UHF Handheld Receiver/Transmitter
Submitted: Sunday, Oct 19, 2008 at 09:42
ThreadID: 62677 Views:8104 Replies:7 FollowUps:9
I'm looking to purchase a couple of handheld communicators and would like some feedback on what people think is a good unit to buy.
I have done some research and would probably look at buying at least a 3w unit which appears to cover a reasonable distance.
I have no idea of the better brands and performance though.
Where are the most reasonable places to purchase the units?
Also would require a charger for the units. When charging the units what size inverter would be required if charging from a 12 volt outlet on the camper ?
Any feedback would be greatly appreciated.
Reply By: Sand Man (SA) - Sunday, Oct 19, 2008 at 10:12
Paul,
Prestige Communications is a good place to buy from and I can personally recommend them.
Competitive prices and prompt delivery.
As for an inverter, go for a 300 watt one, which will cover most situations requiring inverter power.
Some of the lower powered handhelds actually use AA batteries.
I have a 2 watt handheld as a second unit which uses AA's. You can use anything from standard AA's through to Alkaline batteries, or even rechargable AA's which use a small charger that plugs directly into the vehicle's 12 volt supply. No need for an inverter here.
The higher powered handhelds however use an internal battery that requires it's own specific charger and therefore you will also need an inverter to run it. None that I am aware of come with the option of a 12 volt charger.
Check out the various brands on offer, then look at the features that are most acceptable to you and make your final choice.
Any of the "brand name" units, (GME, Uniden, Icom) will give good service.
Bill.
Bill
AnswerID: 330678
Reply By: Member - Doug T (NT) - Sunday, Oct 19, 2008 at 10:55
The GME TX6100 is not just another one of the many compact units currently on the market today. GME have spent a considerable amount of time engineering the TX6100 to fulfil the needs of our users and meet the performance expectations that GME products are renown for.
TX6100 - 5 Watt Handheld UHF Radio
AnswerID: 330695
Follow Up By: Member - Andrew (QLD) - Tuesday, Oct 21, 2008 at 11:29
Hey Doug,
Do you know if there a 12v lead for this unit? I'm looking at a handheld for my wifes car, for long distance travelling on the highway, however would like it to run off 12v most of this time.
Andrew
FollowupID: 598723
Follow Up By: Member - Doug T (NT) - Tuesday, Oct 21, 2008 at 15:20
Andrew
I guess any 12 volt wiring would do the trick, I'd limit it to 300 meters though and if she's following along behind just make sure you tell her not to hit the break or communications will be lost..................
Then of course if the GME is to expensive try the newer brand Uniden shown below.
Image Could Not Be Found
FollowupID: 598776
Follow Up By: Member - Doug T (NT) - Tuesday, Oct 21, 2008 at 15:24
Andrew
OK on the serious side I'd say no , and I don't think ive seen any brand that does, anyhow with a 1700 mAh Li-Ion Battery Pack it should last all day , secondly I'd get a second battery , and just charge at night , other option is a small Inverter ,
FollowupID: 598778
Follow Up By: Member - Andrew (QLD) - Wednesday, Oct 22, 2008 at 09:36
Thanks for that Doug,
It was what i thought might be the case.
I see that those cans don't have 12v input either so might just pass on them. :-)
Andrew
FollowupID: 598931
Follow Up By: Member - Doug T (NT) - Wednesday, Oct 22, 2008 at 09:46
Andrew
Your a hard man to please. Cans are free to air, no batteries needed
FollowupID: 598934
Follow Up By: Member - Andrew (QLD) - Wednesday, Oct 22, 2008 at 09:51
Actually the change of company name from Pal puts me off purchasing them :-)
Andrew
FollowupID: 598937
Reply By: Best Off Road - Sunday, Oct 19, 2008 at 11:22
Paul,
Have a look here
http://www.going4wd.com/
All the details for G&C Communications and a brief interview about the one Doug mentioned.
I've been on a day trip with the bloke and he knows his stuff.
Jim.
