'Format for Printing' - Trek notes etc..
Submitted: Tuesday, Jun 23, 2009 at 14:32
ThreadID: 70084 Views:2484 Replies:3 FollowUps:5
A few moons ago there was a setup option to format Trek notes and others for printing. At the moment- I find that printing Trek notes cuts off a bit of info and sorta looks untidy !!
Any suggestions out there???
Reply By: ExplorOz - David & Michelle - Tuesday, Jun 23, 2009 at 16:06
Yes we know of this issue. It is currently in hand for resolution but don't hold your breath, there's a few complex issues involved at the same time as part of it. Sorry.
MM
AnswerID: 371515
Follow Up By: Honky - Tuesday, Jun 23, 2009 at 16:13
Set your printer for Landscape?
Very appropriate.
Honky
FollowupID: 638747
Follow Up By: Richard Kovac - Tuesday, Jun 23, 2009 at 21:54
MM, why don't you still do the E-books for these types of things?
RK
FollowupID: 638829
Follow Up By: ExplorOz - David & Michelle - Friday, Jun 26, 2009 at 12:12
Basically, old technology - too slow for version control.
MM
FollowupID: 639221
Follow Up By: Richard Kovac - Friday, Jun 26, 2009 at 13:18
It was better than stealing it :-)
FollowupID: 639230
Reply By: Sand Man (SA) - Tuesday, Jun 23, 2009 at 18:23
You can also try cut and paste.
I have had some success doing this and pasting into a black word document.
Bill.
Bill
AnswerID: 371544
Reply By: ExplorOz - David & Michelle - Tuesday, Jun 23, 2009 at 22:02
Ah that should actually work OK if you use the print icon in the tool bar at the top of the page - are you using the printer icon in the task bar? When I tested this after the site update it worked ok - let me know if this is the option you are using or are you just hitting browser print?
David
AnswerID: 371589
Follow Up By: ExplorOz - David & Michelle - Tuesday, Jun 23, 2009 at 22:09
Just tested it and the header is a little weird so I will get onto that tomorrow. I have been writing an export to PDF function which will give a totally new formatted document for our members however time is just getting so hard to find. Treks are being worked on at the moment along with the mapping system so it will get done soon however the basic print function should/must be made to work correctly.
Still let me know if you are using the printer icon because it did not miss any text on the test I just ran.
David
FollowupID: 638833
