radio aerial brackets
Submitted: Saturday, Oct 18, 2008 at 08:20
The Geriatric Gypsies
morning all
does anybody know a supplier of different brackets
i am after something that can be loosened off and turn the aerial from vertical to horizontal and back for travelling and stationary
have tried a couple of different sites from google and most seem to be in the uk
tia
steve
Reply By: Member - Mark G (NSW) - Saturday, Oct 18, 2008 at 08:28
Reply By: Member - Ian H (NSW) - Saturday, Oct 18, 2008 at 08:42
We have a Benelec mount that does just that. Mounts on the side of the roof rack and folds down backwards when not needed.
330495
Follow Up By: The Geriatric Gypsies - Saturday, Oct 18, 2008 at 09:14
goodday ian
is that the marine type or do you have a model no i had a look at there site but it doesnt show a bracket like that except for the marine
thanks
steve
598055
Follow Up By: Member - Ian H (NSW) - Sunday, Oct 19, 2008 at 09:29
HI gg,
Mine is the same looking as the troopie bloke has.
598281
Reply By: That Troopy Bloke (SA) - Saturday, Oct 18, 2008 at 10:13
Just fitted an OPEK AM-503 gutter mount swing-away bracket for my NextG broomstick antenna.
Image Could Not Be Found
Got it from Contact Communications at
Gawler SA.
Glenn
330515
Reply By: Sand Man (SA) - Saturday, Oct 18, 2008 at 14:21
I don't see a lot of practicality in these "swing away" brackets.
Surely you want to be able to use the antenna for whatever it is there for at all times???
I just swap the 800mm UHF antenna (mounted on the roof rail) for a 150mm rubber ducky when around town, then screw the longer antenna back on for better reception in the country.
I do the same for the NextG mobile antenna.
Bill.
330551
Follow Up By: That Troopy Bloke (SA) - Saturday, Oct 18, 2008 at 15:03
Maybe not for you....but for others they work
I only have 10mm clearance getting into my carport, so I can't have anything protruding above the roofline.
Around town no NextG antenna needed....phone works fine on it's own.
And UHF....I NEVER use it around town....too many wankers on the airwaves:-(
Glenn
598142
