xtra wiring to caravan
Submitted: Monday, May 18, 2009 at 22:15
ThreadID: 68962 Views:2765 Replies:4 FollowUps:4
Hi i am placing a thermo 12 v fan into my off road pop top to reduce dust as my 7 pin plug is full i would like to run a wire of car ignition is there a 2 pin plug available or any other suggestions
regards garny esperance
Reply By: Member - Josh (VIC) - Monday, May 18, 2009 at 22:44
Anderson plug is a 2 pin but probably bit heavy just for a fan?
AnswerID: 365595
Reply By: Sand Man (SA) - Tuesday, May 19, 2009 at 07:29
You must already have an earth connection to the Van so you only really need a single pole connector.
The fan is a low current drawing device so just run a single wire from the ignition/accessory circuit to the fan and an earth connection from the fan to am earth (metal) object on the van.
Anderson have the Powerpole connector available in a range of colours, or you could install two if you want a separate earth (return) wire.
Anderson Powerpole
Bill
AnswerID: 365607
Reply By: Member - Rod N (QLD) - Tuesday, May 19, 2009 at 07:39
Do you have a battery in the van? Is it charged from the vehicle? If so just connect the fan to the van 12 volt circuit.
AnswerID: 365613
Follow Up By: Member - JohnR (Vic) - Tuesday, May 19, 2009 at 07:46
That is the appropriate question Rod. Usually you will find that even the simplest poptops have a battery to charge and you won't get sufficient power through a 7 pin trailer cable to charge very much at all.
FollowupID: 633315
Follow Up By: Member - Rod N (QLD) - Tuesday, May 19, 2009 at 08:04
Totally agree John. I use an Anderson plug to charge my van battery and run the fridge when under way. Garny should do the same. It's amazing how many people are told by those that should know better (installers etc) that a trailer plug pin is sufficient to charge batteries and run fridges.
FollowupID: 633318
Follow Up By: garny - Tuesday, May 19, 2009 at 23:38
Thanks for the info guys at the moment the van has a small battery to run the water pump only i will be fitting a larger one to run lights etc and also an anderson plug
I will run the fan of the vehicle accessories so as to control on of when travelling will run through anders plug
The fan will draw from a vent through an air cleaner filter high on the side of our Windsor Rapid
cheers to all
FollowupID: 633458
Reply By: Member No 1- Tuesday, May 19, 2009 at 07:46
most dust enters due to a negative (lower) pressure than the outside of the van.....meaning it is pushed in by the higher pressure.
where are you going to fit the fan so that it will be in CLEAN air and can keep the van at a higher pressure than ambient?
AnswerID: 365617
Follow Up By: Member - Rod N (QLD) - Tuesday, May 19, 2009 at 08:09
There are a number of threads on this subject if you do a search. Pros and cons of fans and scupper vents have been discussed at length. Of course opinions vary as to the effectiveness. If it is a van and the vent is in the roof, it is thought by some that the air is cleaner.
FollowupID: 633319
