Is LPG availlable out of the major cities?
Submitted: Tuesday, Aug 05, 2003 at 20:29
ThreadID: 6384 Views:2638 Replies:6 FollowUps:3
Hi all,
recently I've bought used 4WD - driving on gas and petrol - without knowing and without being told by the dealer that the petrol tank was made smaller by one of the previous owners. I've thought that I have the double amount of tank volume - 90l petrol and 60l LPG-. Today at the petrol station I realized that the volume of the petrol tank is 45 litres only. My question: Is LPG availlable out of the major cities? Will I have Problems on Fraser, Cape York, Outback etc.?
The problems is that I am from Germany and only here for 9 month, so I don't know the infrastructure concerning gas very well. And does anybody knows whether I have any rights against the dealer?
Thanks a lot
Torsten
Reply By: Member - Willem- Tuesday, Aug 05, 2003 at 20:50
Torsten,
All the major road routes throughout the country will have gas available. Once you leave the main routes you may be hard pressed to find gas outlets. You will have to carry quite a few jerry cans of spare petrol with you. Happy travels.
Cheers, Willem
Never a dull moment
AnswerID: 26874
Reply By: Eric - Tuesday, Aug 05, 2003 at 20:51
you cannot tell the volume of your modified tank by going to the pertol station to fill up unlesds you let it run out completely . Gas is available "almost" everywhere
AnswerID: 26875
Follow Up By: Mick - Tuesday, Aug 05, 2003 at 23:04
Not at Oodnadatta - if you plan to cross the Simpson Desert.
FollowupID: 18424
Reply By: Torsten - Tuesday, Aug 05, 2003 at 21:06
I've let it run out completely and the volume is ca. 48l. This is enough for 320 km on normal roads, but the consumption off road will be much higher. I don't know how far I can go on gas, but when I've bought the car, I thought that the gas bottle could be used as a spare tank.
Is it normal that you have to make the petrol tank smaller, when you build in a gas tank on the bottom of the car?
Thanks a lot for your responses!
btw, this site is great. It's a big help.
AnswerID: 26880
Follow Up By: Eric - Tuesday, Aug 05, 2003 at 21:33
what type of vehicle are we talking about ?? and yes sometimes you do have to cut down tank size . If you can get 320 kms to 48 litres og petrol then you will probably get the same for 60 litres of gas , this is a total of 600 kms + , you can almost get from here to Sydney lol . As the other have said use you patrol and keep gas as reserve .
FollowupID: 18414
Reply By: Member - Glenn(VIC) - Tuesday, Aug 05, 2003 at 22:27
Torsten,
If you are travelling through the desert regions, the Hema Great Desert Tracks maps show the towns with LPG ie you can purchase LPG almost anywhere around Alice Springs, Ayers Rock, Kings Canyon etc. I find the maps extremely helpful when planning trips.Just Do It!
AnswerID: 26892
Reply By: Voxson (Adelaide) - Tuesday, Aug 05, 2003 at 22:44
Hi Torsten, You wont find LPG above cairns, townsville, mossman, but not sure about weipa... When gas is installed into 4x4's, the gas tank goes where the original tank used to be and then a smaller tank is put under one side of the car..... I just drove to cape york and had to carry 3 jerries because of lack of gas up there.....
And these aftermarket petrol tanks are notorious for splitting when punished by the corrigated roads up north so make sure you keep your gas tank full when you get high up about lpg outlets........you may have to rely on it.....
I was puting in 60litres of petrol and getting about 80kms because of the split and there were more than just me with that problem......
If your car still has the copper fill line going to the gas tank from the filler i would suggest you get it changed to the newer flexible type before you leave on such a journey because the copper lines tend the break at the flare.... it is a pain when you have got leaking petrol tank and you finally get to a lpg supplier and you pump the gas straight to the sidewalk.... only costs $45 for the modification......_____________________________________________
AnswerID: 26895
Reply By: bruce - Wednesday, Aug 06, 2003 at 09:49
Gas is available at Cooktown..you will get about 2/3rds or a bit better the mileage out of gas that you get with petrol..or we do in the Falcon towing a 17ft poptop .There was not many places around Oz that we could not get gas...but then we did not go in to the real off road outback places either due to only having 2wd ....cheers
AnswerID: 26914
Follow Up By: flappan - Wednesday, Aug 06, 2003 at 10:28
I posted on the other one as well.
Cooktown is the last stop for Gas.
Its a bloody long way to the Cape, for a 45l Petrol Tank.
FollowupID: 18450
