Simpson in dec.
Submitted: Monday, Oct 27, 2008 at 19:50
ThreadID: 62956 Views:4464 Replies:11 FollowUps:28
Hi. I'm planning a trip to alice springs in the beginning of dec. And since i'm starting out in Brissie, crossing the simpson is tempting. I know this is not the best time of the year at all in there, but since i'm only in Australia untill april, and counting on spending most of the time touring down south, i don't really have a choice of month.
So my question is. Is it even possible to cross the simpson at that time of year or is it just terrible.
If not. Is the Birdsville track any better?
Cheers Thor
Reply By: D200Dug- Monday, Oct 27, 2008 at 19:54
I would not even think about it unless you had no other options.
Getting stuck would mean staying stuck untill sundown before you even considered doing any work.
Think ground temperatures of 50oC + during the daytime.
I would look at the Longreach Boulia Tobomoray Gemtree route as a first option as long as it has not been raining. Any rain and take the Mt Isa route.
AnswerID: 332194
Follow Up By: Member - Mfewster(SA) - Monday, Oct 27, 2008 at 20:18
Agreed. Why do you want to cross at this time? Wirh a very well set up vehicle, known to be reliable and experienced drivers and good communications set up. you might tackle it. but why? You can still get an experience of the landscape around the edges without taking the risks of the crossing. The Old Andado track and down to Mt Dare and Dalhousie will give much of the experience.
FollowupID: 600035
Follow Up By: Member - Footloose - Monday, Oct 27, 2008 at 21:28
I wiould classify such a trip as foolhardy, even for experienced bushmen. Why not go to Birdsville, up to Boulia and across the Plenty "highway" to Alice as suggested above? There can be enough drama going that way in summer, and you'll almost certainly live longer :))
AFAIK the desert has been closed at that time by National Parks in anticipation of unwary travellers.
FollowupID: 600052
Follow Up By: danish_viking - Monday, Oct 27, 2008 at 21:53
Does the Old Andado track cross the birdsville track?
What about the Oodnatta track? Is that any good?
FollowupID: 600061
Follow Up By: Member - Footloose - Monday, Oct 27, 2008 at 22:05
No. the Andado track is roughly northish of Oodnadatta. So you'd go down to Maree on the Birdsville track and up the Oodnadatta track to Mt Dare etc.
The only problerms on the Birdsville and Oodnadatta tracks at that time, apart from it being extremely hot, would be any rain that would strand you, possibly for a while...in the heat :))
FollowupID: 600069
Follow Up By: danish_viking - Monday, Oct 27, 2008 at 23:53
Thank you for your patience with answering, apparently anoying newbees like me (i know that is not your opinion). I will deff. look into going south along the birdsville and north from there to alice springs. And maybe see if I can fit the simpson in later in our travels. Would april still be to hot?
Would you recomment the old Andado track from the oodnadatta? and if then why?
FollowupID: 600092
Follow Up By: D200Dug- Tuesday, Oct 28, 2008 at 00:06
I would think April would be a LOT more pleasant and safe :-)
I have no problem with people asking questions I prefer that than foolhardy people getting into dangerous situations and endangering the lives of others who have to rescue them.
What kind of vehicle are you planning on taking ?
Remember to take spare water spare fuel and let someone you trust know where you are going and when you arrive and if you get stuck stay with your vehicle !
FollowupID: 600095
Follow Up By: Member - Footloose - Tuesday, Oct 28, 2008 at 00:13
April should be Ok...certainly far safer and more sensible than summer.
If I got to Oodnadatta, I'd probably go up through Mt Dare to Alice Springs, but once again it's not a great time to go that way.
I rekkon I'd of had enough by the time I got to Oodnadatta ! LOL
It's also the two legs of a triangle to Alice Springs, with the shorter one going across the Plenty Highway.
I'm assuming that you have a recent model serious 4wd in mind and it has both survival and communications. Air con is mandatory to keep cool and the dust out !Remember that in summer your fluid intake should be about double that normally...and I mean water, not beer !! You'll need shade in case you break down, there isn't much out there.
Make sure that if you're renting, you take two tyres, tyre changing and repairing gear (not bike or airbed patches!!!!).
Remember that once you leave the tar you're on your own. No towns or garages in hundreds and hundreds of km. No breakdown service, although RACQ EXTRA is worth the money in case you do have strife. Check it out if you havent already done so.
Do make sure that someone knows if you do go missing, or your chances of survival are slim.
FollowupID: 600098
Follow Up By: danish_viking - Tuesday, Oct 28, 2008 at 00:14
I will try and plan for it in april then.
