Monday, Jun 15, 2009 at 16:10
You're right, olcoolone, the
Oodnadatta Track isn't that rough, and neither is the
Birdsville Track. Both have their share of gibber, stones and the occasional Tek screw, and this is why I have learned to drop pressure to around 25 PSI. I also learned the hard way to drop speed as
well, hence my suggestions.
25 PSI is relatively low for me, since I run 37 to 38 PSI on the bitumen.
I don't know of any theory that says 90 KPH is OK at 25 PSI, and certainly Coopers don't write a special chapter in their guide for light vehicles, except to say don't drop pressures when using HT tyres, only for LT (or words to that effect).
My
Birdsville Track dramas were one Tek screw and two sharp rocks, all before I learned the 25PSI and 70 - 75 KPH combination. Since then, no such problems. And I hvae not had a single puncture on the
Oodnadatta or even across
the desert.
So all my serious tyre damage has been on major tracks, and relatively high speed. One off the major tracks and into the rough, I've had no worries at all.
637464
