Supreme brand deep cycle batteries. Any good?
Submitted: Wednesday, Dec 10, 2008 at 14:35
ThreadID: 64164 Views:12700 Replies:9 FollowUps:30
Hi, I need to replace the battery in my caravan, as the Delkor sealed lead acid is shot after only 20 months.
I can buy a Supreme 140 AH (sticker on top says Made in USA) for $224, which is cheap for a not made in China battery.
Anyone had any experience with this unit?
Details are: 20 hr rate - 140
5 hr rate - 110
200 RC minutes @ 25 amps
Reply By: Geoff (Newcastle, NSW) - Wednesday, Dec 10, 2008 at 14:53
A quick Google for "Supreme Batteries" turns up they've been around since 1926 so they are either extremely lucky or they make a saleable product.
Look here, Battery Guru
Hope that gives some useful info,
Geoff
Geoff,
AnswerID: 339092
Follow Up By: Geoff (Newcastle, NSW) - Wednesday, Dec 10, 2008 at 14:57
And reading further into Google turns up this article, Supreme's Chinese Factory
Geoff
Geoff,
FollowupID: 606622
Follow Up By: RV Powerstream P/L - Thursday, Dec 11, 2008 at 09:19
Geoff
There may be a difference as that set up is for battery packs and I dont think battery packs applies to vehicles.
Crown is in Ohio and that Supreme is in Georgia but who knows they may be a subsidiary.
Ian
FollowupID: 606727
Reply By: TerraFirma - Wednesday, Dec 10, 2008 at 15:37
Nowdays replacing batteries brings opportunity. Do not chase the same brand you have now, take some measurements and replace it with an AGM battery of the same size. An AGM replacement will give you long service , faster recharge and better overall use. Once you have your dimensions see how big you can go with a suitable AGM, I have seen 135AH AGM's for around $350 and dimensions as follows:
LxWxH etc 341/173/281/287 mm
Thats my philosophy, I have been replacing every battery I own in boats, ride on mowers, camping equip with AGM , mostly Fullriver etc and have never looked back.
AnswerID: 339098
Follow Up By: Axel [ the real one ] - Wednesday, Dec 10, 2008 at 16:15
Would love to know where you can get a 135amp hr AGM for around $350 ,, you wont even get an 80amp hr Fullriver AGM for that $350 nowadays ..
FollowupID: 606627
Follow Up By: TerraFirma - Wednesday, Dec 10, 2008 at 16:31
I just checked and have seen some for $395.00, with some hard searching and negotiations $350 isn't that far away IMHO.
Give or take $45.00 to keep you happy ok, more importantly the investment is well worth it IMHO.
FollowupID: 606630
Follow Up By: Boobook2 - Thursday, Dec 11, 2008 at 07:28
TerraFirma can you please point me to them, I am interested in a large AGM for the trailer.
FollowupID: 606699
Follow Up By: RV Powerstream P/L - Thursday, Dec 11, 2008 at 09:24
Faster charge is not always the case with AGM batteries as it depends on the recombination capacity as the higher the recombination the faster the charge and a lot of the cheaper AGM,s do not have a high combination technology due to the high cost.
Flooded wet cells with a high voltage charge input have the capacity to charge faster than most AGM batteries using smart charging technology and temperature compensation.
Ian
FollowupID: 606730
Follow Up By: RV Powerstream P/L - Thursday, Dec 11, 2008 at 09:42
Ian
FollowupID: 606737
Follow Up By: TerraFirma - Thursday, Dec 11, 2008 at 11:33
Thanks Ian but you can have your wet cell batteries all to yourself.! AGM is a better battery all day everyday.
FollowupID: 606746
Follow Up By: TerraFirma - Thursday, Dec 11, 2008 at 12:03
$339.00 for a Fullriver 120AH HGL120 on Ebay right now, 10 left from a trusted seller. Would seem like very good buying right now, have seen these elsewhere for over $500.00.
http://cgi.ebay.com.au/FULLRIVER-12V-120AH-AGM-DEEP-CYCLE-BATTERY-2yr-Warr_W0QQitemZ290279848634QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item290279848634&_trksid=p3286.c0.m14&_trkparms=66%3A2%7C65%3A1%7C39%3A1%7C240%3A1318
You can jump on ebay and type in 120ah agm battery, there are other oprions also.
