"Turboing" non turbo motors
Hi All,
Was wondering if anyone has any knowledge on whether the practise of strapping a turbo on a non turbo engine has any downfalls? i have heard a few opinions from different sides of the fence and thought here would be the place for a few honest opinions. I have already fitted a DTS turbo to my 100 series so its a bit late now anyway if things are grim.
The power is great and economy (13.5l/100k) has also improved and I only opted for a mild boost (10psi). As yet I have not fitted an intercooler but think this may also help engine longevity??? Any advice opinions welcome.
Reply By: Member Brian (Gold Coast) - Wednesday, Nov 05, 2008 at 15:31
Hi gezza,
I had a turbo fitted nearly three years ago to my GQ 4.2.... I also run it at about 10 psi boost and can honestly say I am very happy with it. There shouldn't be any downfalls, as long as you are aware of allowing the turbo to cool sufficiently before surning the key to "off". I use a pyrometer to monitor Exhaust Gas Temperature and never turn the engine off till the temp read below 175 deg C. This will ensure the bearing in the turbo doesn't cook! I also monitor the EGT whilst driving to avoid melting the turbo on mountain climbs etc.... I use 600 deg C as a max, and when it hits 600, I back off the pedal till the EGT starts to fall. Again, this is taking care of the turbo and the engine.
I believe that an inter-cooler will improve the longevity of the engine, but as yet I haven't bothered to add one.
Hope this helps,
Brian
AnswerID: 333759
Follow Up By: Member Brian (Gold Coast) - Wednesday, Nov 05, 2008 at 15:33
Doh!!
Shoulda used the 'ol spell checker there Brian!!!!!!!!
LOL...
FollowupID: 601556
Follow Up By: gezza100 - Thursday, Nov 06, 2008 at 11:38
Hi Brian,
Thats good to know that your beast is doing fine without the I/C, I use a EGT and a trubo timer for no less than 5 minutes regardless of how long I have had the engine running so hopefully this should keep everything fine. Thanks for the info.
FollowupID: 601685
Reply By: Exploder - Wednesday, Nov 05, 2008 at 17:41
A intercooler will help in allowing you to make the same power with less boost or more power at the same boost as the charge air is now cooler so more dense.
The one thing that will kill engines that were not designed for a Turbo is pushing too much boost throe it, as your NA Diesel will run a higher compression than a Turbo diesel engine, pistons, rods and bearings are all now under more stress as the motor is compressing more air and the subsequent bigger bang that results.
AnswerID: 333783
Follow Up By: gezza100 - Thursday, Nov 06, 2008 at 11:40
Hi Exploder, good points. If and when i get the I/C I will stay with the same boost and just cool as you stated.Thanks
FollowupID: 601688
Reply By: Member - Oldplodder (QLD) - Wednesday, Nov 05, 2008 at 18:05
Looked at this when I bought my pajero.
The 2.8 came as a non turbo in the base model and turbo'd and intercooled in the next model up.
Had a friend in the trade make enquiries with Mitsubishi and the turbo'd model has different con rods and pistons and a few other little things. The price difference was just the cost of the aftermarket turbo, so went for the factory model.
Reckon the cruisers and patrol 4.2 diesels though most probably have a little more in reserve than my 2.8 to take a turbo.
AnswerID: 333786
Follow Up By: gezza100 - Thursday, Nov 06, 2008 at 11:42
Hi John, Yes I think you might be right there, I imagine the nissan/toyotas 4.2 engines are probably a little over-engineered which might put a bit of a safety margin in play.
FollowupID: 601689
Reply By: guzzi - Wednesday, Nov 05, 2008 at 19:38
As has been mentioned, the basic engine architecture is different, pistons and con rods are a lighter specification and the non turbo will not have oil spray cooling under the pistons. The 1 HZ engine has issues with the precombustion chambers in the head cracking at high boost levels.
That being said if you don't go squeezing the last erg of power out of it and blasting in ridiculous boost levels the engine should last quite a long time with mild boost ie 7 tp 9 psi.
Change the oil every 5000k with a good oil, filters every 5000k as well, air and fuel filters every 10,000k, service your pump and injectors every 100,000 km, fit a boost gauge and pyrometer and you should get a fairly long service life out of it.
Have a read on here;
http://www.lcool.org/forum/index.php
The turbo debate is well covered.
Think about getting a boost compensator fitted when you have your injection pump serviced ( $600 ish on top of the pump $$$), which will prevent overfueling at lower RPM and provide better ecomony and a bit less black smoke . An intercooler isn't really required for the boost levels these engines can take ie 7 to 10 psi although it will cool the air charge by about a 1/3 to 1/2 ie if the inlet temp is 90 deg C expect it to drop to around 45 to 55 deg. Whether you need one would depend on what you are doing with the vehicle, ie cruising vs heavy towing etc.
