Oziexplorer and Bluetooth GPS
Submitted: Wednesday, Mar 18, 2009 at 22:07
ThreadID: 66956 Views:3470 Replies:7 FollowUps:2
I'm trying to get oziexplorer working on my laptop with a bluetooth gps.
But seem to be having issues, the buetooth works fine with copliot but oziexplorer doesn't seem to show any satelites etc.
It's a GTOP model, just wondering if anyone has got OZI to work with a bluetooth GPS and if so what you did.
Neil
Reply By: Sand Man (SA) - Wednesday, Mar 18, 2009 at 22:41
Firstly you need to configure OziExplorer to recognise the GPS input as NMEA only.
Secondly, make sure CoPilot is not activated first.
A GPS input to a Laptop can only have a single output in a normal configuration.
If you wish the GPS to be shared with two or more applications concurrently, such as OziExplorer and CoPilot, you will need to purchase and install GpsGate from Franson.
This little application creates a virtual output port that can be shared with multiple applications.
Franson GpsGate
Bill
Bill
AnswerID: 354790
Reply By: richard - Wednesday, Mar 18, 2009 at 23:34
Check the baud rates - I am unsure hwat ya need but go to the Ozi site I believe they have info on it.
There are also some Ozi forums or used to be which may be able to help you
Richard
AnswerID: 354802
Reply By: Zebra400 - Thursday, Mar 19, 2009 at 05:04
Neil
What COM port have you set? Co-pilot will probably automatically hunt for the right COM port, but Ozi wont. Ozi's default is COM1 but bluetooth will not operate on COM 1.
Laurie
AnswerID: 354815
Reply By: Member - Andrew (QLD) - Thursday, Mar 19, 2009 at 12:08
Are you using Copilot for PocketPC or the laptop version? This will make a difference to which way you approach the BT connection issue.
Subject to the BT device being paired to the laptop, OziExplorer will need the following:
NMEA baud rate: 38400
com port: (BT specific allocation)
Parity: None
Stop bits: 8
Andrew
AnswerID: 354882
Follow Up By: Member - Andrew (QLD) - Thursday, Mar 19, 2009 at 12:09
Make that Stop bits: 1 (brain not connected to fingers)
Andrew
FollowupID: 622960
Reply By: wicket - Thursday, Mar 19, 2009 at 12:37
i am using garmin Bluetooth so the settings might be a bit different . go the COM tab of the configuration seetings and try;
com port:4
up/dowm baud:9600
nmea bands:4800
serial port driver:driver2
initially the setting up hassle wasn't with oze but the bluetooth software, took a lot of trial and error before i got it right..
AnswerID: 354893
Follow Up By: wicket - Thursday, Mar 19, 2009 at 12:39
but try all of the above first.
FollowupID: 622964
Reply By: bgreeni - Thursday, Mar 19, 2009 at 12:39
There is a program on the OziE web site utilities page that will search for the GPS and tell you the port and baud rate to use.
AnswerID: 354894
Reply By: Neil_surf - Thursday, Mar 19, 2009 at 20:09
Thanks all,
I used the utility to find the GPS.
Neil
AnswerID: 354982