FollowupID: 606749
Follow Up By: Boobook2 - Thursday, Dec 11, 2008 at 14:11
Thanks Terrafirma, that is a good price indeed.
FollowupID: 606758
Follow Up By: RV Powerstream P/L - Friday, Dec 12, 2008 at 07:55
All batteries have their application and I do not prefer one against the other I apply the battery to suit the application.
I was merely dispelling a myth.
Flooded wet cell deep cycle have the longest life and the fastest charging time under controlled conditions and in an appropriate application.
Good AGM batteries are hard to beat in most mechanical applications but there are a lot that are not good only makebelieve.
Full River appear to be one of the better lower recombination batteries.
Ian
FollowupID: 606871
Reply By: Shaker - Wednesday, Dec 10, 2008 at 16:40
I have had a Delkor Calcium battery in my camper trailer for over 5 years & certainly haven't looked after it, it has done heaps of High Country & corrugated Outback tracks.
I would have no hestitation in replacing it with the same battery when the time comes.
AnswerID: 339105
Follow Up By: pickle - Wednesday, Dec 10, 2008 at 17:29
Currently testing 27DC36 Lead Acid with 115 AH from Supreme.
Being the Technical Officer for the Pajero Club of Vic I was given one for a long term test.
14 months into the test their has been no problems with the battery.
At this stage they appear to be good value for money.
Dave
FollowupID: 606633
Follow Up By: Maîneÿ (wa) - Thursday, Dec 11, 2008 at 10:06
I used Delkor Calcium (DC27) batteries, however retired them after 6 years, not because they died, but because I was not prepared to risk taking them away for another winter and have them die on me.
Mainey . . .
FollowupID: 606740
Reply By: Warstar - Wednesday, Dec 10, 2008 at 18:09
Thanks guys. I have since been researching on the AGM question and have found that I can buy either "First Start" or "Full River" for just under $400 landed at home. (120AH)
Given the akwardness of servicing the battery in its location in the corner of the boot, I am leaning that way.
Any comments??
AnswerID: 339113
Follow Up By: Axel [ the real one ] - Wednesday, Dec 10, 2008 at 18:46
Fullriver have been around for a fair while , nowadays at $400 for a 120amp hr you are doing well ,,go for it , you wont be dissapointed ,, my Fullriver AGMhgl,s are now 5yrs old and still perform as new.
FollowupID: 606640
Follow Up By: BV - Wednesday, Dec 10, 2008 at 19:14
I understand that you cannot (should not?) mix AGM and lead acid batteries, not even house and starter batteries. Not sure why, but someone may have the explanation.
BruceV
FollowupID: 606644
Follow Up By: RV Powerstream P/L - Thursday, Dec 11, 2008 at 09:15
With normal vehicle alternators it is rarely a problem as the charge rate is not high enough to make much difference.
The problem exists where you have a charger that can charge 14.7V for flooded wet cell and you put in an AGM second battery that is overcharged at 14.7V and is damaged.
I have run a flooded wet cell cranker and an Optima yellow top AGM together for eight years now.
In that time I have used three FWCells to the Yellow top but it is now corroded under the posts and although still holding charge I will lose it with post separation.
Yes you are advised by some not to mix and match batteries but it depends on the specific application.
Ian
FollowupID: 606726
Reply By: Member Boroma 604 - Wednesday, Dec 10, 2008 at 22:50
Gooday,
Put 2/ 145 Amp Supreme Deep Cycle sealed, in our Caravan a few months ago, so far very good, the bloke who handles them here in Bne was very good. Bought direct from YHI wharehouse, not retailer.
Paid approx $365-00, reckon Full River is over priced & Over rated.
Found these blokes when looking for Trojan, bloke in Sydney reckons they dropped Trjoan for these and never been sorry.
