Wednesday, Oct 15, 2008 at 12:56
Hi Gary,
Should have mentioned, I chose the mouse GPS coz it mounts on the roof, and then gives a full hemisphere view of the sky, whereas a dash-mounted GPS has the view partially obstructed by the roof. Not normally a problem, but in thick forest, you need to lock onto every sat you can get, and the roof-mount wins every time.
I had thought of getting a $25 external antenna for my old Garmin, but the more modern BU353 has a 24-channel SIRF-III receiver which really performs.
You'll find it's pretty easy to set up. Under your control panel in Windows, Hardware, Device Manager, you will find which virtual serial Com port number the GPS is running. Under OziExplorer configuration, you set the Com port to that port number (usually com port 5 or 6 on
mine). For GPS type, select 'NMEA only'. It then runs as if it's under a serial Com port.
Gerry
597468
