at least three spots they leak badly. On various trips have noticed other pioneers' leak in the same place so not just mine.
Keep a very good eye on either side of the hinge. There is a plate on both sides just around from the hinge that is either bolted or pop to the floor side (sheet metal). Early ones had one bolt, next they used pop rivets. Not sure now but in mine and others I've seen leaks appear and quite a bit of damage occurs.
Second leak/s: The inner mudguard is sicaflexed at the front and rear leading edges. It only takes a very small break in the gap to allow water into both the kitchen area and under the bed. Gap quality is very poor and in some places just wiped on and not forced in. Best bet is to try digging with a scriber. If the gap isn't filled dig out and redo yourself. Trust me it's worth the effort rather than latter on.
Now I'll shut up but had to tell you some of the worst dramas associated with this camper. Keep a very close eye on the above leaks. Even to the point of lifting a corner of the carpet every now and again to check. As the carpet is nylon it may not feel wet on top. However underneath it's rusting away badly.
AnswerID: 322956
Follow Up By: Shaker - Saturday, Aug 30, 2008 at 12:20
Thanks for the heads up, certainly worth checking.
It isn't that I didn't want to know, I just didn't want it to appear that I was having problems other than trying to get tips on storage & packing up.
FollowupID: 590021
Follow Up By: Austravel - Saturday, Aug 30, 2008 at 13:54
No dramas give me a yell if you ever want to know. Other tip is be extremely careful with the tap, easy to break the inside tags and tap flies off.
We find it much easier to close camper with myself in usual hard floor position (to side and pulling canvas) and wife at rear lifting floor off ground.
Had to make glove like cover to fit over opening of kitchen and rear door to stop dust. Ie if travelling over hundreds of k's will definitely get dust in Kitchen. We increased seal profile size on kitchen which also helped. Careful of rocks being flicked up on top of draw bar box. They tend to roll back and fall down gap between box and main camper and cause a bit of damage, we fill with foam.
Only pack things you don't want regularly to rear of camper (under bed). Get a water proof sheet to throw on top of bed. If canvas wet when closing will open to wet/damp bedding. Check what style of battery switch used. Ours wouldn't switch back on as voltage cut out was lower than the voltage at draw bar due to voltage drop. Make up a second sink hose supplied one to short. With above tap issue, close kitchen fully at night or even just in a couple of inches will disable the pump. Rear legs have no lock nut and thumb screws face down. Have a habit of loosening on rough roads and fall off, just fit a lock nut. Would suggest going over every nut and screw on camper, had a number of things fall off on rough roads. Including bleeder nipple which meant full brake flush.
Be very careful of door zip at bottom. It may not be an issue as depends on how canvas cut. Ours was very easy to get screen caught in zip. Make sure centre canvas pole thumb screws very tight in wind. Don't get caught putting in large items under bed that you need to get out without lifting floor. Am sure you've noticed can't get full height items out door due to lip. Carry hard flat plate to put under jockey wheel in sand and mud. Am told you can leave short awning on when folding camper. We didn't bother as didn't use that often but wonder how much harder it would be to close up. We fitted egg shell mattress to top of supplied mattress, made a huge difference. Wouldn't put heavy tins of food in Kitchen as bearings are not that strong. Really only designed for plates etc which makes sense. We fitted that nylon covered stretchy wire to the sides of the kitchen for tea towels etc.
Don't use cleaners on canvas as will damage proofing so best bet is if you don't want spots on canvas, don't camp under trees. We didn't worry about it but can get heaps of sap, bird droppings etc. Lift canvas flap regularly and clean where seal fits when closing. Especially on dusty roads.
Will post some more if I think of others.
FollowupID: 590034
Follow Up By: Shaker - Saturday, Aug 30, 2008 at 15:19
Thank you!
FollowupID: 590038
Follow Up By: PandJ - Sunday, Aug 31, 2008 at 10:19
Hi Shaker and Austravel,
We have just ordered a Pioneer ONYX and hope we don't have all these problems. Thanks for the info, is worth keeping, just in case.
Thanks P&J
FollowupID: 590152
Follow Up By: Austravel - Sunday, Aug 31, 2008 at 11:54
Hi P&J,
Not having a go at you but unless they've made some major changes to quality control I can't see why not. To be fair since the last director left they've made a lot of changes. The major one is trying to rectify complainants. They did try to sort out my dramas but pretty hard if you don't live in near the manufacturer.
I'd suggest you go over it with a fine tooth comb before accepting delivery. Not kidding get a couple of spanners and go over the camper. Unless things have changed it's unlikely they've used any flat or spring washers. Be mindful of the kitchen tap. If they still use the plastic caravan tank underneath make sure the stone protection goes top to bottom. Ours didn't' hence stone damage. The foam protection used on the brake lines lasts about 100k on dirt roads. The design is very prone to stone damage, you'll probably need a stone skirt. Yes I know most do but they've cut the stone deflector back to narrow and you get damage on the leading edge of the kit door and mud guards. The latest addition of rubber strips on the front of the camper helps.
Look not trying to knock them to much as I'm sure the new management will make it better. Just trying to make you're aware of the pitfalls. If you know them check out the camper before delivery and ask questions then all should be ok. The impression I got is that the new guys are certainly willing to listen.
Difference is they are relatively new and while all the design faults of the other older brands have been ironed out, these guys have a way to go.
Good luck and I"m sure you'll enjoy it just do some checks before handing over the cash and keep a good eye on the potential leak spots.
FollowupID: 590167
Follow Up By: Austravel - Sunday, Aug 31, 2008 at 12:23
Just one more thought. If you can get them to use parallel bearings instead of tapered. I'm pretty sure you can get it as an option. Will be much, much stronger and no dramas with adjustment.