Boroma604.
AnswerID: 339165
Follow Up By: Member - Glenn D (NSW) - Wednesday, Dec 10, 2008 at 23:24
Yes have to back you up ,
Recentley got 2 x 105 ah batts for about $400 delivered for my CT .
Saw an 85ah at SuperCrap for $200 .
Even if you are in your van 24/7 why pay double the price for something that does the same thing , its not like its your starting battery, has warranty and everything.
My neighbour has optima's in his CT , I have spent $400 less !
Glenn.
FollowupID: 606685
Reply By: Boobook2 - Thursday, Dec 11, 2008 at 07:31
I put a Supreme 950cca and 140AH in the Landcruiser a year ago. So far so good. I am pretty happy with them.
I did a bit of research. They are not known in Australia because there was a name copyright issue here that was resolved about 18 months ago. Until then they could not be sold here. They are well regarded in the US and made there.
AnswerID: 339174
Reply By: TerraFirma - Thursday, Dec 11, 2008 at 12:05
Fullriver AGM 120AH on Ebay right now for $339 from a trusted seller. Great buying it would seem..
AnswerID: 339202
Follow Up By: Axel [ the real one ] - Thursday, Dec 11, 2008 at 14:12
You do realize the HGL in the Fullriver AGM battery designates that it is NOT a full deep cycle but the hybrid battery .
FollowupID: 606759
Follow Up By: TerraFirma - Thursday, Dec 11, 2008 at 14:30
Yes Axel I realise this, I have 3 of them. I note your use of the word "FULL" deep cycle, in reality Axel the HGL series has been sold as a deep cycle battery by more people than I can count and it works fine. I am aware of all of the Fullriver batteries, if you wish to discuss full vs dedicated deep cycle plse use another forum. The HGL series has been discussed in these forums in hundreds of threads and there are that many people using it as a deep cycle battery just like me. Can we move on now..?
FollowupID: 606763
Follow Up By: Axel [ the real one ] - Thursday, Dec 11, 2008 at 14:53
Thing is unless you specificaly
FollowupID: 606769
Follow Up By: Axel [ the real one ] - Thursday, Dec 11, 2008 at 15:11
Wrong button , Terra you made the statement that a Fullriver AGM 120ah could be sourced for $339 ,, It is not , simple as that .
The designation of hgl with Fullriver gives you a hybrid battery which is priced less accordingly ,, less lead plate thickness ,
big deal you have 3 , I have 6 since 02 used as starter and aux in now the 3rd vehicle + c/t combination .. under bonnet - upside down -laying on side ect ect
FollowupID: 606770
Follow Up By: Member - Mike DID - Thursday, Dec 11, 2008 at 15:14
All AGMs are inherently good at Deep Cycle performance.
If they are to be used for starting, they can be optimised for higher discharge currents without sacrificing much deep cycle performance.
FollowupID: 606771
Follow Up By: TerraFirma - Thursday, Dec 11, 2008 at 15:24
Quote "All AGMs are inherently good at Deep Cycle performance."
Thks Mike, perhaps Axel will take note.
Axel, You don't need to buy the Fullriver DC series unless you are going to be frequently dropping the battery down to 40% capacity. The HGL Hybrid is a good allrounder, I stated you could buy a 120AH Fullriver AGM for $$$ and I'm correct.
Most people buy the HGL series battery because it can crank out 900CCA and also work as a deep cycle battery, yes the DC series is the dedicated DC battery and yes it has thicker plates bla bla bla, horses for courses.
IMHO the HGL120 or bigger would do the job nicely as a replacement for the battery this thread is being discussed. In fact the HGL120 is advertised as a Caravan battery by a number of sellers, humm I wonder why..??
FollowupID: 606772
Follow Up By: Maîneÿ (wa) - Thursday, Dec 11, 2008 at 17:57
I make this comment as a 'distributor' of said battery, I would NOT sell a HGL series to anyone wanting to use it as a storage battery, make of that comment whatever you like.
(no further comment will be made on the subject)
Mainey . . .
