Friday, Jul 24, 2009 at 19:05
Ps.
Specs are:
42 cylinders heptagonal-star/6 cylinder rows
Diameter 160 mm, stroke 170 mm, capacity: 143.500 ccm (8.757 cui)
7 over head camshafts driven by shafts, central steer time adjustment
4 valves/cylinder, 168 valves operated by roller rocker arms one cam moves an exhaust valve and an inlet valve
Rotational speed: up to a maximum of 2500 rpm
Torque: about 15000 Nm (approx 11063 ft/lb)
Power: about 4500 kW (approx 6034 hp)
Fuel consumption: 205 g/kWh resp. About 800 litres diesel/h
Direct injection 9-hole injectors
Decentralized
fuel injection pump, per cylinder p ~ 1.000 bar
Turbo compound: 1 step axial turbine and 1 step radial blower (p ~ 2,1 bar)
Joined with crankshaft via 3 parallel hydrodynamic couplings
Compressed air start system is at work with 150 bar compressed air on 2 cylinder banks (12 cylinders)
Dimensions: diameter 1.600 mm, length ~ 2.000 mm"
Mark
643421
