Shaft Lock Pin
Submitted: Tuesday, Nov 11, 2008 at 14:11
Member - Roachie (SA)
Does anybody know where I can get hold of one of these square (ish) Shaft Lock Pins, please? Plenty of
places sell them with the curved spring, but the square ones are hard to find.
Image Could Not Be Found
Thanks in advance for any ideas....
Roachie
Reply By: Peter McG (Member, Melbourne) - Tuesday, Nov 11, 2008 at 14:58
Let me know when you find out Bill. The round ones are from your local Bareco dealer:
Dealers in postcode area SA 5554
Name Address Suburb Phone Fax Email
Agserv Industries (SA) 14 Kennett Street Kadina 08-8821 3922 08-8821 2820
G & J East 11 Goyder Street Kadina 08-8821 1188 08-8821 2918
Larwood's Ag.
ServicesMoonta Road Kadina 08-8821 1999 08-8821 2866
Measday's
Services Pty Ltd 13a Martin Terrace Kadina 08-8828 0200 08-8828 0250
334644
Follow Up By: Member - Roachie (SA) - Tuesday, Nov 11, 2008 at 16:28
Thanks Peter,
I'm trying to get 4 of these for the legs on the Ultimate. The drop nose pins get lost etc and I'm hoping that these ones can be held on with a length of chain etc, so they can't get lost/left behind.
The "D" shaped ones work okay, but are more difficult to fit onto the squared-edges of the legs.
I've tried the local tractor
places and they only have the rounded type.
Roachie
602455
Reply By: Saharaman (aka Geepeem) - Tuesday, Nov 11, 2008 at 15:10
Roachie,
The most likely place is your local tractor or machinery dealer. If you have already tried them without success you may have to import some. They are also called Coupler Shaft Pins. A company called nanshun in Taiwan makes them but I dont know if they have agents in Australia. I have a Bare-Co catalogue and they only have the curved ones as far as I can see.
Try:
http://www.nanshun.com.tw/style/content/CN-08-2cp2/product_detail.asp?lang=2&customer_id=1662&name_id=56315&rid=26159&id=152550
GPM
www.nanshun.com.tw
334645
Thanks GPM, the search will continue..... hahaha ;-)
Roachie
602456
Reply By: Tim - Stratford (VIC) - Tuesday, Nov 11, 2008 at 15:48
Roachie,
The one on the right is exactly what came with my bike carrier. It is a Thule Brand 4 bike carrier - you can get spare parts from Thule from some Auto or pushbike shops. Have a look at their web site.
Mine suit 2" section)
Tim
334656
Follow Up By: Member - Roachie (SA) - Tuesday, Nov 11, 2008 at 16:25
Thanks Tim; I will give that a try; the one's I'm after are 2" long as
Roachie
602454
Reply By: Member - Cookie & Di - Tuesday, Nov 11, 2008 at 16:46
We got ours from a Tractor
shop on the outskirts of Mt Gambier on the Western side of town.
334677
Follow Up By: Member - Roachie (SA) - Tuesday, Nov 11, 2008 at 17:08
Thanks Cookie,
Was that the squared-type?
All the tractor
places I've been to so far only have the "D" shaped ones with the semi-circle spring clip....
Roachie
602472
Follow Up By: Member - Cookie & Di - Tuesday, Nov 11, 2008 at 22:58
Nah it was the "D" shaped one & it was at
Naracoorte SA Tractor Place.
602553
Reply By: Member - Cookie & Di - Tuesday, Nov 11, 2008 at 16:49
We got ours from a Tractor Dealer on the outskirts of Mt Gambier on the western side of town.
334679
Reply By: DesF - Tuesday, Nov 11, 2008 at 19:08
Hi, Roachie, you can get pins like that from farm implement
places we use a lot of the on the tractor etc at the club , you can get then from Auto Crash in Pirie , we have them in sizes from 3/8 up to 1/2" I reckon , they have a "D" shaped spring over centre ring on them would be easy to attach a chain or such to.
Cheers Des.
334702
Follow Up By: Member - Roachie (SA) - Tuesday, Nov 11, 2008 at 19:26
Thanks Des,
Yes, I have found plenty of
places that stock the "D" shaped ones.
The job I need them for relates to square box section tubing and that's why I'm specifically chasing the ones like in the photo with the square spring, instead of the rounded one.
Thanks anyway.
Roachie
602503
Reply By: MEMBER - Darian (SA) - Tuesday, Nov 11, 2008 at 21:28
Re that pin on the right Bill - my Campomatic uses them too, for locking of the stabiliser legs and also the main box closure. Only diff is that the retaining clasp on
mine is curved - not squared. Anyway - if you get stuck, Campomatic in
Sydney seem to be geared up and organised now - I rang and ordered some new gas struts the other week - very good price and delivered promptly to my door via A post [
http://www.campomatic.com.au ].
334744
Reply By: Member - Murray R (VIC) - Tuesday, Nov 11, 2008 at 21:32
Hi roachie
If you have the pins maybe you could make your own square springs out of stainless welding wire as this has a fair amount of spring to it and it might do the job.
regards Murray
334747
Follow Up By: Member - Roachie (SA) - Wednesday, Nov 12, 2008 at 17:17
Thanks Murray, that was one of the suggestions the bloke at the Case joint made as
602661
Reply By: Member - Duncs - Tuesday, Nov 11, 2008 at 22:19
G'day Roachie,
I don't know about the exact pin you are looking for but in the past I have had success getting odd pins and clips etc. from yachting chandlers.
The place that springs to mind in
Sydney is Universal Engineering Supplies used to be in Marrickville not now though
http://www.uesint.com/
UES (INT'L) NSW
1/453-455 Victoria St,Wetherill
Park NSW2164
Tel: +61 (02) 8745 9000
Fax: +61 (02) 8745 9099
I would give them a ring and fax a pic of what you want. They are very good.
Duncs
334764
Reply By: Member - Luke (SA) - Tuesday, Nov 11, 2008 at 22:26
If your after the one on the right they are a standard part on the Caterpillar skid steer (bobcat). They hold the safety brackets for the lifting ram on the machine.
As said above you should be able to get em from agricultural outlets.
Cheers Luke
334769
Reply By: wafarmer - Wednesday, Nov 12, 2008 at 01:11
Hi Roachie
They were also used on the Case IH !600 and 2100 and 2300 series harvesters to lock the Mcdon front on.
Try a CNH dealer
Cheer's
wafarmer
334788
Follow Up By: Member - Roachie (SA) - Wednesday, Nov 12, 2008 at 13:06
Damn! I went to the local Case dealer here today and they had a similar pin (not exactly the same, but it would have been okay), but the damn things were $19- each!!!!
The ones I've seen on the net are only $3- each.....
Search continues..... hahaha
602618
Follow Up By: Squizzy - Wednesday, Nov 12, 2008 at 15:27
Hey Bill,
Have you tried Rocky River Ag, and Crouch Rural at
Crystal Brook?
Might be worth a try.
Geoff.
602644
Follow Up By: Member - Pesty (SA) - Wednesday, Nov 12, 2008 at 16:32
Send an email to Outandabout David, he is in the tractor spares industry, he would be able to set you in the right direction im sure.
Cheers pesty
602658
