Saturday, Jan 10, 2009 at 09:35
Nikkilinks,
You ask-> " if I want to disconnect from city power to use a
solar power system with all the regular comforts but can't afford to spend a ton .... what can I do and what do I need "
If I understand you want to power your 'urban residence' I'm sure you will get no change from $16k, but even then it may not be possible to run all the products you use now anyway, because some will be extreme power guzzlers, as manufacturers in past years didn't make their products capable of running *efficiently* on
Solar power.
Another problem you may have in the 'city' is the (lack of) area capable of placing the solar panels to gain optimum sunshine hours with-out shade and therefore performance from the panels is limited.
However, if you can specify the actual power consumption figures for each of your present electrical products, the system requirements you will require to run them can then be worked out !
Mainey . . .
611362
