A bit of innovation - An adjustable mount for HF Antenna
Submitted: Saturday, Dec 13, 2008 at 22:12
ThreadID: 64244 Views:5364 Replies:3 FollowUps:3
I bought a Barrett 950 HF radio with an 910 Auto-tune antenna a few months back from a chap up Sydney way. I wanted to mount the Antenna at the rear of the Patrol as anything up the front takes a fair pounding on my trips. The problem I had was that I use an ARB Roof Top Taj (tent) mounted crossways across the rear of the car on a normal ARB Roof rack. This means it sits about 50mm past the gutters on either side of the vehicle and folds open to the rear.
The problem being that when the tent is packed away, the antenna sits clearly at the back, when it’s open, the antenna can’t be used as it wouldn’t clear the rear or side of the tent.
SOLUTION: Did some thinking, got some photo’s from Exploroz members with various type HF mounts and then went down to Brown-Davis in Bayswater and had a chat. The end result is a very solid mount that telescopes outwards to the right to allow clearance from the tent. It has a locating pin that seats into holes in the interior, sliding tube and two tightening keys to lock the sliding bar and prevent any sort of movement. Kevin has done a great job. I’ve thrown a few photo’s up on the profile page for those who are interested.
Thanks to those who sent me photo's and emails of their Antenna mounts.
Cheers Mick
Image Could Not Be Found Image Could Not Be Found
Reply By: Member - Footloose - Saturday, Dec 13, 2008 at 22:43
Mick, that's a serious bit of engineering. I like it.
AnswerID: 339581
Follow Up By: Member - Mick O (VIC) - Sunday, Dec 14, 2008 at 09:43
Fit for purpose Footy. Just wish I was handy enough with steel and a welder myself.
Cheers Mick
FollowupID: 607160
Reply By: Member - Stephen L (SA) - Saturday, Dec 13, 2008 at 22:46
Hi Mick
You must be getting soft. What's wrong with the good old fashioned swag on the ground?
ps. The mount that they made up looks great.
AnswerID: 339582
Follow Up By: Member - Mick O (VIC) - Sunday, Dec 14, 2008 at 09:42
Some may call it soft Stephen, I reckon it's just adding a degree of sophistication (Ha). After reading Uncle's blog on the snake and the swag, the roof top taj will be the domicile of choice till the new trailer/caravan arrives.
Cheers Mick
FollowupID: 607159
Reply By: Member - Phil G (SA) - Sunday, Dec 14, 2008 at 12:18
Mick,
You'll find that it will transmit better when its a bit further away from the body too. I made an adjustable mount for mine too so it can be elevated to get the necessary clearance from my canopy.
AnswerID: 339653
Follow Up By: Member - Mick O (VIC) - Sunday, Dec 14, 2008 at 16:26
Hi Phil and thanks for that. I'm having the Barrett installed in the new year. It's all very new to me so I'll enjoy learning about it before next years trip. I was very keen to know a bit more about the electric bug antenna, the "Super Rod" I think it was called and I believe you have used one. Will send you a MM about it.
Regards Mick
FollowupID: 607207