My car is a Hilux surf. And i will take plenty of water and fuel. plus a satphone, and a UHF. And a lot more :).
Can you recommend a good map showing all these different tracks in there? I'm drowning in maps, and they're all missing some point, ether it being the small tracks or the greater picture.
FollowupID: 600099
Follow Up By: Member - Madfisher - Tuesday, Oct 28, 2008 at 10:50
Hilux Surfs where not designed for hot Australian conditions. They where designed to be used in Japan. Australian spec vehicles have larger radiators etc. They overheat in summer in surburbia, let along the outback, and remember you will not be use to our heat. I live in the central west of NSW and will only go south (snowies, Tas) in the Summer.
Goodluck Pete
FollowupID: 600151
Follow Up By: Member - Mfewster(SA) - Tuesday, Oct 28, 2008 at 11:41
Danish V.
I originally suggested the Old Andado track rather than the Simpson at that time of the year. You asked why I would recommend that track as an alternative. I've done it a couple of times around December/February and also in a 4Runner that is nearly identical to your Surf ( but I would also take note of the post from Madfisher about the size of the radiator in the Surf) . It takes in a lot of country that will give you a similar experience to the Simpson, but is much safer. More vehicles go along there at that time (not very many, just more than across the Simpson) Vehicles from aboriginal communities and some cattle properties plus a few more tourists likely to be around because of Xmas holiday period.You don't have big dunes to cross but you get to see some at the side of the road that give some idea of the Simpson landscape (around the Old Andado station area). I'd go through Mt Dare Old Andado and Santa Theresa to Alice Springs. These roads are better marked and a lot smoother than the Simpson tracks. I would do a side detour from Mt Dare to Dalhousie Springs, then back to Mt Dare. But I would make sure that Mt Dare knew I was doing this and when you were expected back in Mt Dare. The Mt Dare/Dalhousie bit is the beginning of the Simpson crossing, so you could have a look. This road is rough, but safe enough for a brief expedition and you don't have to deal with sand dune crossings. Wouldn't go beyond Dalhousie Springs however.
I'd take the advice being offered here and I wouldn't underestimate the trip. 10 litres of water per day per person should be carried and I would take extra for a couple of unplanned days. Take all the communication gear and spare tyres. And make sure it is securely packaged and carefully packed. Plastic water bottles can rub on each other and other gear while going over rough ground and then the bottles you thought were full are empty.
I'd note the warning from Footloose on the problems with rain at this time of the year. This will strand you, but then leave you unable to move for days. I'd be especially careful of claypans where what looks like rock hard surface (even when there hasn't been rain for months) can give way and you find you have broken through to grease. Most of the claypans have sidetracks so you can go around them and I would take these alternatives. Make sure people know where you are going; when you are expected and will raise alarms if you don't turn up or make contacts on time.
You will enjoy it more in April and there will be more other vehicles around, but it can still be very hot. We were in the Simpson a month ago and already it was ferocious. I can send you some photos if you like that will give some idea. If you take the precautions, and have no options for a later time of the year, I think it would be OK to do this track in December February. Much, much better to try to convoy it with another vehicle, especially as you are new to this type of country.
FollowupID: 600159
Follow Up By: D200Dug- Tuesday, Oct 28, 2008 at 12:17
This is good advice, remember also the effect extreme temperatures have on your vehicle. Grease oil tyres cooling systems and mechanical parts are all more likely to fail in these temperatures, I have seen the preparation army drivers make before operating in these areas in the summer.
http://www.theage.com.au/ffxImage/urlpicture_id_1047749717232_2003/03/18/18TROOPS_SAS.jpg
this is a photo of the standard patrol vehicle for these areas the circle thing in the center is the fuel tank !!! They always operate in units of 3 vehicles.
FollowupID: 600165
Reply By: Vince NSW - Monday, Oct 27, 2008 at 20:29
As stated above. Think again. There are few if any other travlers at that time of year, so little chance of help coming to you without VERY good communications in the form of HF or sat phone. The Birdsville track will be just as hot but it is now a well used road even in the hotter months. Vince
AnswerID: 332206
Reply By: NeilT - Monday, Oct 27, 2008 at 20:43
Hi Thor,
Man if you're a Danish Viking you'd best remember you're in the Southern Hemisphere. Head SOUTH for the summer and into the hot desert (even Alice) for the winter. NOT vice-versa - that way madness lies...
AnswerID: 332211
Reply By: Holden4th - Monday, Oct 27, 2008 at 20:53
I've seen it somewhere (but can't find it) but I believe that the SA Parks guys have closed the Simpson desert from the last week in November to the last week in February. Can anyone confirm this?
