Radtel Perth Base
Submitted: Sunday, Sep 28, 2008 at 10:19
anglepole
On a recent trip to WA I had great difficulty in accessing Radtel's
Perth Base. I once got a feeble selcall return on 8 mhz. I had no such trouble with the VKS base at
Perth.
Has any one else had this problem?
Reply By: blue one - Sunday, Sep 28, 2008 at 11:16
Mate,
I was up around Alice,
Birdsville etc and had no problems raising
Perth.
Even get them some days from
Sydney.
327479
Reply By: MEMBER - Darian (SA) - Sunday, Sep 28, 2008 at 12:43
Can you recall time of day and distance involved at the time ?
327491
Follow Up By: anglepole - Sunday, Sep 28, 2008 at 20:10
Hi Darian,
I have had no problems getting into Radtel's Bases elsewhere. Infact
Derby and CAB bases were good.
The time of day was usually mid morning and late afternoon. I have to say checking call back with VKS
Perth operated as I would expect.
After trying the Radtel
Perth base regularly over 3 weeks (90-3000kms) it would appear to me to be some what inadequate.
However I take note of the reply that at least one other user has found it OK. I also take note of the other reply about antenna orientation. If the antenna points Northeast it may not be a great signal due north.
594809
Reply By: Member - Mike DID - Sunday, Sep 28, 2008 at 13:47
It depends on the type of aerial each base is running.
One might favour close-in signals and one may favour more distant signals.
327494
Reply By: MEMBER - Darian (SA) - Monday, Sep 29, 2008 at 09:18
I did use Radtel a few years back - the service worked quite
well overall - HF is of course quite variable in performance due to a number of factors, including the actual location of the base hardware - with these networks though, you can pretty
well tap in via one base or another at any time. Generally, VKS737 base operators report HF conditions currently as being quite 'long' - when I used Radtel from central and southern Oz, I was a lot better off using Charters, middle of the day, on those higher frequency numbers. The airwaves were much cleaner in the middle of the day (at that time, I found asian sourced interference on Radtel's frequencies early and late - other networks suffered too of course - propogation for that 'interference' at noon was poor though, so unheard), and my reach to Radtel was good on those higher frequencies - Charters being further away was a whole lot better than the Alice at that time. Hmmm - maybe you were a bit close, for these times, for Radtel
Perth ?
327625