AnswerID: 330702
Follow Up By: Matt & Caz - Tuesday, Oct 21, 2008 at 09:47
We have just brought a GME TX4400 UHF it works well paid approx $440, hubby installed it.
Matt & Caz
FollowupID: 598696
Follow Up By: Best Off Road - Tuesday, Oct 21, 2008 at 09:53
Did you get it from G&C?
Doesn't matter to me personally, no affiliation, but I like to know if someone I recommend does the right thing.
Jim.
FollowupID: 598698
Follow Up By: Member - Matt & Caz H (QLD) - Tuesday, Oct 21, 2008 at 10:19
Hi Jim,
We got it from TJM Megastores at Caboolture.
Matt & Caz
FollowupID: 598707
Reply By: Robin Miller - Tuesday, Oct 21, 2008 at 11:01
Hi Paul
The UH065SX - available in a twin pack for under $250 remains the best value for money handheld in my opinon.
This twin pack includes the very useful speaker mics and earpieces which make then very useful for placing in a mobile phone holder on a car dash and using as a second radio.
Its feature set and user interface , power up to 2w , AA cells and general quality make it a winner.
While they come with a mains charger and rechargeable batteries , most of those that have taken up this recomendation
don't use these but just use standard AA's and replace them due to the long life.
Range is the combination of sensitivity and power along with an antenna that can be clear of obstructions like a hand.
Other units such as the UH 078 and variations will deliver a bit more range but at about 3 times the price.
AnswerID: 331011
Reply By: OzTroopy - Tuesday, Oct 21, 2008 at 11:04
At $150 you can afford to buy two of these .... from Jaycar.
It is only a 3w max unit ( as sold ) but the external ( car ) antennae fitting solves that shortcoming.
3 Watt 38 Channel UHF CB Radio with Scrambler & CTCSS
This feature rich transceiver boasts a host of functions and will have a wide appeal in personal, sporting, and business activities. The radio has a maximum output of 3 watts which can be reduced to 1W and prolong battery life when the higher power is not required. All 38 legal channels are utilised as well as CTCSS sub channel calling, automatic muting, and four level scrambling which allows private communications on what is normally a public broadcast. The transceiver is supplied with a high gain (168mm) antenna that is attached via a standard SMA connector. This enables the transceiver to be installed with an external antenna to boost the transmission range even further. Other features include dual-watch, VOX, and a built-in stop watch. The transceiver is supplied with a 1,200mAh rechargeable battery pack and mains adaptor. Optional accessories include a hands-free headset with throat mic (DC1039), Motorbike headset (DC1037), 12VDC Car Charger (DC-1036), and VOX Headset (DC-1032).
AnswerID: 331013
Reply By: Member - Paul Mac (VIC) - Wednesday, Oct 22, 2008 at 07:43
Thanks to all who provided responses. Much appreciated.
I think I will go with Robin's suggestion at the moment as I'm only looking at a unit mainly for hiking at present however, will look at upgrading nearer to when I decide to head off on the big trip and install something in the car.
Cheers and again, thank you for all the information.
PS: I was particularly impressed with Doug's communicator but I was a little concerned that the metallic tin might rust a little if used near the sea too often and.........I couldn't see where you fit the lid to prevent water getting into the unit. :-)))
AnswerID: 331159
Reply By: thescatman - Sunday, Nov 16, 2008 at 06:52
NEVER GET A UNIDEN. I have 2 x 5 watt hand held radios. I had a problem with them, took them to UNIDEN and I havent got them fixed yet, that was over 2 months ago, it takes over 10 minutes to get through to them over the phone, then they always transfer you and say they will call you back and they never do. I just went to department of fair trading, hopefully they will resolve the issue, UNIDEN are a nightmare to deal with.
Get an ICOM or Motorola.
My workplace bought 6 uniden handheld radios (uho65sx), all 6 of the radio's are now faulty after 5 months use, uniden radio's will break if used constantly over extended periods, and they are about the same price as quality products, uniden are made in china, icom and motorola are made in japan. WOULD YOU BUY A CHINESE CAR?
AnswerID: 335465