AnswerID: 332217
Follow Up By: REV'S - Monday, Oct 27, 2008 at 22:19
Yes that is correct I have read it somewhere as well, could have been in the open road.
I have recently crossed the Simpson one of many crossings over the years. I can see why NP are closing the tracks. The tracks are in a very bad condition, the worst crossing I can remember due to the corrugation's and soft sand. I agree that it should be closed over the summer months for obvious reasons.
cheers Revs
FollowupID: 600078
Follow Up By: Crackles - Monday, Oct 27, 2008 at 23:13
There has been several posts "somewhere" of a summer desert closure but yet to see a link to anything official. A simple search of the SA parks & track closures makes no mention of any such proposal, strange particually as this mythical closure is only 4 weeks away ;-)
I dissagree with any broad track closure of the desert. Although potentially dangerous during the summer period, a well set up group can cross without issue be it quite uncomfortable.
I do question peoples ability to be able to cross the desert safely at such a difficult time particually if they need to ask if it's even possible on a public forum?
Cheers Craig...........
FollowupID: 600088
Reply By: danish_viking - Monday, Oct 27, 2008 at 21:41
thanks for your advice. I will consider your sugestions.
Steve there's no need to be unpleasant. That's why i'm asking the question. I'm not trying to prove anything.
AnswerID: 332238
Follow Up By: Kiwi & "Grenade" - Monday, Oct 27, 2008 at 21:51
you were smart for asking, dont worry....but I wouldnt be doing it thats for sure.....too many people have carked it out there....and some were even a local family on the birdsville track....
steer clear and enjoy it another time if possible..
Laura
FollowupID: 600059
Follow Up By: Member - JohnR (Vic) - Tuesday, Oct 28, 2008 at 08:17
d_v in July we met some German people in a Troopy doing a Simpson crossing that really were having a ball. It was not their first visit here and their security was the reason to be here, in the outback and in Australia. Enjoy your time in here safely.
FollowupID: 600131
Reply By: Kim and Damn Dog - Monday, Oct 27, 2008 at 22:08
I hope this is'nt the same fella again, who's been bothering this site in the last few months.
Kim
AnswerID: 332248
Follow Up By: Member - Footloose - Monday, Oct 27, 2008 at 22:12
Kim, no it isn't. See my post above. No skate boards or thongs with this one :))
FollowupID: 600074
Reply By: Member - Footloose - Monday, Oct 27, 2008 at 22:18
I'm afraid that from time to time this forum is plagued by silly enquiries. People wanting answers to questions that quite frankly place them in the *loony* or annoying category.
Please excuse those of us who feel that such a trip is a trifle too much like these.
I know that it's not, but others here have been through similar posts before, and tend to jump on any posts that remotely resemble anything *dodgy*
We really are a friendly mob...most of the time :)))
AnswerID: 332251
Follow Up By: Kim and Damn Dog - Monday, Oct 27, 2008 at 23:05
Gidday Footy
No mate, not trying to knock the fella. If he want's to hire a 4WD and drive off into that sort of heat, Good luck to him.
I don't have much time for dills any more.
Kim
FollowupID: 600085
Reply By: D200Dug- Monday, Oct 27, 2008 at 23:43
I think it would be far more foolish not to ask questions !
I would ask what vehicle you have DV and what experience you have in desert driving under extreme conditions?
This would not be a trip I would consider unless absolutely necessary and I would not attempt it with less that 2 well equipped vehicles and experienced drivers.
If you must see that area contact a tour company and see if they run any trips at a time suitable to you.
Or come back to Australia in our winter when conditions are much more pleasant. I doubt people from Europe can really quite understand the heat and conditions out there at this time of year.
I have worked with a few university researchers from overseas who have attempted to plan field trips to areas locals would never consider at that time. ( One researcher was planning to drive to Darwin from Brisbane he had his car packed and was leaving on Friday morning and planned to be back at work on Monday morning )
AnswerID: 332270
Follow Up By: danish_viking - Tuesday, Oct 28, 2008 at 00:05
Thank you. Yes it is rather hard to imagine a heat that fearsome, since i'm from denmark where we rearly see more than 30C, and therefore i am glad that this group exist so i can ask. And i will take your advice ofcause.
I drive a hilux surf 93, and i have a lot of 4wd experience althoug I must admit not any specific dessert experience. I plan to take a sat phone ao. no matter how the plans turn out and hope to be able to do the simpson later in our travels.
