Tuesday, Sep 30, 2008 at 18:29
The law requires that you can see clearly down both sides of your rig.
Therefore the inner width between the mirrors should be as wide as the widest part of the rig EG the van.
Even on a 100 series the mirrors are not wide enough to see down the sides of an 8ft wide van.
You should be able to see a small object poked out behind the rear corner of your van.
If you cant, technically you are illegal.
Using the normal car mirrors certainly does what you say but should a small child stand at the back corner of your van you may not see it because of the small loss of vision.
I have both a camera and Aussie Truck mirrors and have proved that normal car mirrors do not do the job.
595150
