road van to innaminka
Submitted: Thursday, Jul 23, 2009 at 22:17
ThreadID: 70930 Views:2911 Replies:5 FollowUps:8
I know its been done before but im asking again, my parents have a jayco tandem road van and am thinking of going to Innamincka via white cliffs.
Anyone gone this way and would it be ok?
If not then what about via Lynhurst.
Shane.
Reply By: mjs_117 - Thursday, Jul 23, 2009 at 22:35
The track from Lyndhurst to Innaminka is A1. Take it easy and I'd say you'd be right.
AnswerID: 375921
Reply By: D200Dug- Thursday, Jul 23, 2009 at 22:37
If it's your parents van not yours
WHO CARES ???? !!!! :-)
Sorry
AnswerID: 375923
Follow Up By: Member - shane (SA) - Thursday, Jul 23, 2009 at 22:43
If you go through life with that attitude I don't think you will get far, I try to treat any item like its mine.
ITS ALL ABOUT RESPECT.
Shane.
FollowupID: 643269
Follow Up By: Member - shane (SA) - Thursday, Jul 23, 2009 at 22:44
Shane.
FollowupID: 643271
Follow Up By: D200Dug- Thursday, Jul 23, 2009 at 22:49
I got this far and I am still going :-)
If people cannot take a joke then that is their problem !
PS If I borrowed something I would never treat it like it was my own.
I would take care of it instead.
FollowupID: 643273
Follow Up By: Geoff (Newcastle, NSW) - Thursday, Jul 23, 2009 at 22:50
Dug,
Don't set the drag too tight, now you've hooked one you don't want to get broken off!
Geoff
Geoff,
FollowupID: 643274
Follow Up By: D200Dug- Thursday, Jul 23, 2009 at 22:56
Skull drag them to be beach I say !!!
Anything under 100lb line is for sissies :-)
FollowupID: 643276
Follow Up By: Geoff (Newcastle, NSW) - Thursday, Jul 23, 2009 at 23:02
I remember fishing for tiger sharks at the mouth of the Pennefather River about 25 years ago using a Toyota PTO winch to land them!
Does that qualify?
Geoff
Geoff,
FollowupID: 643280
Follow Up By: D200Dug- Thursday, Jul 23, 2009 at 23:06
Bingo we have a winner !
Who did you get to swim out with the bait ?
I think we should stop the hijack soon :-)
FollowupID: 643281
Reply By: Africampers - Thursday, Jul 23, 2009 at 23:42
Hi Shane,
I recently completed the trip towing my off-road caravan the other way round - via Arkaroola, Moolawatana up to Innamincka the back via Cameron Corner/ Tibooburra to White Cliffs. The worst part was the corrugations on the section just before White Cliffs - the remainder is easy going if you take it slow. My caravan is a compact off-roader - Conqueror Commander - but if you take it easy and tie everything down inside the caravan I don't believe there would be problems.
The road from Tibooburra to Strzelecki is well worth suffering the few bumps to get there. Just keep the speed down, let the tyres down a tad and take an extra spare for the caravan as well if possible, but not essential.
Regards,
Africampers
AnswerID: 375928
Reply By: Sand Man (SA) - Friday, Jul 24, 2009 at 07:34
Shane,
The road to Innamincka via Lyndhurst (Strzelecki Track) is generally a first class track, with a crushed rubble base at the northern end and also in the process of having a major upgrade being done along its route.
Having said that I would still not take an on road van along the track.
The main problem with an on road van is that the internal cupboards and fittings are not designed to take constant shaking and vibration which is common on off-road tracks. They can be shaken to pieces and I have heard of it happening although I don't own a van myself.
Secondly, your folks would want to have a very good stone guard mounted on the van's draw bar, an "impact" bra fitted to the front surface of the van and a rear window protector on the back of the towing vehicle.
Off road vans are specifically designed to take the type of treatment that will occur when travelling on unsealed surfaces and the suspension is also important to limit the possibility of premature failure and give higher ground clearance.
Bill.
Bill
AnswerID: 375944
Reply By: Member - shane (SA) - Friday, Jul 24, 2009 at 19:55
thanks for replies.
shane.
AnswerID: 376039
Follow Up By: Kim and Damn Dog - Friday, Jul 24, 2009 at 20:59
Shane
We’ve just got back from there. There has been a lot of water dumped on the Paroo North of White Cliffs; most of it would have dried out by now. The lower section is Gibba and rock, but as you head further north in the vicinity of Klondyke Station the road turns to sand, which is an easy travel up to Wanaaring.
Your folks will need to take it pretty easy with a caravan on the lower section, but it can be done with a bit of common sense. They’ll probably finish up with a bit of damage to the van if they don’t take it real slow.
It’s an interesting post in that you’re going through White Cliffs and then Innamincka. Drop me a post and I can take you through some of the other areas.
Kim
FollowupID: 643448
