Best Mobile broadband for me?
Submitted: Saturday, Dec 27, 2008 at 19:45
ThreadID: 64594 Views:4220 Replies:9 FollowUps:15
Hi. I have Bigpond ADSL at home, a Telstra home phone a/c and a Telstra prepaid mobile phone a/c.
We travel about 15 to 20 weeks of the year and have a laptop which we take with us. When using the van we normally camp away from towns but do not go "deep outback" - the desert routes and the like. For Example in 2009 we will leave Melb tour up outback NSW to Mnt Isa. the into NT, Cape Crawford to Darwin, then thru the Kimberley staying at places other than Broome, into the Pilbara, and eventually south to camp the Nullarbor, and back to Vic.
I have enquired of bigpond and find that I can go to a 1 Gb plan for 3 years for an all up cost of $2876 for 3 years ,inclusive of my home phone. I would need to change my Email address (painful!) and use the "express card" to get coverage in the more remote areas. This is a nuisance as I do not have an appropriate slot on my desktop, which presumably means buying an USB attached card reader?
If one wants good coverage, is there any real alternative to this plan. Would I also need some sort of external aerial?
Reply By: Member - Matt & Caz H (QLD) - Saturday, Dec 27, 2008 at 19:49
We have the Telstra 3G mobile card and find it works really well, yes its expensive we are on the 3GB plan we don't need an external aerial in fact I sometimes get the internet but no mobile coverage (my mobile is about 2yr old). From what I have learnt Telstra has the best coverage. Yes you will need a USB attachment
AnswerID: 341526
Reply By: Member - Rod N (QLD) - Saturday, Dec 27, 2008 at 20:01
If you type broadband in the site search box, top right, and hover over forum threads you will get a lot of info that has been posted recently.
AnswerID: 341528
Reply By: Notso - Saturday, Dec 27, 2008 at 20:30
You could always use a Next G mobile phone with a data pack, Attach to the puter with USB Cable.
Data packs aren't that cheap but it depends how much browsing you want to do.
AnswerID: 341531
Reply By: Bat30 - Saturday, Dec 27, 2008 at 20:38
HI having travelled for 3 years Telstra is the only one for computer and mobile phones ,you have to pay that the way things are.
AnswerID: 341533
Reply By: toyotabits.com - Saturday, Dec 27, 2008 at 20:39
Hello, telstra now have a prepaid usb antennae prepaid for $149 startup kit, then minimum $10 per month, no carry over at month end, you can increase extra data if you need more - once again end of month no carry over, so for minimum of $10 month not bad value prepaid no extras, you can plug it into your desktop &/or your laptop, 3G, pretty good coverage every where, regards
AnswerID: 341534
Follow Up By: Member - Andrew (QLD) - Saturday, Dec 27, 2008 at 23:29
Where do you see this $10 per month deal??? The deals as listed on http://www.telstra.com.au/specialoffers/prepaidwireless/index.html start at $20.
Andrew
FollowupID: 609209
Follow Up By: Richard W (NSW) - Sunday, Dec 28, 2008 at 09:25
I'm on the $10/150mb a month plan.
Can be found here:
Data Packs
This is on a plan though.
Use the LGTU500 with the old CDMA arial as a bluetooth modem to the computer. Works OK in range of a cell.
FollowupID: 609237
Follow Up By: Sand Man (SA) - Monday, Dec 29, 2008 at 10:01
Richard,
I'm using a data pack option at present on my NextG phone because the bloody Telstra Home Line has a fault on it and I cant get my normal ADSL link.
Do you get notification on your phone when you are nearing your Data Pack limit?
Bill
Bill
FollowupID: 609360
Follow Up By: Richard W (NSW) - Monday, Dec 29, 2008 at 10:08
Bill,
Don't think so and the data usage snapshot is pretty useless as there seems to be a huge lag. The increase from 20mb to 150mb/month for $10 suits me.
FollowupID: 609361
Follow Up By: Member - Andrew (QLD) - Monday, Dec 29, 2008 at 10:26
Under the "Data Usage Snapshot" area (which goes to "My Account" on my phone), there is a selection called "Usage Notice" which when activated on that page states the following:
Your Usage Notice is turned on. To turn off your Usage Notice, simply click the "Turn Off Notice" link below. You will receive an initial SMS Usage Notice when My Data Usage estimates that you have reached 80% of your included data pack allowance, and a second SMS when you have used 100% of your included data allowance. You will not be charged for these Usage Notices.
Andrew
FollowupID: 609362
Follow Up By: Richard W (NSW) - Monday, Dec 29, 2008 at 14:49
Andrew,
Thanks. Will activate it.
