Where are the best deals for parabolic suspension kits for a Troopy?
Submitted: Monday, Mar 23, 2009 at 17:43
Member - Boo Boo (NSW)
I have been doing a bit of research on
suspension kits for the troopy and it appears that I need the above kit and longer shocks and I should notice a much more comfortable ride.
My thanks go to William H (WA) for his help and contacts.
I will be home in the Hunter Valley just after
Easter and considering I have trouble putting a nut and bolt together I will need to get them supplied and fitted.
Anywhere on the Central Coast,
Newcastle or
Sydney would be ok.
I have read the archived threads and presume that most kits seem ok except for ironman , which had a lot of different opinions.
Any updates on the various kits would be helpful.
Regards BooBoo
Reply By: Kanga1 - Monday, Mar 23, 2009 at 20:24
Hey Boo Boo, I had some APM Parabolic 3 leaf fitted to the rear and King coils on the front with Koni Shocks all round, on my 78 Troopy, in September last year, by a Company in WA called Wilkinson Suspensions, very professional crowd, they only do
suspension and have been around for eons. So far so good, a bit more comfortable when the car is unloaded, markedly more comfortable when loaded, they are more compliant when crossing the axles up in rough country, about $2600 for the lot fitted with greasable pins on the rear, the car came up about 65mm front and 70mm in the rear from the OEM gear fitted by Toyota. Cheers, Kanga1.
355752
Follow Up By: Member - Boo Boo (NSW) - Monday, Mar 23, 2009 at 21:59
Thanks for the info Kanga1, but I am hoping that some one in
sydney will come good or I'll have to hit the phone.
623777
Follow Up By: Member - William H (WA) - Monday, Mar 23, 2009 at 22:14
Good evening Kanga1
What is the phone number for the
suspension place please, i need to sort out some springs for my tojo, and shocks as
Good evening Boo Boo.
Cheers for now...William H...Bunbury...WA.
623782
Follow Up By: Kanga1 - Tuesday, Mar 24, 2009 at 00:46
Hi William, Wilkinsons Suspensions phone # is 9370 2646, they are up in Bayswater, and the head Sharang is Peter Wilkinson, cheers, good luck with the Eastern suburbs spring hunt Boo Boo. Kanga1.
623797
