second battery for 60Ltr engel ?
im looking for a good brand battery for fridge and dont want to waste money buying a battery that doesnt have a long life, but on the otherhand i dont want to brake the credit card !! any suggestions? thanks
Reply By: Maîneÿ (wa) - Wednesday, Dec 03, 2008 at 14:33
If we knew where you lived and what you expect to be a max $$ value, I'm sure you will get plenty of replies.
Remember, one aspect of battery "long life" is their manufacturing technique and quality materials used, the other main aspect is the charging regime you employ.
Mainey . . .
AnswerID: 338035
Follow Up By: xr500 - Wednesday, Dec 03, 2008 at 15:04
sorry bout that !! im from adelaide
FollowupID: 605574
Follow Up By: Cram - Wednesday, Dec 03, 2008 at 18:59
Hi Mainey, I want to buy two batteries for my camper after Christmas. I live in Newcastle I am looking at spending around $600.00. I already have a 120amp hour AGM that I got from TJM not sure of the brand in the rear of the vehicle.
We are basically running a 60litre engel and 12 volt lights. We have a solar panel as well so I am thinking the extra batteries should see me have enough power given the most we usually stop in one place without power is 5 days.
Thanks and sorry to hijack the thread....I guess I should think about becoming a member so I can send direct :)
FollowupID: 605624
Reply By: Geoff (Newcastle, NSW) - Wednesday, Dec 03, 2008 at 15:41
To make any sort of moderately informed recommendation we'd probably need to know a little more about your intended use.
1. Were do you plan to mount the battery?
2. How do you plan to charge it?
3. Do you plan to camp for 1 night or 20 nights straight without charging said battery?
4. What is your budget? If you are Jamie Packer I'd probably suggest something different to if you were on the dole!
5. Do you wish to run anything else besides the Engel off it?
That'll do us for starters!
Geoff
Geoff,
AnswerID: 338046
Follow Up By: xr500 - Wednesday, Dec 03, 2008 at 15:57
mazda bravo 2.6petrol 1995 dualcab,305,000kms, hehe, redarc 100 amp isolator, battery in back tray 5m of 13mm2 cable to the back, 3days without driving car at most and not on the dole but soon could be!!. would like to spend no more than $250 on battery if possible.only running fridge and it has a new compressor in it so running 4.5amp
darren
FollowupID: 605579
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 03, 2008 at 17:12
Hi Darren,
That's something to get the teeth into, first thing that jumps out. Your cable is way too small, far too much voltage drop to have a chance of fully charging the battery in the tray.
This image is a screen grab of a spreadsheet I made up some time back to calculate whether a given cable size is suitable for a given load. In this scenario I've assumed the Bravo has an 80 Amp alternator. Using 13mm2 cable you are losing over 1 volt or 8.3% odd of your charge in the cable alone! (I've also assumed a 5 metre positive and 5 metre negative cable = 10 metre circuit)
Let me know if any of those assumptions are incorrect.
Now, on to your battery.
If we use your number of 4.5Amp and guess that the Engel will run for say 8 hours a day then you'll be pulling 40Ahrs in a 24 hour period. Note: 4.5Amps x 8 hours does equal 36, I added 10% for losses and fudge factor.
So to get three days you'll need 3 x 40 = 120Ahrs of useable power. If we assume a battery charged to 100% of its stated capacity is spent at 50% charged then we need to double that to 240Ahrs!
I don't think you are going to get a 240Ahr battery for $250 unless it gently falls off the back of a truck!
You'll need to carefully monitor the voltage and charge a battery around the 100 - 120Ahr more frequently is my guess. A sealed lead acid Deep Cycle will give you the lowest entry price but will require you keep it well charged and don't let it go below that magic 50% for long perids. (days) You'll have to fix that voltage drop or it won't recharge successfully and it will sulphate and die.
Or look at a supplementary solar array for when you are stationary for longer periods.
I have two 105Ahr AGM's in my troopy running my 110 litre Waeco and get about 2 days if all goes well and the weather isn't real hot. The vehicle was sealed up all weekend last and the fridge had stopped on low voltage around the 36 hour mark. At the moment my only charging method for them is a 25Amp 3-Stage charger so I can pretty safely say they are always returned to 100% when charged.
Hope all this helps,
Geoff
Geoff,
FollowupID: 605593
Follow Up By: garbage - Wednesday, Dec 03, 2008 at 17:23
Is the effect of the voltage drop a bigger or smaller issue if the battery is mounted in the boot rather than in the engine bay?
FollowupID: 605594
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 03, 2008 at 17:51
Basic rule of thumb, the longer the wire the bigger it has to be to combat voltage drop if the volts and amps are constant.
The boot is a long way form the alternator, you'll get more voltage drop.
Geoff
Geoff,
FollowupID: 605601
Follow Up By: garbage - Wednesday, Dec 03, 2008 at 18:18
What would the approximate circuit length be if the cable were to run from the alternator to the boot in a standard stationwagon car? You've allowed for 10m in your spreadsheet which sounds like a lot to me, or are you also counting the cabling that goes from the battery to the auxilary equipment?
FollowupID: 605606
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 03, 2008 at 19:39
I allowed 10 metres which is made up of 5 metres for the positive wire and 5 metres for the negative wire.
The cabling from the battery to the other equipment is entirely seperate.
Geoff
Geoff,
FollowupID: 605637
Reply By: Cram - Wednesday, Dec 03, 2008 at 18:52
You should be able to get a lead acid 105ah deep cycle battery for around $250.00 One brand that I have used is US Batteries you can get them at most of your supplies like Battery World etc...