FollowupID: 609387
Reply By: Member - Graham H (QLD) - Saturday, Dec 27, 2008 at 20:41
You can buy a Telstra USB modem for $199 and get a casual plan browsing pack 1 gig $59 5 gig $89 and u can drop it down to $5 a month when not travelling Is cheaper than using your mobile and much more flexible as there is no fixed term
AnswerID: 341535
Reply By: Member - Norm C (QLD) - Saturday, Dec 27, 2008 at 20:44
For travel like you do (15 to 20 weeks per year), I believe the best option is Telstra data packs using the phone as modem. No contract required. You need a Next G phone and phone plan. Just ring Telstra and tell them you want a data pack of x size attached to your phone.
Load the software that came with the phone and connect the data cable from phone to USB on laptop. Works a treat.
When you return from the trip, ring Telstra and and tell them to remove the data pack. They will credit you back for any unused portion of the current month.
The monthly cost is much the same as the contract plans with Telstra or Bigpond, but no need for a modem and most important, no contract. You only pay when you need it. I think you can currently get 5 GB for about $89 per month. There are other bigger and smaller plans available.
We have used this system very effectively with a Samsung A412 or A411 phone connected to a 10db external antenna and have had internet access in some surprising places.
If you go to a Telstra shop, they may try to sell you a 3 year contract plan with modem as that is what they are instructed to do(more income, higher sales commission). But rest assured, the data pack on the Next G phone (no modem and no contract) is available and works very well.
Norm C
AnswerID: 341536
Follow Up By: P7OFFROAD Accredited Driver Training - Sunday, Dec 28, 2008 at 10:34
This is what we do.
It works a treat.
After returning from our trip I called Telstra to have the 3GB plan dropped back to my ormal 150mb plan. The salesperson (they are all salespeople) then tried to sell me a data pack and modem, on a contract.
I asked him to explain how that could possibly be cheaper or better than the way that I currently do it. He couldn;t, and agreed that using your phone with data pack is the bext option in my circumstance.
if you text "use" to 176, you will get a SMS telling you what usage % and mb you have in the current billing cycle (handy for making sure that you don;t go over)- this is more up to date than the telstra usage meter (apparently)
Dave
FollowupID: 609246
Reply By: robertbruce - Saturday, Dec 27, 2008 at 22:23
The New 720 Gateway Modem is the go but you must get it through bigpond...im often out of phone range but can just get some bytes through.
There are a lot of compaints about telstra mobile wireless broadband service where-as telstra bigpond services dont seem to attract many....
I know, I know same company... but they connect you through differant billing servers and through a usb dongle... The external aerial for the usb dongles are uslelss, less than 5db....this has a dramatic outcome on your service delivery...phones and thier bits are fiddly little things too
go the modem, make sure you can connect and enjoy the ease of experience...
AnswerID: 341543
Reply By: Member - Doug T (NT) - Saturday, Dec 27, 2008 at 23:57
Warstar
DO not take the 3 year contract, , with that your trapped for 3 years, much better to buy the modem outright and go 1 year , at end of that year it just rolls along but you then have the option of cancellation at your leisure, Also don't get caught out with the useless bloody Telstra Wireless modem on prepaid, If I had that last month my internet cost would have been over $18000 for 9000 + MB of downloads at $2.00 per MB , in other words .....do your homework,
AnswerID: 341549
Follow Up By: Member - Andrew (QLD) - Sunday, Dec 28, 2008 at 00:52
huh? how could "pre-paid" charge you $18000 without your approval? The most expensive rate seems to be 13.3c per MB, not $2! Wireless pre-paid is not the same rates as Pay-As-You-Go.
Not as many people download 9GB via wireless broadband speeds... :-) Whilst the data packs might be cheaper based on a fixed usage, it really depends on an individuals usage and expectations. Sometimes the knowledge that you will not be charged any excess is reassuring and it only takes a couple minutes to recharge the SIM account, thereby resetting the 1 month period. Are you able to do that with those accounts Doug? If so, i might just move across to them. (I am in a situation where i don't want to be caught out during a month with no access or very expensive access, therefore the prepaid is ideal)
I use the prepaid Next-G SIM (set up for WBB) and WWAN card installed permanently in my laptop and it is great for everything i need. To say that it is bloody useless is misleading.
Andrew
FollowupID: 609214
Follow Up By: Member - Doug T (NT) - Sunday, Dec 28, 2008 at 00:56
Read what I typed.... the rate for Telstra Pre-Paid Wireless is $2.00 per MB download, Now I used the word ...IF , meaning IF I had Telstra Prepaid for the 9000 plus MBs I download / uploaded last month would have therefore cost $18,000 plus ....Does make sense now.
FollowupID: 609215
Follow Up By: Member - Andrew (QLD) - Sunday, Dec 28, 2008 at 01:01
I did Doug thanks...hence my statements.