I'm looking at fitting a turbo to my 80 series cruiser in the nearish future, how do you find the DTS unit for performance ,fit and finish?
Pete
AnswerID: 333799
Follow Up By: gezza100 - Thursday, Nov 06, 2008 at 11:49
Hey Guzzi,
Thanks for your advice and yes I run an EGT, plus a turbo timer always. Prior to the fitment i replaced the big end bearings and had the shims/tappets adjusted as well as the injector pump checked out, I;m hoping all that put together with mild boost (10psi) and not too brutal a right foot will keep things happy.
The DTS kit is very neat, looks like it is a factory install to be honest. The power is outstanding, on my 1HZ with 230000k, at 10psi boost + 3 inch mandrel system, power went from 51 rear wheel hp to 118 rear wheel hp according to the dyno sheet I was provided.
I am sure the fit would be just as neat on the 80, I guess performance will be a little bit dependant on each indivudual engine but mine were impressive. Good luck you wont look back once you have the turbo on board.
Gezza
FollowupID: 601690
Reply By: rumpig - Wednesday, Nov 05, 2008 at 20:10
couple of pics of mine for you pete, DTS turbo and frontmount intercooler setup on a 105 series cruiser
AnswerID: 333807
Reply By: furph - Wednesday, Nov 05, 2008 at 20:29
I have had a Garratt t28 turbo (9psi boost) on my '97 1hz for the last 40000km.
I originally "derated" the pump, at the altitude we live the black smoke drove me mad.
So when I installed the turbo I reset the pump screw to the original setting.
The turbo setup has proved perfect for the added torque required in the towing we do, not interested in a heap more horses.
A valuable bonus is an improvement in fuel economy, now always less than 11litres/100km not towing, av. 15L/100 towing 2tonne.
I also believe a side effect of the better combustion is much cleaner/less contaminated oil. For instance at my 5000km. change the oil is now only a dark honey colour as against jet black previously.
Probably an urban myth, but was told that later 1hz motors had reduced structural integrity of the internals from lightened pistons etc. in the interest of reduced friction/economy.
Reckon if its going well and you are happy with the result thats about all that counts. I know I am.
furph
AnswerID: 333813
Follow Up By: gezza100 - Thursday, Nov 06, 2008 at 11:51
Hey Furph, yeah your right mate and I am happy and all seems fine.
FollowupID: 601692
Reply By: Robnicko - Wednesday, Nov 05, 2008 at 22:30
Provided you de-compress the motor by either pistons or decompression plate and do not run too much boost you should be fine.
If you dont then it's only a matter of time
Rob
AnswerID: 333844
Follow Up By: gezza100 - Thursday, Nov 06, 2008 at 11:52
Robnicko, thanks for your reply, how much or too what level should the motor be de-compressed?
FollowupID: 601693
Follow Up By: Robnicko - Thursday, Nov 06, 2008 at 11:58
Basically you would want to have the same compression ratio as the factory turbo fitted model.
I experimented with Turbo's about 20 years ago on a mazda rotary engine that ran 9:1 compression and while it went like crazy it would not last long. I changed the rotors to 8.5:1 compression and reliability was not an issue after that.
Mazda run 8.5 turbo and 9.0 normally aspirated.
Lots of people turbo non turbo motors without a problem however the turbo gives so much more compression that you really need to be careful and not over boost it.
Rob
FollowupID: 601695
Follow Up By: David N. - Thursday, Nov 06, 2008 at 16:24
"Provided you de-compress the motor by either pistons or decompression plate and do not run too much boost you should be fine. "
Absolutely not done on a diesel. Completely off track, I'm afraid.
FollowupID: 601713
Reply By: Member - 120scruiser (NSW) - Friday, Nov 07, 2008 at 16:23
Too much boost and too much fuel = as stated too higher exhaust gas temperatures (EGT) which will crack the pistons in a 1HZ engine.
You need a pyrometer or EGT guage and the egt's need to be under 550 degrees under load after 2 minutes.
This is going straight of Denco Diesels install and warranty instructions.
I have a set of pistons out of a 100 series that has less than 80 000 km on it with a DTS turbo that was opened up too much.
It now has a 1HDT engine in it.
AnswerID: 334081
Reply By: Member - Bucky, the "Mexican"- Saturday, Nov 08, 2008 at 08:33
gezza100
Mate did the turbo, and intercooler thing on his '99, 100 series Cruiser. He cannot be happier.
But be careful, I have heard another side to this arguement.
Have a look at a factory turbo motor, pulled down, compared to a non turbo motor, pulled down.
Now there will be some manufacturers that have exactly the same specs on both motors, ie the thickness of all the internals of the engine, con rods, crankshaft, pistons, ect.
There are also manufacturers that use lighter internals (because it's cheaper) for the non turbo'd motors.
Be carefull in your decision, and I hope that yourself, or someone else on the forum, can tell me that I am wrong..
Bucky
AnswerID: 334182
