strange front tyre wear
Submitted: Tuesday, Dec 23, 2008 at 10:21
ThreadID: 64506 Views:5886 Replies:11 FollowUps:8
Hi everyone,
firstly Merry Xmas!!
My GQ patrol has developed strange wear on the front tyres. Ive got Goodyear MTR's that have done 60,000Kms - still plenty of tread on them. the outside of the trye is wearing much more than the innerside of the tyre, and there is a fair amount of unevenness in the wear on the outer lugs in that every second one is wearing more. the rears are wearing evenly.
I dont have any shake/shimmer/or vibration in the steering wheel when driving to indicate something is out of balance.
Does the wear indicate Ive got a front suspension issue? the car has ARB springs on it so that adds a 2.5 inch lift (I think).
Im going to rotate the tyres to help even the wear out, but does anyone know what causes this wear profife to occur?
many thanks for any advise.
regards
Bryan
Reply By: pepper2 - Tuesday, Dec 23, 2008 at 10:36
suggest front wheels are towed in and also shocks could be worn
AnswerID: 341025
Follow Up By: kev.h - Tuesday, Dec 23, 2008 at 12:16
Any more than 2" lift affects the caster angles and can cause that type of wear suggest a wheel alignment by someone who has experience with lifted 4wds
Kev
FollowupID: 608717
Reply By: Member - Footloose - Tuesday, Dec 23, 2008 at 10:36
Tyre pressure too high ?
AnswerID: 341026
Reply By: Member - Mick O (VIC) - Tuesday, Dec 23, 2008 at 10:37
Possible a shocker issue as outlined above. There was a very similar post within the last 2 months. Will try and find it.
Mick
AnswerID: 341027
Follow Up By: Member - Mick O (VIC) - Tuesday, Dec 23, 2008 at 10:40
Found it. Post 63790.HERE is the link.
Mick
FollowupID: 608694
Reply By: Bryan (WA) - Tuesday, Dec 23, 2008 at 10:41
I hope its not a shockie issue - I only replaced the old OME ones and put on Koni's maybe 2 years ago :-(
I did a bit more searching on the web and found it is most likely linked to the camber angle - which I guess would change when I put on the longer ARB springs many years ago.. I do recall the BFG's I had on previously wore more on the outside, but not as much as the MTR's are.
AnswerID: 341030
Reply By: handy - Tuesday, Dec 23, 2008 at 11:25
had the same dramas with wrangler mtr but on the inside.
an alignment soon sorted the trouble out . that was on my GQ
AnswerID: 341033
Follow Up By: Bryan (WA) - Tuesday, Dec 23, 2008 at 11:37
Thanks Handy,
I think I'll go get it re-alligned to be on the safe side.
FollowupID: 608709
Follow Up By: handy - Tuesday, Dec 23, 2008 at 11:41
its worth the effort, i noticed mine had worn after only doing a 2000 km trip. It was aligned when they put the new tyres on but was done by a kid i found out . cheers
FollowupID: 608711
Reply By: ross - Tuesday, Dec 23, 2008 at 11:40
Your tyres have "scalloping". Its normal for tyres with an aggressive mud terrain pattern on the front end.
My tyre dealer talked me out of M/T for that very reason
AnswerID: 341037
Follow Up By: handy - Tuesday, Dec 23, 2008 at 11:43
mine hasnt done it since aligned properly after 17000 kms
FollowupID: 608712
Reply By: Member - Dennis F (WA) - Tuesday, Dec 23, 2008 at 11:44
I have a similar issue with my MTRs on my GU.The wear is not on the edges but there is uneven wear on the tread.Some blocks are worn while blocks next to them are not.Shock absorbers are in very good condition.people i ask cant work it out.
AnswerID: 341039
Follow Up By: Bryan (WA) - Tuesday, Dec 23, 2008 at 14:12
HI Dennis,
thats what I have happening :-(
I was just at my local 4x4 shop and asked them, they also mentioned to chack my wheel bearings are tight....
I havent checked them in ages, so thats now also on my list of things to do...
FollowupID: 608750
Reply By: Member - Duncs - Tuesday, Dec 23, 2008 at 15:40
Rotate, Rotate, Rotate.
After many years I found a tyre guy I trust. He explained to me the value of rotating tyres. I tried it 'cause I trust him, I trust him 'cause he's right.
I have always thought that if my tyres wear out unevenly fronts wear quicker than rear or vice versa I would only be buying two tyres at a time.
The tyre guy I trust explained to me how that theory is OK on a road car with light tyres and well maintained suspension that never really works too hard. Once you increase the weight of the wheels and tyres the wear on the front particularly will be very uneven and can lead to an out of balance situation. The longer you leave it the worse it gets.
By rotating tyres, front to back, you square off the tyres that were worn unevenly on the front and they last more than twice as long. So I now rotate and I get the results I was promised.
Of course if you are already rotating your tyres regularly, then I haven't got a clue.
Merry Christmas
Duncs
AnswerID: 341072
Follow Up By: Richard Kovac - Tuesday, Dec 23, 2008 at 22:28
Duncs
I'm with you, I have mine done every 10,000 Km and add the spares in so do a 6 wheel rotation.
I have no problem with un even tyre wear because they all wear out at around 45-50000Km .. :-)
Richard
FollowupID: 608851
Reply By: trainslux - Tuesday, Dec 23, 2008 at 16:49
With larger tread blocks, you can get tread movement, which is normal, and often can look like incorrect toe adjustment.
Best bet is to ensure wheel align is ok, tyre pressures are ok, shocks doing their job, (usually the scolloping with shocks worn is larger than just one tread block as you have mentioned), and rotate them side to side to reverse the rotation.
then put them to the rear.
this will even up the blocks, and even out the wear.
But once you have worn your tyres, they will contunue to wear unevenly, rotating them prolongs their life, and allows for them all to wear at an even rate.
Trains
AnswerID: 341093
Reply By: StormyKnight - Tuesday, Dec 23, 2008 at 18:29
Interesting, my previous tyres (Cooper ST's) had this issue on my Prado. My current tyres BFG MT's do not....
I rotate every 5000km & the MT's tyres are currently @ 55,000km without issue.
Sadly it may be due to 98% highway use & very few roundabouts....
AnswerID: 341115
Follow Up By: trainslux - Tuesday, Dec 23, 2008 at 19:39
Which goes to show its most likely a tyre issue, and not from the vehicle.
The way a car is driven will also have a large bearing on how the tyres wear, but all things being equal, this type of tread block wear is just due to the tyre and how it behaves.
Pressures can help it a bit.
have any of you noticed that with tractor tyres, with the large bar tread, have this wear pattern too if there run on bitumen instead of just dirt/ rock.
Trains
FollowupID: 608812
Reply By: Bryan (WA) - Tuesday, Dec 23, 2008 at 21:53
Thanks everyone for your advise - it has certainly helped with things I need to do.
regards
bryan
AnswerID: 341149
