Around OZ..suspension
Submitted: Thursday, Dec 04, 2008 at 13:38
Jock69
Hi all am just planing a 12mnth trip and have a 2002 diesel Prado, could someone please let me know if I need to do anything with the
suspension before I go..as I will be towing about 1300kgs of camper and do plan to go off road..
Reply By: Markymark - Thursday, Dec 04, 2008 at 14:13
We did 6 months in our 1998 Prado towing similar weight to yours, plus home made drawers in the back with recovery gear, fridge etc. We already had medium duty Old Man Emu springs and shockers and loaded up she sank a bit. I had some Polyair bags put in the back and that worked
I did think about sticking in some heavy duty springs instead but now we're back home and driving around relatively empty, I'm glad I didn't do that!
I had a Tregg hitch so couldn't used the weight distribution bars I previously used on our old wind-up camper.
Mark.
338226
Follow Up By: Ozrover - Thursday, Dec 04, 2008 at 16:25
Gerday MM,
Why couldn't you use the ride levels with the treg? I just lopped the dangly bits off the receiver & bolted the lot to the tow bar, this was suggested to me by a caravan repair man in
Broken hill & has worked fine ever since. The ride levels are a PITA but are a necessary evil as far as I am concerned, when going off road I just remove the bars!
605772
Follow Up By: Markymark - Thursday, Dec 04, 2008 at 22:28
Jeff do you have any photos of that? I hadn't thought of chopping bits off one to weld onto another and would like to see how it is done. The reason you mentioned about taking them off is why I left them behind. I wasn't going to take 2 different tow connections to switch between bitumen and off-road.
Mark.
605842
Follow Up By: Ozrover - Friday, Dec 05, 2008 at 08:33
Mark, here are some photos, I didn't bother welding them together they don't move anyway.
Image Could Not Be Found
605865
Follow Up By: Markymark - Friday, Dec 05, 2008 at 09:06
Brilliant, so simple! Now I'm scratching my head thinking "why didn't I think of that?".
Thanks Jeff,
Mark.
605873
Reply By: Jock69 - Thursday, Dec 04, 2008 at 14:16
Tanks mate
338229
Reply By: Markymark - Thursday, Dec 04, 2008 at 14:35
I should add we had 2 kids too, so LOTS of extra stuff! Every nook and cranny was filled in both car and trailer, jerry cans with
fuel and
water, another fridge in trailer...We were self sufficient when needed.
A family member went for 1 month, just him and his partner, in standard Prado towing a trailer from Vic up to the Centre. They mainly stuck to the highway but came home on the
Oodnadatta track and didn't have any worries.
Mark.
338231
Reply By: Member - Mick O (VIC) - Thursday, Dec 04, 2008 at 15:42
I'd definitly look at beefing up your
suspension prior to departing. I did the trip round the block in 06 towing a off road
Tambo camper behind the Navara. Upgrading to
suspension was one of the most sensible things I did. Can reccomend
Ironman products. Great service and products at a very reasonable price compared to many other aftermarket suppliers.
Mick
338242
Reply By: Member - Phil G (SA) - Thursday, Dec 04, 2008 at 16:37
I used to have the same model Prado, and carried lots of extra
fuel and
water, but didn't tow.
I upgraded
the springs, added rear polyairs and kept the factory shocks because they are usually more reliable than the aftermarket shocks on Prados. If yours is 6 years old now, you'd probably want to replace the shocks as
well - they are cheap from Toyota.
338261
Reply By: westskip - Thursday, Dec 04, 2008 at 21:29
Hi Jock
We,ve just got back from a 6 month trip towing a 16' van with a 2001 diesel Prado and had absolutely no trouble. Had air bags installed in the rear springs and even then the back would drop a bit but not too badly considering the amount of gear and
water we were carrying.
Good travelling
338316