Where does it say $2/Mb for "pre-paid wireless" ? i'm not seeing that anywhere.
Andrew
FollowupID: 609217
Follow Up By: Member - Doug T (NT) - Sunday, Dec 28, 2008 at 01:16
Andrew
Yeh.... It's a bloody hard one to find , anyhow 2 blokes here in the C/park got caught, 1 has since gone over to Bigpond, the other one ... well I tried to warn him but he didn't listen and went and got talked into one of Telstra's little USB modems too, It's pitifully slow , total waste of money.
Image Could Not Be Found
FollowupID: 609218
Follow Up By: Fiona & Paul - Sunday, Dec 28, 2008 at 09:16
G'day Doug, Andrew & Warstar
As I have found out Telstra and Bigpond are two different companies, each in direct competition with the other and this is where they trick us all up with wording of their contracts. I would agree with Doug T and say don't under any circumstances go on a 3 year contract as the market is too volatile.
The advertised data-rate for Pre-Paid Wireless is 13.3c per MB or part of, giving a 150MB DL allowance for the period. If I do a $50 top up of my account then for that period I the data-rate if 8c per MB with 650MB allowance. For $80 it is data-rate of 2.25c and 3.5GB, then for the daddy of em all ifyou pay $100 the data-rate is 1.65c with 6GB allowance.
I have been testing this stuff for about 3 months now by trial and error to see how much it will cost to do certain jobs when in the bush and this is what I have found;
Original cost of USB Modem $149 - I only have to charge it up once in any period of 12 months to keep it going;
My major use is to check emails and maintain three websites;
Second major use is ExplorOZ which is only an issue when I am looking at photographs within posts;
I do not intentionally DL anything when I'm on the road camping remotely, but obviously that does have to happen and I upsize my recharge to accommodate that period;
If the Telstra USB modem was going to cost me more than $300-400 in any year then I will not continue with it. The fact that I can't use Skype with this modem is an issue at this time, but I will develop a work-around for that one also, probably by buying another modem as Skype is brilliant at talking with people across the globe.
I can see Doug's point about $2 per MB and as Andrew has pointed out it isn't documented anywhere obvious. I am pretty sure the Pay-as-you-Go plan is a Bigpond service and I don't want to pay for anything I can't use, so when I did a $5 recharge for my Xmas Day testing while Fiona and I went bush for a few hours I had $12.37 to use which I blew away in 2 minutes as I DL my email (3 items with measured attachments).
I do have to look at the NextG data pack's next, but for now the pre-paid wireless from Telstra is OK for me, BUT, it can be very expensive as Doug pointed out. I have spent an hour or more on ExplorOZ with little impact on $9 balance but the minute I checked on someone's trip photos it gets eaten into pretty quick.
Happy New Year to all
Regards Paul & Fiona
Paul H
OZ Downunder
FollowupID: 609236
Follow Up By: Member - Andrew (QLD) - Sunday, Dec 28, 2008 at 09:43
Just be aware that this Pay-as-you-go "plan" is NOT pre-paid wireless per se......two completely different kettle of fish. It is not advertised everywhere because it is not an excess usage fee, rather a seperate plan for those that are either rich or don't use the connection very much, if at all :-)
To tarnish the pre-paid wireless setup with this $2/Mb charge theory is wrong. It is one of the pitfalls of "plans" as it is a plan concept only. You cannot be overcharged with pre-paid wireless unless there is something i am missing.
BTW the $100/6Gig pre-paid is very comparible to the $119/9Gig and $89/5Gig data plans, for those needing that much quota. The only low-usage plan seems to be $29.95 for 200Mb, which is the equivalent ($30) pre-paid value gives you 225Mb......seems to be better IMO. :-) The pre-paid plans seem to fit in roughly to the post-paid plans values, with the added benefit of being able to top up/upgrade at short notice (5 minutes for my last upgrade).
Any idea why you can't use skype with your USB modem P&F? I have no problem using the equivalent of the 880 USB modem.
FollowupID: 609241
Follow Up By: Member - Andrew (QLD) - Sunday, Dec 28, 2008 at 09:49
I should say that i missed the low usage mobile datapacks (as pointed out by Richard W) which might be suitable for those on a mobile plan.
Andrew
FollowupID: 609242
Follow Up By: Fiona & Paul - Sunday, Dec 28, 2008 at 10:47
Just a Tetstra thing with the wireless modem, there will probably be a work-around but haven't got to that part yet.
I've got virtually 'unlimited' download options at home and the only thing I do with that is regular upgrades for my software library of tools and checking out photography sites, etc, on the web. When I'm in the bush it's to relax and get more images.
Paul & Fiona
Paul H
OZ Downunder
FollowupID: 609252
