UHF radio
Hi Guys
Would like to have UHF radio whilst I am on the road. I have looked at Hand Held ...save having to mess with wires and things in the Forester, but when I start looking at 5w ,,,the hand held are getting just as pricy as a fitted one.
Any ideas on setting UHF up in the Forester without to much hassle???
Brian R
Reply By: Member - Tony S (WA) - Sunday, Jul 12, 2009 at 23:40
Hi Brian
Assuming that you have a roo bar.
Mount the aerial, run the wires through the bulk head and attach the aerial plug.
My uhf is mounted on the center consul with industrial velcro tape and plugs into the cigarette lighter plug. When wiring up the male cig. plug you attach the positive wire to the sprung loaded centre contact.
With the velcro you can mount the unit anywhere. Just make sure you clean the area where the velcro goes with metho. Hic!!
Once I worked out where the unit was going it took about 1/2 hour from woe to go.
Tony
The rig
AnswerID: 374259
Reply By: Member - Stephen L (Clare SA) - Monday, Jul 13, 2009 at 00:40
Hi Brian
Check out the new GME TX3340. You will not get a smaller vehicle mounted UHF radio that is Australian made, 3 year warranty and will fit anywhere out of the way
http://www.gme.net.au/products/radio-communications/uhf-477mhz-cb-radios/TX3340
AnswerID: 374261
Follow Up By: Member - A J- Monday, Jul 13, 2009 at 08:29
Brian - recently mounted a GME TX3440 and placed the actual unit under the front seat. The mic has all the controls and information.
Australian made and a previous thread some time ago advised that GME were considered very clear reception
A J
FollowupID: 641525
Follow Up By: Member - Stephen L (Clare SA) - Monday, Jul 13, 2009 at 08:51
Hi AJ
I also have a TX 3440, and they are a great unit. I have had mine now for just on two years and have the main head unit mounted under the front dash. The new TX3340 is even smaller again, still with all the controls on the microphone, but the head unit not much bigger than the microphone. With a head unit that size, it could be mounted just about anywhere out of the way.
FollowupID: 641526
Reply By: warfer69 - Monday, Jul 13, 2009 at 01:12
Hiya Brian
Get yourself an external aerial RFI 6.5db is a happy medium meaning hilly and flat areas,buy either Icom 41s (i use x2) or Gme Handheld if thats what you really want and when ordering get bnc connector,BNC just screws on where the original aerial goes then you snap on the external wire to it,Connect the power to ciggy lighter and thats it,i also use a mike for incar.The range once connected to external is the same as incar unit provided you get a 5w one.
Take out,Take off BNC Connecter and screw on aerial supplied with handhand..Simple as that
If you want more info just send me your email.
AnswerID: 374264
Reply By: Member - Paul F (QLD) - Monday, Jul 13, 2009 at 08:33
Hi Bryan R,
It just so happens that I have a relatively new GME TX3200 sitting here gathering dust with all new installation wiring and a new 6db aerial that mounts easily to the hood gutter. If you're interested send me a contact number or e-mail.
Paul
AnswerID: 374278
Reply By: tim_c - Monday, Jul 13, 2009 at 11:51
Brian,
It depends what you're going to use the unit for, and how often...
If you're just using it for convoys or talking to truckies while they overtake you, you wouldn't really need 5w and for occasional use, a lower powered handheld unit would be fine. If you're looking at longer range communications (ie. where you can't physically see the other party) you'd need 5w (the maximum allowable without a licence) and preferably an external antenna. If you're looking at something that you will use a lot, get the fitted one which is powered off the car. If you'd ever like to use it out of the car then obviously you'll need a handheld unit.
If you get one fitted, you might still consider a lower powered handheld unit - there are a number of situations where this can save your voice: eg. backing the A-Van into a tight spot, a person can get out to guide the driver and can easily communicate without yelling their lungs out! If you've ever said "I didn't hear you say STOP!" then the set up could pay for itself in one campsite! :)
I bought a high powered handheld unit but the battery always went flat on longer trips - I ended up fitting a unit that ran off the car battery. I still carry a low-powered handheld but it takes AA batteries so I can carry a spare set.
Hope this helps, Tim.
AnswerID: 374317
Reply By: Member - Brian R (WA) - Monday, Jul 13, 2009 at 17:31
OK
Thanks guys I will take another look over the Forester to se were I can set up
Brian R
I will be in touch with you Paul
AnswerID: 374363
Follow Up By: Member - Graham H (QLD) - Monday, Jul 13, 2009 at 18:26
There are also Unidens with remote heads which are the width and height of the front of the radio but only about 20mm thick.
Rest of radio under seat.
Its very handy to be able to hear trucks beyond line of sight.
Especially the two that came around a corner a couple of days ago.
Each one had a 250tonne Haulpak on a low loader and took up the whole road.
Had I not heard them and saw the pilot I would have been in big trouble where we were.
Look in my profile for how its mounted in a 100ser Croozer
Nice and neat and hardly noticeable amongst all the other junk.
Mike is on a home made bracket that clips under the edge of console and is secured by the screw that the two halves are connected by.
FollowupID: 641592
