Patrol 03 3L Breaking Down under Load
Submitted: Tuesday, Sep 30, 2008 at 16:03
ThreadID: 62151 Views:3438 Replies:7 FollowUps:0
Hi all,
Just had to limp my brothers '03 Patrol auto back from Geraldton as it had a case of the stutters and wondering if anyone has any ideas. We are dropping at the dealers who did a service on it last week but would still like some other advice.
Scenario. He was towing 1.5t boat up from Perth on Sunday on the way north and got around Geraldton before it started breaking down under load. This was about 11am in the morning. Leave it for an hour and give the fuel pump a prime and goes again then starts doing it again once it gets warm.
I was only in Jurien Bay at the time (170 odd kms south) so went up and swapped cars with him. By this time it was around 5.30pm and during the day they'd managed (after lots of looking, changing filters and bleeding the fuel) another 40km before it happened again. They then took the boat off and got it back to Geraldton nice and easy to meet me at 5.30pm.
It was now pretty cool there as the heat of the day had gone. I then left Geraldton by about 6pm and drove the 170 odd km's back to where I was no problem at all and sat on 100-105kph. Didn't miss a beat.
Yesterday I left Jurien Bay and headed home to Perth with it. Was about 10am. I took it pretty easy but there are a fair number of hills coming back. About an hour into the trip going up some hills at about 100kph with overdrive on (about 2000 rpm I think) it started to happen. Just start shuddering and feels like no fuel etc. I then turned off o/d and the revs went to 3000rpm and it did not have a problem going up the hill.
Over the hill slow down and let it relax a bit etc. Temp on it had not moved at all. Problem from then just got worse regardless of speed or gear but dropping back and increasing revs gave a slight reprieve from it.
Finally coughed out as I turned into Cataby truck stop.
Left it for 30min and wouldn't fire even after priming. Left it an hour and it was happy sitting there at an idle and I even drove it around a bit.
Only conclusion I can draw is something in the engine bay is getting too hot and causing the problem as driving through the cool night it did not miss a beat.
As far as I know my brother did not put in E10 or anything.
Any ideas?
Reply By: austastar - Tuesday, Sep 30, 2008 at 16:28
Sounds like fuel vaporising, but is that possible?
Had similar symptoms in an old Volvo, fuel injected, 2 fuel pumps (one lift from tank, one main pressure).
The lift pump had frozen and the extra suction on 35deg day caused vapour lock.
Went ok except when it was hot.
After correct diagnosis and lift pump fix, it fairly flew (by comparison).
AnswerID: 327807
Reply By: Member - Tony B (QLD) - Tuesday, Sep 30, 2008 at 16:30
I had an oldder model patrol once that did this and it had fuel vaporisation problems. Was not enough insulation on the fuel lines and manifold heat vaporised the fuel. Wrapped insulation around line and no more problems, maybee and just a maybee they can still do this. Check how close the lines come to the manifold, maybee also someone has done a modification and taken off a heat shield. Cheers Tony
AnswerID: 327808
Reply By: westozal - Tuesday, Sep 30, 2008 at 18:14
Id be checking the MAF sensor before much else.
AnswerID: 327814
Id be checking the MAF sensor before much else. This is assuming TD 3 Ltr.
AnswerID: 327815
Reply By: qubert - Tuesday, Sep 30, 2008 at 21:14
oh what a feeling
AnswerID: 327859
Reply By: 3.0turbob - Wednesday, Oct 01, 2008 at 09:44
Colski,
Try the Patrol 4x4 Forum.
AnswerID: 327917
Reply By: yakodi - Wednesday, Oct 01, 2008 at 14:42
Our patrol went into limp mode only when towing a load, 2 tonne caravan, but would appear to drive fine when not towing anything. It would get slightly warm but not hot and would be really gutless up any slight incluine. We started with the basics trying to diagnose the problems. The radiator was partially blocked. Once backflushed and cleaned no further problems. Hope this helps.
AnswerID: 327952
