Cobb heat beads
Submitted: Tuesday, Sep 30, 2008 at 14:36
ThreadID: 62146 Views:6186 Replies:5 FollowUps:2
Hi All
In BCF this morning noticed this product from Cobb.
Cobble stone heat beads, only come in packs of six. Says one will
last up to 3hrs. Has anyone used these? if so what do you think
of them. Cost $13 a pack.
Cheers Brian
Reply By: davida - Tuesday, Sep 30, 2008 at 14:53
This is the info on the Cobb (.au) website. Made from coconut shells, apparently.
http://www.cobb.com.au/cobble-stones.asp
AnswerID: 327788
Reply By: Abraxxas - Tuesday, Sep 30, 2008 at 15:37
Hi Brian,
We tried a Cobblestone for the first time on the weekend and it was very effective, lasting 2 hours 50 minutes. But when you compare the price of a 5Kg packet of the ordinary beads costing about $6 [or 68 cents to cook a roast], it makes Cobblestone expensive at $2.15 per heat bead.
AnswerID: 327800
Follow Up By: Member - Barry H (WA) - Tuesday, Sep 30, 2008 at 17:25
Brian,
I agree they are really good.
I like em because they catch really quickly, and you can be cooking in under 2 mins, instead of sitting around waiting for the other heat beads to burn down.
Because so they burn so effeciently I find myself only using half a Cobb stone which lasts for about 2hrs, plenty of time for cooking roasts etc, used half a stone on the weekend and it cooked a roast beef and then had enough heat left over to bake a loaf of bread, helps bring the cost of the stone down.
Barry H.
FollowupID: 595136
Reply By: Sand Man (SA) - Tuesday, Sep 30, 2008 at 20:13
In my experience a quality head bead such as the Heatbeads© brand gives a consistent result and most recipes you will see, have cooking times based on this level of performance.
I'm not criticising the new "Cobble Stone" product, but it works out considerably more expensive than the Heatbeads© product available in almost all supermarkets. The Heatbeads© product in turn is more expensive than cheaper "generic" brands, but the latters' inferior performance is also an issue to consider.
Now, having said all this, I must try this new product, as the quick "ignition time" appears attractive.
Also, lasting three hours each, you can certainly do a roast, then whack a desert of some kind on while you are eating your main course. Something like a Bread and Butter pudding for instance:-))
Bill.
Bill
AnswerID: 327840
Follow Up By: Pete Jackman (SA) - Tuesday, Sep 30, 2008 at 20:47
If you want quick ignition, stick the basket full of beads on a gas ring. You are good to cook in about 5 to 10 minutes.
Pete
FollowupID: 595179
Reply By: Sand Man (SA) - Tuesday, Sep 30, 2008 at 20:17
On a different (but related) topic, I notice Rays Outdoors are currently advertising a Cobb Premium cooker for $180, which is considerably cheaper than the normal RRP of $234.90.
Bill.
Bill
AnswerID: 327841
Reply By: Tadooch - Tuesday, Sep 30, 2008 at 21:14
I agree with Abraxxas. they are expensive if you use your cobb weekly. A few weeks back, coles had heatbeads brand at $7.95
and their own brand on the shelf for $5.95 so gave 'em a try... 3 firestarters, 10 beads (they are smaller) and 25min later they weren't lit. So 5 min on high gas ring they are glowing. Lamb on. Another 20min and noticed no usual spit and crackle...they were out. Now only good to add 3-4 to top up with 6-8 Heatbeads.
AnswerID: 327857