FollowupID: 590172
Reply By: Outa Bounds - Sunday, Aug 31, 2008 at 09:23
Wow! That's the sort of info I would have liked to read when looking to buy any model of camper! Just wanted to say great honest feedback. Although I'm sure you had some positives as well? You obviously chose to buy it over other brands for some reason, just wondering did it live up to the good things? - for the prospective buyers (not me, I just sold a camper).
AnswerID: 323075
Follow Up By: Austravel - Sunday, Aug 31, 2008 at 11:37
The only reason was price. We were traveling for 3mths and wanted a hard floor camper for that period and probably sell on the return. Havn't sold for various reasons but the only reason was price. Didn't have a real opportunity to properly check out the others and they were 5-7K dearer hence the reason for this one.
You get what you pay for of course.
FollowupID: 590165
Follow Up By: Outa Bounds - Monday, Sep 01, 2008 at 08:47
Oh that's a shame, would have been nice to be able to compare a few similar ones in the same price bracket.
FollowupID: 590295
Reply By: Shaker - Sunday, Aug 31, 2008 at 11:47
Thank you very much for all the replies both in this thread & by email.
I have now spoken to several Pioneer owners, & it has been a great help in assisting both in the operation of the camper & storing gear etc.
Storage was one of our biggest issues as we are moving from a Track Desert Eagle, which incidentally will be for sale soon, which has arguably, the biggest storage capacity of any camper trailer.
We would still be grateful for any tips Pioneer owners may have, no matter how trivial they may seem.
AnswerID: 323103
Follow Up By: Gramps (NSW) - Sunday, Aug 31, 2008 at 12:23
Shaker,
As a point of interest, why did you change from the Track Desert Eagle? I have'nt seen much in the way of bad stories about them.
FollowupID: 590173
Follow Up By: Shaker - Sunday, Aug 31, 2008 at 12:35
Gramps, to say it is breaking my heart to part with the Track Desert Eagle, would be the understatement of the century!
Unfortunately my wife has rheumatoid arthritis which at times can make accessing the bed difficult.
This is the ONLY reason that I am parting with my beloved "Eagle".
(The final decison was also arrived at, after determining the comparative cost of changing my wife!)
FollowupID: 590178
Follow Up By: Gramps (NSW) - Sunday, Aug 31, 2008 at 12:45
Shaker,
I thought there must have been a very good reason for the change. Wish you and SWMBO the very best with your Pioneer.
FollowupID: 590181
Follow Up By: Shaker - Sunday, Aug 31, 2008 at 14:47
Thank you!
FollowupID: 590192
Follow Up By: Austravel - Sunday, Aug 31, 2008 at 15:55
Hi shaker,
I'm in the same boat so to speak. Diagnosed last year and now suffering. Haven't used the camper in that period. How do you close the camper up? It's certainly becoming a struggle for me to help. Hence the reason my wife lifts the rear while I drag on the canvas.
Would be interested in your technique.
FollowupID: 590203
Reply By: Member - Paul Mac (VIC) - Monday, Sep 01, 2008 at 07:50
Interesting reading about the faults that have been experienced. I took delivery of my Onyx in February this year and can honestly say I have not experienced anything similar. The only "fault" I had, for want of a better word, was the brand of tyre used. I did a google search on the brand and having read that the US administration was in the process of having these tyres withdrawn from sale in the US I contacted Pioneer who checked out my concerns and immediately replaced them.
I have recently been camping for several days in heavy rain and did not have any canvas leaks inside the camper whatsoever. Had one small leak on the awning zip over the front storage locker but I'm hopeful this will now stop as the canvas has had a good seasoning.
Storage isn't a problem with the Onyx model as there are storage areas under the bed as well as the gullwing and front lockers.
Shaker, if you want to discuss further, you have my number.
Cheers.
AnswerID: 323211
Follow Up By: Austravel - Monday, Sep 01, 2008 at 09:08
Good to hear they must have made quite a few changes.
I've spoken to 4 other owners while tripping around and two didn't think they had any problems until I looked at the leak points and it was just they hadn't noticed. Pealed up a corner of the carpet and there was rust. Actually one of them had the faulty water fillers fitted. There was a large run of water fillers that used to pop off and you'd run water directly into the camper. Also some including mine had no hose clamp, they'd used a zippy tie instead. Filler wan't Pioneers fault it was a Camec brand.
That's great you've had no problems would still keep a very keen eye on those two spots for leaks. The one inside the tyre well will be and if the gap lets go will leak. I'd be interested in how they've fixed the side plates near the rear bar. If they are pop they will snap on rough roads. Tried that with SS and they lasted a couple of weeks. Had to resort to 5mm bolts to lock it all in place. These issues did happen across the and Gibb so had a decent work out. Would have thought however it would be fine as they are off road campers.
Can you let me know which tap they now use. The previous one is very poor quality, a white lay flat unit. You have to be very not to turn off to far as it flexes and breaks a couple of tags inside the tap. Tap can fly off at any time and pump drains the tank.
Quite a few dramas I had were quality control so that may have been looked at with the new management. Also as per previous found the new willing to listen and help were possible.
If you ever want photos of the problem areas to look out for let me know.
FollowupID: 590299
Reply By: Member - Paul Mac (VIC) - Monday, Sep 01, 2008 at 10:15
G'day Austravel,
Yeah, I'd be very interested to see your pictures you mention. Hopefully it will give clear guidance on what to check for.
Look forward to seeing them.
Paul
AnswerID: 323228
Follow Up By: Austravel - Monday, Sep 01, 2008 at 17:22
No dramas. What email address??
FollowupID: 590367
