LandCruiser 76 Series Long range fuel tank.
Submitted: Saturday, Dec 20, 2008 at 19:54
Foxhound (WA)
I have had a 166 L long range
fuel tank fitted to the new 76 Series. At 400K the
fuel gauge started to move down, at 1200K the low
fuel light came on but the gauge showed just under a quarter,I made it home with the odometer showing 1250K. Next day I removed the
fuel sender unit from the
tank and measured the
fuel left in the
tank it measured 80mm on a stick.Considering the size of the
tank I would say I would have about 40 L left at least. Having had a look at the float and low
fuel sensor it appears I need to extend the length of the low
fuel sensor to keep it down in the
fuel. To do this I will have to cut and lengthen the wire to sensor as
well as lengthen the wire stalk it hangs on. The wire is a special type so not sure I can solder it. Has anyone with this problem sorted it out? would appreciate some ideas on it. Regards,,Foxhound.
Reply By: Rossco td105 - Saturday, Dec 20, 2008 at 21:35
G'day there,
Who fitted the
tank? When
mine was installed the wire attached to the float was modified as part of the install (As IMHO it should be when having a long range
tank fitted). I'm sure I have seen an article on the web somewhere on how to do this job, if you don't have any luck with the installer.
Hope you get it sorted,
Ross.
340678
Follow Up By: Foxhound (WA) - Sunday, Dec 21, 2008 at 10:28
Rossco,,,,The
tank was fitted by the local ARB people and in their opinion no modification to the gauge was required when I spoke to them about it. However that dosn`t seem to be the case to me with the light coming on at 1/4 full. The gauge seems to be reading reasonable correct apart from it not moving for the first 400K but that is OK by me. The
fuel light is on a separate stem from the float and just needs to be lowered,a simple adjustment as the sender is easy to get at. I am a mechanic and have all the gear to do the job, its just the lengthening of the wire and the type of material it`s made of I am concerned about, don`t want to stuff up a new sender. Regards Foxhound.
608389
Reply By: PatrolSTL04 - Sunday, Dec 21, 2008 at 00:44
G'day Foxhound,
I put a larger sub
tank in the Patrol, and had to cut the rigid wire to the float, and insert 75mm of bungy pipe, then braze. Solder will not hold it together, unless the extension will allow the original wire to slide in both ends.
Good Luck.
Brett......
340704
Follow Up By: Foxhound (WA) - Sunday, Dec 21, 2008 at 10:33
G`Day Patrol,,,As above the float is OK it`s the low
fuel sender that`s the problem. You are right with the solder,I would silver solder the ridged stem,have oxy etc to do that. Regards ,Foxhound.
608390
