Joining Seperate Plotfiles using Oziexplorer
Submitted: Sunday, Jun 21, 2009 at 15:14
Member - John Baas (WA)
Hi all, I've a stack of seperate plotfiles for various trips which, for convenience, I would like to join up into one extended plotfile per trip.
I can't see where to do this using OE help function. Does anyone know if it can be done and if so, how pls?
Cheers.
Reply By: equinox - Sunday, Jun 21, 2009 at 15:25
John,
Click on File, Load from File, Append Track from File.
This will append the selected track to the preloaded file.
371180
Follow Up By: Member - John Baas (WA) - Sunday, Jun 21, 2009 at 16:07
Done, thks.
638476
Reply By: Sand Man (SA) - Sunday, Jun 21, 2009 at 15:48
And then you can save the modified tracks as a separate file if you desire.
You can also select View - Tracks - Track Control and add or delete track points.
All good is OziExplorer.
Bill.
371182
Thks Bill, got it. Cheers.
638477
Reply By: Member - Chris & Debbie (QLD) - Sunday, Jun 21, 2009 at 16:14
Hi John
You could also select multiply tracks as once when using 'Load Track from File (Multi)' by the usual method of selecting multiple fies.
You can then use the 'Join Tracks' command in the Track Contol box.
I prefer this method as you can easily see the different track sections allowing you to join the sections together in the correct order.
Chris
371186
Follow Up By: Member - John Baas (WA) - Sunday, Jun 21, 2009 at 17:46
Thks Chris.
638495
Follow Up By: Bonz (Vic) - Thoughtfully- Monday, Jun 22, 2009 at 21:45
This is great way of doing it I didnt know that, thanx Chris
638669
Follow Up By: Member -Dodger - Monday, Jun 22, 2009 at 22:55
Well I learn't something as
Thanks Chris
638682
