oztent rv4 internal measurement
Submitted: Saturday, Sep 27, 2008 at 08:34
ThreadID: 62066 Views:3246 Replies:3 FollowUps:6
Could someone with an rv4 oztent tell me if the internal measurement between the aluminium frame is 2400mm . I need to know if 3 dmh self inflating foam mattreses of 800mm width each will fit between the aluminium frame . cheers . They say its 2400mm x 2400mm but i dont know where this is measured from and the shops i have beem to only had rv5 set up and dont want to set up an rv4 LOL .
Reply By: Sand Man (SA) - Saturday, Sep 27, 2008 at 08:48
Troopyman,
It would be too small regardless of whether the three matresses fit.
You would have no space between the "beds" at all.
Do you already possess the matresses?
Perhaps three swags, or the larger RV5 would be better solutions?
Bill.
Bill
AnswerID: 327356
Follow Up By: troopyman - Saturday, Sep 27, 2008 at 09:00
I already have the mattresses . They are 800mm wide x 1930mm long x 100mm thick . I dont want any space between the beds so i can sleep 4 if needed without the beds moving apart and ending up in the crack LOL .
FollowupID: 594570
Reply By: Willem - Saturday, Sep 27, 2008 at 11:11
Google it
http://www.oztent.com.au/OZTENT-RV-4/
AnswerID: 327373
Follow Up By: troopyman - Saturday, Sep 27, 2008 at 18:58
OK , smart alec . show me the link to where google tells me the internal dimensions between the frame . Maybe you have the internal dimentia .
FollowupID: 594615
Follow Up By: Willem - Saturday, Sep 27, 2008 at 19:22
Specs
Colours: Khaki Green
Weight: 19kg
Packed Size: 2m x 0.35m x 0.15m
Sleeps: 4-5 people
Size Erected: 2.4m(w) x 2.4m(d) x 1.9m(h) + 2m awning
FollowupID: 594621
Follow Up By: Willem - Saturday, Sep 27, 2008 at 19:25
3 x 800mm wide foam matresses will have enough 'give' to fit within the 2400mm space as indicated even if there is a tad of the 2400 taken up by the interior frame
FollowupID: 594623
Follow Up By: troopyman - Saturday, Sep 27, 2008 at 21:06
ok thanks .
FollowupID: 594659
Reply By: Member - Pesty (SA) - Saturday, Sep 27, 2008 at 14:17
I have an rv4, but im not setting it up just to measure it, cos its blowing a hot howling nth gale here today. LOL
It would be 2.4 0n the outside at the point of the canvas.
The front corner upright wouldnt be a problem as the matress would fit next to it, the only pole in your way are the 2 overlocking poles that hold the whole caboose in the upright position.
There are none at the back.
If you carefully jam them in, im sure that they would mould around these 2 side poles.
Are they a big 800 or a little on the shorter side, as we are only talking about 30mm each side.
Hope this helps.
Cheers Pesty
AnswerID: 327384
Follow Up By: troopyman - Saturday, Sep 27, 2008 at 18:59
thanks for that .
FollowupID: 594617