FollowupID: 600094
Follow Up By: D200Dug- Tuesday, Oct 28, 2008 at 00:12
The heat is just insane out there you will drink 10 lt of water a day just sitting in the shade. Double that if you are working. See if you can find another vehicle to travel with in convoy, it is safer and more pleasant.
( do not watch "Wolf Creek" on DVD before leaving :-) !!!!
Cheers doug
FollowupID: 600097
Follow Up By: Member - Footloose - Tuesday, Oct 28, 2008 at 00:21
Mate, it's difficult for many of us to imagine trying to survive in the Antarctic (European winters) LOL.
Driving quickly on ice isn't fun. And the snow, ice and hail etc are so different to the glossy pictures shot in a European summer.
But it's a similar extreme with our desert summers. A different planet. If things go wrong it can bite you..BIG TIME.
FollowupID: 600100
Follow Up By: danish_viking - Tuesday, Oct 28, 2008 at 00:48
haha good one with wolf creek. Luckily i have only heard of that one.
I did'nt know about plenty highway. When you wrote highway I thought it was the bitumen highway from Mount isa. Is Plenty highway worth it. I mean you save a lot of km's but it sounds quite boring in the description on this site. Is'nt it worth the extra km's to go down the birdsville and up one of the two mentioned to get to alice s.?
FollowupID: 600107
Follow Up By: Member - Footloose - Tuesday, Oct 28, 2008 at 00:59
The Plenty Highway runs through some pretty special country on the northern end of the Simpson. It's corregated, remote and beautiful counytry but no highway as you know it. It's not really desert country but more scrub and mountains. There are a couple of places along there if you really get into strife..even a police station at Harts Range, a few hundred K from Alice.
The Birdsville /Maree/Oodna run is pretty much sand and rock and a bit of desert. It's a very different route, with heaps more to see. But in summer ??? mmm...
Take a look at "places" on this site. Good mud maps here but I use Hema maps and Natmap myself. Google Earth is also a useful tool when looking at these areas.
FollowupID: 600108
Follow Up By: danish_viking - Tuesday, Oct 28, 2008 at 01:07
great. One last one. What would be an apropriate time frame for plenty highway and for the birdsville-maree-Oodna route?
FollowupID: 600110
Follow Up By: Member - Footloose - Tuesday, Oct 28, 2008 at 01:14
Plenty Highway, Boulia to Alice, 2 days unless it rains. Then it can take a lot longer.
Burdsville to Oodna, around 4 days. Another couple to Alice ?
I am talking normal days , summer temps will mean driving slower. It will also depend on road surface conditions etc.
FollowupID: 600111
Follow Up By: danish_viking - Tuesday, Oct 28, 2008 at 01:25
Thanks a lot for all the advice. Have a good one.
Cheers Thor
FollowupID: 600112
Reply By: The Landy - Tuesday, Oct 28, 2008 at 06:16
Keep checking back into this site as you might be able to link up with someone for a Simpson trip in the coller months.
Good luck
AnswerID: 332287
Follow Up By: The Landy - Tuesday, Oct 28, 2008 at 06:17
...cooler months
FollowupID: 600120
Reply By: Top End Explorer Tours - Tuesday, Oct 28, 2008 at 09:49
Hey DV
Try this, Brisbane, Toowoomba, Miles, Roma,, Charleville, Quilpie, Noccundra, Innamincka, Lyndhurst, via Strezelecki track then up the Oodnadatta track to Marla then out to the rock from there.
My 6 year old and I did this from Bundaberg in January it was 49 in the shade but we were well prepared, we had an absolute ball.
That way is safer and IMHO, just as scenic, you could visit the Dig tree, then Burke and Wills grave, then find were they found King, while you are doing that learn about some Oz history, ( The Dig Tree by Sarah Murgatroyd ).
Just to let you know, Philip and I are used to the heat, as we live in Kakadu were we get temps well into the 40's both dry heat and humid.
Be well prepared and have a great trip.
Cheers Steve.
AnswerID: 332302
Reply By: danish_viking - Tuesday, Oct 28, 2008 at 12:00
Thanks you guys. I will go and get a better map today, that gives me a better overview of all the tracks you are sugesting. The maps in here are very nicely detailed, but they are not good for the overview or maybe i just can't twist them the right way.
I will try and tjeck in on the forum later on, but i'm going to be on the road from dec. till april, so internet is not going to be my best resource. If any of you are planning a simpson trip in april and would'nt mind a tag along, write me an email on t_villesen AT hotmail.com .
Thor
AnswerID: 332318