AnswerID: 338093
Reply By: Member - Norm C (QLD) - Wednesday, Dec 03, 2008 at 19:08
Before you start to panic too much, it might be worth while doing some of your own calculations based on your system. Geoff is absolutely right about the effect of length of cable and conductor cross sectional area, but he has posted (IMO) a worst case scenario.
The formula for calculating voltage drop is:
length of conductor (typically length of wire run x 2) x Current in Amps x .017 / conductor cross section in sq mm.
Another possible calculation for your situation might be
8 meter conductor length x 40 Amps x .017 x 13.5mm sq cable cross section
8 x 40 x .017 / 13.5 equals 0.4 Amps. An acceptable voltage drop in most circumstances.
See how much some changes in assumptions can make.
In my previous vehicle (Hilux), I used 25mm sq cable to battery in back and to battery in CT. In my new vehicle I have used 13.5mm sq (6B&S). While the 25mm cable is clearly better, in practical use, the 13.5mm cable has been adequate in all respects.
Hope this helps.
Norm C
AnswerID: 338097
Follow Up By: Member - Norm C (QLD) - Wednesday, Dec 03, 2008 at 19:11
Oh, and to answer your original question, I reckon you can't go past AGM batteries. A bit more expensive, but worth the money in my view. The cheaper brands (made in China) like Fullriver, Remco etc) are good quality and excellent value for money.
Norm C
FollowupID: 605627
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 03, 2008 at 19:42
Hi Norm,
I think you are right, I did size for worst possible case!
It's easiest in electrical design to assume the worst when only limited information is available then work back from there!
Geoff
Geoff,
FollowupID: 605638
Follow Up By: Cram - Wednesday, Dec 03, 2008 at 19:56
I can relate to that......but I also get baldness watching the Knights.....lol
FollowupID: 605640
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 03, 2008 at 19:59
Hey Marc,
Whereabouts in Newcastle are you?
I'm currently at Shortland.
Geoff
Geoff,
FollowupID: 605641
Follow Up By: Cram - Wednesday, Dec 03, 2008 at 20:00
Hey Geoff, just a stone's throw away mate. I am at Waratah West not far from the uni.
FollowupID: 605642
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 03, 2008 at 20:03
Keep an eye out for the white Troopy with the ExploreOz wheel cover!
Geoff
Geoff,
FollowupID: 605643
Follow Up By: Cram - Wednesday, Dec 03, 2008 at 20:05
Will do. I am in a Series 2 TD5 Disco....southern cross sticker on the left side window....
Where is the best place around newcastle to go for batteries?
FollowupID: 605644
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 03, 2008 at 20:15
Hi Marc,
Give it an hour or so then flick me an email on,
contact_geoff@internode.on.net
Once we make contact on that I'll delete it to annoy the spammers and use my regular email address.
Save driving poor Norm nuts and getting rightly moderated.
Geoff
Geoff,
FollowupID: 605646
Follow Up By: Cram - Wednesday, Dec 03, 2008 at 20:43
Geoff, that email address bounced back to me?
FollowupID: 605647
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 03, 2008 at 21:23
Have a crack now, I just sent an email to mysefl and it worked.
Geoff,
FollowupID: 605652
Follow Up By: RV Powerstream P/L - Thursday, Dec 04, 2008 at 15:11
Geoff posted the worst scenario and Norm C Posted his proven experience with doing the job.
Both are in a way correct correct as the worst scenario covers maximum and can never be a problem.
Alternators are cold rated and the continuous duty would be around 60% so in reality you can work on cable sizing for that load as the alt will only produce maximum output for a short period.
Once the initial cranking battery has recovered from starting the vehicle which is normally only a few minutes the regulator cuts back the charge rate and you may only get a charge that would be covered by Norms sizing of the cable and definately suitable for that purpose.
Most people do not understand voltage drop in DC and have a tendency to underwire everthing and think they are working OK when they are not.
It is better to overcable to be sure than undercable and be sorry.
Ian
FollowupID: 605760
Follow Up By: Axel [ the real one ] - Thursday, Dec 04, 2008 at 15:57
Norm C , have you checked out the price of what WAS the cheaper brands of AGM lately ?? Fullriver + Remco can now not be called cheap or entry level anymore , Same size batt that was $200 5yrs ago is now close to $500.
FollowupID: 605768
Follow Up By: Member - Norm C (QLD) - Thursday, Dec 04, 2008 at 18:17
Whitworths recently had 100 AH Remco AGM for $339. Bias Boating have AGMs (Remco or Amp Tech not sure which as they have pics of both in the catelogue) - 100 AH $369, 120 AH $399.
Price of lead pushed battery prices way up over past couple of years. Lead is now much cheaper, but so is the Aussie $ unfortunately.
Norm C
FollowupID: 605786
Reply By: xr500 - Wednesday, Dec 03, 2008 at 22:38
if the alternater charges 60amps through the small wire to the main battery andthe aux battery is flat, the max current to the battery wouldnt exceed 100amps would it?? if you where trying to jump start from the aux battery it would a huge current draw.... not sure. i originally had 6mm2 cable and when the car was running i had 14.2 v at cranking battery and 13.6 at aux battery. put in 13mm2 and the voltages where exactly the same. redarc in adelaide told me that 13mm2 was min requirement and that is the cable that is supplied with cyclone 100 amp isolators. i will enquire about the AGM batteries.
thanks to all posters too!!
AnswerID: 338140
Follow Up By: xr500 - Wednesday, Dec 03, 2008 at 22:43
i only have 5metre cable on the positive side and grounded on negative.
FollowupID: 605673