FollowupID: 606788
Follow Up By: TerraFirma - Thursday, Dec 11, 2008 at 20:10
Mainey, I hope the fish bite as well as you do cocko..! LOL...
FollowupID: 606811
Follow Up By: Secret Mens Business - Thursday, Dec 11, 2008 at 20:28
I make this comment as a "reseller" of Fullriver batteries. I would sell the HGL as a caravan cycle battery and I have done many a time. The DC series battery is a storage battery designed for frequent charge & discharge cycles also capable of recovering from discharge to below 50% on a regular basis. I do not believe the DC series battery would be necessary in general caravan useage. The HGL is suitable and is promoted as a caravan battery.
Further comment is welcome, however I concur with Terra and Mike and the others who are using the HGL series in this enviroment. The HGL series over 30AH should return a 8-10 year life cycle if maintained with a suitable battery charger in a holiday makers caravan enviroment.
FollowupID: 606816
Follow Up By: Rut Tearer - Thursday, Dec 11, 2008 at 20:39
Yes I would agree with Terra on the suitability of the HGL as a caravan battery, I have 2 in mine. I chose to increase my AH capacity to a total of 240AH (2 x HGL120's).
Often the capacity is not enough and batteries are discharged to an extremely low level on a regular basis, which is not good good for any battery. Increasing the AH capacity is always a good thing if in doubt.
You may need to consider your charger also as recharging a bigger bank in terms of AH capacity is inportant. Sometimes caravan makers cut corners with both battery size and charger to reduce costs. IN the real world having ample capacity and charger to suit is critical.
You may want to analyse your useage Warstar before replacing the battery, 150H to 200AH may be ideal.
FollowupID: 606822
Reply By: TerraFirma - Thursday, Dec 11, 2008 at 21:58
Fullriver HGL & DC Series AGM Pricing from Southside Batteries:
HGL120 AH Fullriver - $335.00 (Hybrid & General Purpose Battery)
DC120-L Fullriver - $365.00 (Deep Cycle Heavy Duty)
http://www.southsidebatteries.com.au/catalogue/fullriver_agm_batteries/fullriver_12v_120ah_agm
Warstar , they also have 180AH Fullriver batteries in HGL & DC Series from $585.00
At the end of the day consider the use of the Caravan, how often, battery draw down % and then your budget. Any of the AGM from Fullriver, First Start and some others would be better than what you had, if your keeping the van and want the best batteries go this way IMHO
AnswerID: 339302
Follow Up By: RV Powerstream P/L - Friday, Dec 12, 2008 at 08:06
Terra and others
What are the PLFT12-100 and the PLFT12-120 Full River or are they.
I have just found them at reasonable prices in Sydney.
Ian
FollowupID: 606873
Follow Up By: RV Powerstream P/L - Friday, Dec 12, 2008 at 16:12
Sorry I stuffed that one up good and proper I read it off the wrong page.
The batteries are the equivalent to Full River and the firm in question only deals with Full River and a firm called Leoch .
The batteries are definately deep cycle and are PLCG 12V 100 and PLCG 12V 135.
Ian
FollowupID: 606932
Reply By: Warstar - Friday, Dec 12, 2008 at 13:15
Thanks for all the input. I have just purchased a Full River DC 120-12 For $315, delivered, so that satisfies me.
I have an "Electro BC-1215" charger. For that battery, I presume the charger gets set to "wet" from the choice of "Gel/Wet/Calcium"?
Also set to "13.2V" from the float voltage choice of "13.2v/13.5v/13.8v" ?
Thanks again for all the input.
AnswerID: 339386
Follow Up By: Warstar - Friday, Dec 12, 2008 at 13:46
Sorry guys, Further info. I have just been reading the battery specs and it appears that float charge should be set to 13.8V.
Further the manual on the charger in discussing the battery type selection states to select :-
"GEL": for "sealed type(VRLA),Gel, Maintenance free, automotive or deep cycle lead acid batteries" which I guess covers the Full River DC series?
FollowupID: 606921
