Broken CT wiring to 4x4
Submitted: Friday, Jul 24, 2009 at 19:21
Lachie
hi
On a recent trip we stopped for lunch and on the customary check of the prado and KK I found out that the anderson plug and 7 point plug had pulled out of the prado and lay bare on the road. ie no ends
Up to this point we had only been driving on the bitumen. I had double checked the electrical fittings before we left.
This was only my second trip with the KK
The KK has a thick hose with the wiring coming out of it. This is very stiff.
Is it better to have no hose as the outer casing and therefore it would be more flexible ?
Are flat pins better than round pins ?
The electrical fittings on my tractor to the spay unit are a lot better. You push the plugs in and then you slide over a plastic nut that screws the two plugs together.
Has anyone seen connectors like these for trailers ?
Reply By: Sand Man (SA) - Friday, Jul 24, 2009 at 20:05
Lachie.
A very strange occurrence you are describing.
The Anderson connector is retained in its mate by the spring tension of the conductor and the 7 pin plug is locked in by the lid of the socket.
In my opinion, there is no way that either would vibrate loose, especially at the same time. Even if the cable was somehow caught up in something and pulled, the chances are that the cable would pull out of the plug, leaving it still locked into the socket, at least for the round seven pin connection.
Now, I once discovered the trailer cable laying on the road when I stopped and the plug had disappeared, having been worn away by abrasion. I had obviously forgotten to connect it on this occasion.
I now carry a spare plug, "just in case" I stuff up again.
Are you doubly sure you double checked the connection before you left???
The seven pin flat plug and socket is secured in a similar way to the round plug/socket so changing this will not improve things at all.
As far as the Anderson connectors are concerned, there is no better anti-vibration solution around.
You could perhaps change over to an industrial cannon plug/socket which has a screw type retaining ring, but this is not a cost effective solution if the connection is either ripped out after being caught on something, or not connected in the first place.
The cost of a plastic 7 pin plug, either flat or round, is around the $10 mark and generally is the best, most cost effective solution. Simply carry a spare plug and retain the backing off the package that shows what coloured wire is connected to the appropriate numbered pin.
Bill.
376044
Follow Up By: Lachie - Friday, Jul 24, 2009 at 20:26
Thanks for the Sand man.
I too thought it was very strange.
As the second hand KK being was fairly new to me I checked all the trailer lights before departure and also put a voltmetre on the wires to the trailer batteries to see if the current was flowing .
Lachie
643440
Follow Up By: Dave(NSW) - Friday, Jul 24, 2009 at 21:10
Electrical plugs fall out all the time on trucks , very sharp corners or jack knifing the trailer or some times just vibration, Use cable ties and they will never come undone.
643449
Reply By: Maîneÿ . . .- Friday, Jul 24, 2009 at 20:21
You say: "Up to this point we had only been driving on the bitumen. I had double checked the electrical fittings before we left"
have you concidered that some rsole may have unplugged the two connections ??
Maîneÿ . . .
376050
Follow Up By: blue one - Friday, Jul 24, 2009 at 20:38
Ah Mangy,
The paranoia kicks in.
643443
Follow Up By: Member - Graham H (QLD) - Friday, Jul 24, 2009 at 22:27
Ah yes was advised when travelling up through the centre to check connections if rig left parked and connected up in
places like Alice
Tennant Creek, definitely
Halls Creek.
I put a locked pin in towbar as they have been known to pull the straight ones out completely.
SO !!!!!!!! maybe
643467
Follow Up By: ABR - SIDEWINDER - Saturday, Jul 25, 2009 at 23:26
considered ? (spell check)
643611
Reply By: Member - Mark (Tamworth NSW) - Friday, Jul 24, 2009 at 22:29
Just back today from 7000km with our 2003 KK in Central Aust. We purchased it last year.
On the
Oodnadatta - Dalhousie very ordinary gravel road I found my Anderson plug missing and wires from CT Battrery dangling on the ground anfd I had to cut the wires back 200mm due to shorting.
Mine too has the thick blue pressure hose shroud.
I suspected
mine was stone damage, but it may have been due to the Anderson cable being a bit shorter than ideal.
My main trailer wiring was far too short and I fitted 300mm of extra unprotected cable, between the KK supplied fitting and the vehicle, no problems. Prior to that on tighter cornering or reversing I found the main wiring connection would come out.
Looking at the stone damage to my CT A Frame before the stone guard, the shroud protection is a very good idea, but perhaps you may want to spend a little money making a short flexible bridge.
The mechanic at Uluru joined some new wires and encased them for a short section in a flexible plastic spiral wound shroud at the joint, with the heavy air/hyrdaulic hose either side end of it.
Suppose it depends where you are going to use your CT, on bitumen and sand or on gravel roads?
376070
Reply By: ABR - SIDEWINDER - Saturday, Jul 25, 2009 at 09:50
Hi Lachie
On my last trip to
Birdsville I had a plug do the same but it was the original plastic round 7 pin plug supplied with the caravan.
It was changed over to a metal plug at a great roadside "workshop" and has not come loose again.
Derek from ABR
376111
Reply By: Lex M (Brisbane) - Saturday, Jul 25, 2009 at 11:14
Might I suggest a light shockcord attached to the cable so that if the plug pulls out it holds the cable up off the ground.
The trick is to use a long light cord tied up high so it puts little pressure on the connection but enough to lift the unplugged cable and keep it off the ground.
376122
Reply By: Lachie - Saturday, Jul 25, 2009 at 15:52
Thank you all for your replies .
You can not beat good feed back from people who have been out in the field.
Lachie
376167
