Thursday, Apr 30, 2009 at 20:07
Lionel,
Nitrogen is becoming more common now due to the following benefits according to Jax tyre company.
1. Stable Tyre Pressure
2. Better Grip
3. Safer in all weather conditions
4. Less frequent pressure checks
5. Increased
fuel economy
6. Zero internal oxidisation through elimination of moisture
7. Increased tyre life
Refer to their web site for more details:
Nitrogen in Tyres
If you look at the valve caps on parked cars you may see some red ones - that is the international standard for tyres containing Nitrogen. We had a Lexus ES300 years ago with Nitrogen in the tyres - I dont think we had to pump up the tyres the whole time we had it - they just seemed to maintain the right pressure.
One of the problems with using normal air is that most likely it os of poor quality (ie not perfectly dry). How many service stations or even tyre outlets would service their compressors frequently to remove
water. Probably very few. The fact is the quality of air we put in our tyres is probably very poor and varies significantly between inflation points. The quality of air directly effects tyre performance.
A rubber tyre is like a membrane, through which air permeates As a result, the air slowly leaks out through the rubber walls, which leads to under-inflation. The rate of this loss can vary between tyres (even on the same vehicle). As we know underinflation can contribute to increased tyre wear and vehicle performance. In addition if the compressed air contains high levels of moisture this not only effects the maintenance of tyre pressure but can also accelerate the corrosion of the tyre rim (with repercussions later on).
More significantly the higher the moisture content in a tyre's air chamber, the greater the pressure build-up as a tyre increases in temperature. In other words one tyre may have poor air quality (ie higher moisture) than its companions and under heavy load will built up a lot higher pressure than the others.
Water vapour also causes oxidation with the rim, which can cause leakage through the valve core and an uneven surface for the bead to
seat, and seal.
Water vapour can also lead to the eventual corrosion and or weakening of the steel strands in the tyre.
Many outlets are now providing the Nitrogen alternative – eg Bob Jane and Jax outlets to name just two.
Nitrogen appears the way of the future - the only issue for offroaders who let their tyres down is how to re pressure them remotely if you use Nitogen. Carry a pressureised
tank of Nitrogen as outlined above id one option.
GPM
630204
