Installing U.H.F into the PAJ
Submitted: Thursday, Sep 18, 2008 at 21:22
ThreadID: 61808 Views:3001 Replies:5 FollowUps:11
I was going to install the radio my self but i have a issue as in,is it as easy as hooking it straight up to the batterty or do you have to go via the fuse box,as the last one i had i just hooked it up straight to the batterty.cheer's GREENDOG
Reply By: Member - Mark G (NSW) - Thursday, Sep 18, 2008 at 21:28
GREENDOG
the uhf should have its own in line fuse. i just connected mine up with the cig lighter. hows life down your way?
cheers.
AnswerID: 325991
Follow Up By: Member - GREENDOG - Thursday, Sep 18, 2008 at 21:40
Hay Mark., not bad mate,went to pick up my new G.P.S today guess what none in stock BUGGA,yeah it has it's own in line fuse so you reckon i'll be o.k putting it on the batterty.cheer's GREENDOG
FollowupID: 593048
Reply By: Stephen M (NSW) - Thursday, Sep 18, 2008 at 21:31
Hi there Greendog, depends if you want it to turn off with the key, or can keep it on without having the key in the ignition. Myn is hooked up so it turns off with the key. I just linked into the cigy lighter on mine as it turns of with the key. The wiring kit that comes with your new radio should have an inline fuse which you still use even thou the cigy has its own fuse as well. Just connect the earth wire to some thing close by that will give you a good earth. You dont have to run the positive wire for the radio all the way to the battery if you want to have it on without the key. Just pick up a wire from under dash that has permanant power. Regards Steve M
AnswerID: 325993
Reply By: Member - Norm C (QLD) - Thursday, Sep 18, 2008 at 21:32
Straight to the battery via the in line fuse that should come with the radio. Very simple project.
Norm C
AnswerID: 325994
Follow Up By: Member - Mark G (NSW) - Thursday, Sep 18, 2008 at 21:40
NORM
thats the simplest way but its a pain in the ar$e if you leave the radio on & it flattens the old battery. as Stephen said, the turn off key/radio is less of a hassle.
FollowupID: 593049
Follow Up By: Member - Norm C (QLD) - Thursday, Sep 18, 2008 at 22:05
Different strokes I guess.
I find it a pain having to have the key in the ignition and on accessories to use the radio.
Also, with the radio connected to the aux battery, I think I would need to leave it on for a VERY long time for it to flatten the battery (measured in days, I suspect).
I've wired this way for several years in different vehicles and always been happy.
As I said - different strokes.
Norm C
FollowupID: 593059
Follow Up By: Sand Man (SA) - Thursday, Sep 18, 2008 at 23:16
Spot on Norm,
No need to have the the UHF connected via the ignition.
I have accidently left mine on overnight without any noticable impact to the battery capacity.
Power is really only consumed when transmitting, not recieving.
Receive power is minimal and you are only driving a small speaker.
Bill.
Bill
FollowupID: 593076
Reply By: Member - GREENDOG - Thursday, Sep 18, 2008 at 21:42
Thanks guys for your ideas,it sounds simple enough
AnswerID: 325998
Reply By: Member - Luke (SA) - Thursday, Sep 18, 2008 at 21:46
G,day Greendog
Mine is hooked up to permanent power, that way you don't have to have your keys on you just to use the radio. mine usually stays on the whole weekend as I forget to turn it off when I get back to camp. I've never had a flat battery
I've been reading your posts about the insurance co. it's good to see everything is working out
Cheers Luke
AnswerID: 325999
Follow Up By: Member - GREENDOG - Thursday, Sep 18, 2008 at 21:53
Yeah thanks Luke,it's takin longer then i thought but not to worry,i'm trying to pick my roof rack up from A.R.B but finding the time is hard and my fridge comes in next week and i get my new XGT's fitted at the end of the mounth so it's all coming together.cheer's GREENDOG
FollowupID: 593053
Follow Up By: Member - GREENDOG - Thursday, Sep 18, 2008 at 21:55
Hay Luke have you seen me around dude cause i just live around the corner from you
FollowupID: 593054
Follow Up By: Member - Mark G (NSW) - Thursday, Sep 18, 2008 at 21:55
GREENDOG
not to worry 'bout the wait............youve got 'till september next year for the gathering at St George,ha ha :-))
FollowupID: 593055
Follow Up By: Member - GREENDOG - Thursday, Sep 18, 2008 at 22:14
Funny that,i am just hoping every thing falls into place so we can come
FollowupID: 593061
Follow Up By: Member - Luke (SA) - Thursday, Sep 18, 2008 at 22:40
No mate I haven't, I've been keeping an eye out for ya. Maybe one day and we could have a coldie or two or three.
Cheers Luke
FollowupID: 593065
Follow Up By: Member - Borgy.. (SA) - Thursday, Sep 18, 2008 at 23:33
"Maybe one day and we could have a coldie or two or three."
Image Could Not Be Found
Cheers......Borgy
FollowupID: 593079
Follow Up By: Member - GREENDOG - Friday, Sep 19, 2008 at 19:10
Hell thats scary
FollowupID: 593182
