Icom 400 pro help !
G day ALL !
Finally got my UHF radio. Yes it's an Icom 400 Pro.
Now is it just me, or is it a fact that their instruction manual is virtually useless. I seem to get into endless loops, from pushing buttons, on the panel, and cannnot get out of them.
Plays havoc with my brain.
Does anyone out there know of links, that will allow me to download a user friendly manual, or a site for help.
Bucky
ps works well when I get it into the right mode !
Reply By: Sir Kev & Darkie - Thursday, Sep 18, 2008 at 06:37
Bucky,
At least you have the manual, I don't LOL
Darkie had one fitted when I go him and like you could not work it out so I put my GME in and the ICOM now resides in a box until I can find someone who can show me how to use the bloody thing. It has been programed with a heap of police etc channels but I can't seem to get it to scan the standard channels.
Good luck :)
Cheers Kev
Russell Coight:
AnswerID: 325830
Follow Up By: Member - Doug T (NT) - Thursday, Sep 18, 2008 at 08:57
Kev
Can't you blokes work anything out .....how do ya survive.
Lol
FollowupID: 592900
Follow Up By: Sir Kev & Darkie - Thursday, Sep 18, 2008 at 09:59
I survive by using GME LOL
Russell Coight:
FollowupID: 592909
Follow Up By: Member - Bucky (VIC) - Thursday, Sep 18, 2008 at 20:08
I dunno how.
Maybe it's because I'm of Irish decent
Image Could Not Be Found
And boy does it show, sometimes
Bucky
FollowupID: 593009
Reply By: Member - Dick (Int) - Thursday, Sep 18, 2008 at 08:03
Hi Bucky
http://groups.yahoo.com/group/ic400pro/
Dick
AnswerID: 325840
Reply By: Member - Dick (Int) - Thursday, Sep 18, 2008 at 08:06
Bucky, is the "endless loop" simply the numbers on the dial continually running. If so it is doing a normal Scan of all frequencies. Press the Scan button and it should stop.
Dick
AnswerID: 325841
Follow Up By: Member - Bucky (VIC) - Saturday, Sep 20, 2008 at 07:04
Dick
Read the manual, for the 40th time, and I actually got somewhere !
WOW ! about time....GGGGGrrrrrrrrrrrrrrrrrr now the unit has confused me...
I will give it a break for a couple-a-days !,,, and try again
One thing is for sure,...... the other UHF's are easy to set up, ...
I hope I will be rewarded.. eventually
Bucky
FollowupID: 593249
Reply By: Member - Doug T (NT) - Thursday, Sep 18, 2008 at 08:42
Bucky
I tell people about the 400 pro bloody good radio but if button illiterate don't get one....lol.
Mate.... get your manual in your email right now
AnswerID: 325847
Follow Up By: Member - Bucky (VIC) - Thursday, Sep 18, 2008 at 20:10
Cheers for that Doug !
Same as I got with the unit..
Just the Irish in me,, kicking in..
Still bloody hard to follow
Cheers Mate, ...........and thanks
Bucky
FollowupID: 593014
Reply By: guy007 - Thursday, Sep 18, 2008 at 18:23
Hi Bucky
My pro 400 works beautifully. I two have it programmed with 40 channels @ ++ watts as private channels + police and fire service etc. On open scan it will go through the 40 cb channels + 18 service channels and then through the 40 Private channels. If you take the mike off the hook while on Open Scan then you will be stuck on the channel that has traffic and have to then move back manually to your preferred channel to broadcast. It will tell you in the book how to set on Priority scan. If you select say channel 40 and priority scan you can listen to all the traffic but as soon as you take the mike off the hook you will be back to channel 40 or your desired. It is imperative that the mike holder is earthed for this to happen. Hope this helps.
regards
Guy
AnswerID: 325935
Follow Up By: Member - Bucky (VIC) - Thursday, Sep 18, 2008 at 20:19
Guy
I have had all that offered to me, and it has been done, but all just dumped in..
Can get it one day and not the next, that's the problem.
A local "chic" has offered to tidy it all up, so that should help..
Just another question, I have been through the settings, and the only thing that appears different to the "suggested settings", in the manual is the squelch....
Mine is at 50.... seem to get a lot of static.!
Is this too low.. and are there any other "settings that I should change to clean up the crap, or is it a matter of just upping the squelch ???
The other thing that I can't get my head around is those bars, on the bottom... What do they indicate, ?... or do I just keep reading the manual... over and over and over..whilst the radio is on ...more loops ?
Bucky
FollowupID: 593020
Reply By: Member - GREENDOG - Thursday, Sep 18, 2008 at 19:50
I am just about to buy a pro 400 are they really hard to get to use,or do you just have to spend more time mucking around to understand the radio,it seems to be the radio to buy if you want up market stuff but in the long run is it worth it,cheer's GREENDOG
AnswerID: 325955
Follow Up By: Member - Bucky (VIC) - Thursday, Sep 18, 2008 at 20:23
Greendog
Just mucking about with it !
Tell me about it...
Need another hands on lesson, trouble is the bloke who took me thru it, was pressing buttons too quick... I think he was just showing off...
OK , I'm a little slow sometines, but its a whole lot harder to pick up.. But I supose if I want the best, then I have to take a bit longer to learn it ..
Bucky
FollowupID: 593021
Reply By: SteveL - Thursday, Sep 18, 2008 at 21:13
The squelch setting at 50 is too low from my experience,I have programmed quite a few of them and usually set it at 70 +.
AnswerID: 325986
Follow Up By: Member - Bucky (VIC) - Friday, Sep 19, 2008 at 04:11
Steve
I recon I will just keep it going up higher, 5 units at a time, till I can cut out all the "tail end traffic".
I am not too sure what all the other settings are, but as I said before, I will just stick to the recommended, as per the manual, unless there is a dedicated site that I can get settings, and try them.
Bucky
FollowupID: 593090
