LED lighting
Submitted: Monday, Jun 29, 2009 at 10:15
touringoz
Not completly happy with the existing interior lighting in my Van am thinking of replacing some of them with LEDs, anyone else done this and are you satisfied with the results, also where did you purchase your lights from.
thanks
fergy
Reply By: Mandrake - Monday, Jun 29, 2009 at 12:03
I've bought a couple of LED lights from BrightLightAuto -
Interior LED lamps
They are certainly easier on the battery but brightness ??
Mine were not interior lamps .
Interiors may have reflectors to make them a bit brighter ??
Might be worth a look ?
Rgds
Steve
372299
Reply By: Tenpounder (SA) - Monday, Jun 29, 2009 at 12:54
Hi there. Yes, I've been there. My van has the usual 240v/12v overhead lights, plus a couple of 240v reading lights over the beds.
I wanted good 12v lighting with minimal power consumption. I couldn't find a simple globe substitute to replace the standard 12v incandescent globes.
A visit to Jaycar provided me with two 12v multi-LED downlights to fit over the beds, and a couple of 12v flouros, one in the centre of the ceiling and one over the sink area. The power consumption of these is absolutely minimal (I monitor the current closely, I can tell you!).
Hope this helps.
372310
Reply By: SMICK - Monday, Jun 29, 2009 at 16:54
I replaced all my fluros with 12v light fittings with 48 led's from Bias boating; in
Sydney. They are switched or non switched. They only use .3amp, the fluros used .7amp.
372331
Reply By: warfer69 - Monday, Jun 29, 2009 at 19:34
Yep replaced
mine not long ago you'll never look back... JAYCAR
372363
Reply By: ABR - SIDEWINDER - Monday, Jun 29, 2009 at 21:29
Hi Fergy
If you
free camp and use
battery power you will appreciate the power savings you obtain from LED lamps.
Most of our new lamps use less than 0.2A and are as
bright as 20W Halogen. We also have new 18 inch strip lamps that will light up half your caravan.
You should choose carefully and it is always a good idea to buy just one at first to see how good they are before replacing all of them.
Derek from ABR
372390
Reply By: SR5 HILUX - Tuesday, Jun 30, 2009 at 02:09
Reply By: Boobook2 - Tuesday, Jun 30, 2009 at 07:04
Ferg do you know what kind of bulbs you have now. I had G4 bulbs, 20W.
I replaced them with these
http://www.ledshoponline.com/G4_LED_bulb.htm
They are brighter and draw 0.08Amps instead of 1.5A each for the old bulbs and plug straigt in. I got the 6 LED ones but the newer 9 LED look even better.
Lots of other LEDs on that site too. I have found that the bayonett ones, as per tail lights are not as
bright though.
372405
