deep cycle battery
Deep cycle batteries have been done to death I know.
Now my question from them that know.
I have always run wet cell deep cycle batteries, but again I am up for a new one.
My fault, it went down to 3 volts while i was away and i did not realize it was running anything.
So i am just wondering what advantage there is if any apart from being sealed and no fumes that an AGM battery of the same amps would have over a wet cell?
Do they last longer as far as discharge is concerned?
cheers Shane.
Reply By: Member - Roachie (SA) - Sunday, Jul 26, 2009 at 18:42
Shane,
They don't last longer (given that they have the same capacity). IE: a 100a/h wet cell deep cycle battery should last as long as a 100a/h AGM if it is being asked to run the same load.
Where the AGM will excell is in the charge rate it will accept and (if treated well) should last a considerably lot longer in terms of the number of cycles it will take. Typically, where a wet cell deep cycle battery might be expected to last for , say, 4 years..... a quality AGM used in the same manner, should last you around 10 years.
Well, that's what I'm banking on anyway.
I do tend to mollicoddle my batteries though. At the moment, sitting here at home, both my 4x4 and my camper trailer are sitting out in the shed/carport. They each have a Durst 15amp 3 stage battery charger hooked up to them to keep the batteries in top condition.
Roachie
AnswerID: 376308
Follow Up By: Member - shane (SA) - Sunday, Jul 26, 2009 at 19:04
Thanks for your reply Roachie,
I have the van batteries on a float charge all the time. this is done by a 3 stage charger as yours are. The one that stuffed up was the one in the patrol as my second battery.
when i priced them today the guy told me that the AGM 100 amp was only $90.00 dollars more and it would be a better buy.
Hence the question, but then i would either have an AGM as a second battery in the patrol. Or an AGM and wet cell in the van in parallel.
cheers shane.
FollowupID: 643684
Follow Up By: Sand Man (SA) - Monday, Jul 27, 2009 at 07:28
Another advantage of an AGM battery is that they don't lose their charge when not in use.
Having charged the AGM to its full capacicty, it will hold that charge for months on end. (unless something is slowly draining it of course)
For a comparison, Whitworths Marine have a 100Ah Remco AGM for $339.
Bill.
Bill
FollowupID: 643738
Reply By: viz - Sunday, Jul 26, 2009 at 19:13
Caution - you get what you pay for. The cheap AGM batteries will not last under the bonnet, or so I am told when I bought one for my Cruiser. If you are after long life, it would pay to get one that is "ruggedised" for 4WDs
viz
AnswerID: 376310
Follow Up By: Member - shane (SA) - Sunday, Jul 26, 2009 at 19:19
Viz the battery i have been quoted on is $300.00, I would not have thought that was a cheep battery but looks like i am wrong. what would one expect to pay for a AGM battery? As i might have to mortgage the wife.
shane.
FollowupID: 643690
Follow Up By: viz - Sunday, Jul 26, 2009 at 21:33
Oops I posted my reply in the wrong place - check the next post
viz
FollowupID: 643716
Reply By: viz - Sunday, Jul 26, 2009 at 21:32
Without going downstairs in the cold and rain and dragging the Bruiser out and looking under the bonnet... ;) And the Missus glared at me when I asked her for the receipt...
I'm in trouble mate... :(
$525 for mine from Battery World - it is a Deka 92 Amp/hr. To make matters slightly worse, while the AGM battery seems to be very much the flavour of the month (I can attest to their performance) they do like being massaged gently with a stage charger while resting in the garage . This (so they tell me) will very much increase the life of the battery.
There is a guy on this forum who has a business in vehicle electrics (Sidewinder is the company name) who might also be able to give some advice.
viz
AnswerID: 376336
Follow Up By: viz - Sunday, Jul 26, 2009 at 21:34
ABR - Sidewinder
http://www.exploroz.com/Customers/ABR_-_SIDEWINDER.aspx
FollowupID: 643717
Reply By: Maîneÿ . . .- Sunday, Jul 26, 2009 at 23:56
shane
You say;
"My fault, it went down to 3 volts while i was away and i did not realize it was running anything"
Any type of battery will die given the these conditions, use a battery cut-off device this time, set at about 11.6v if possible.
You obviously know by now you need to maintain your battery in a fully charged condition, how you do this is dependant on how it's fitted and what use it gets.
Maîneÿ . . .
AnswerID: 376356
Reply By:- Monday, Jul 27, 2009 at 01:09
Shane,
from top of my head, AGMs have the following advantages over liquid lead acid batteries:
the plates inside the AGM cannot deform/crack in extreme sub zero temps, as there is only very little water.
The AGM design recombines oxygen/hydrogen inside the glass matting back into water thus preventing water loss (under normal charging conditions).
They can be operated in any position except upside down as this might interfere with the safety valves in case of overcharging.
The glass matting is tightly packed between the plates and cushiones them which makes the design inherently more shock/vibration proof.
AGMs do not suffer from an effect which pertains to stationary liquid lead acid ones: stratification of the acid.
The self discharge rate of an AGM is considerably lower compared to liquid lead acid - the main reason for sulfation when kept in storage for extended periods of time.
And this last one is for you:
If accidentally left to totally discharge, the active material on the plates is held in position by the glass matting (a liquid lead acid battery sheds the material which sinks to the bottom of the battery and cannot be reformed onto the plates through recharging).
As to your question which battery type lasts longer? For under the bonnet and other 'hot' places: liquid. For all other mobile applications, AGM.
@viz,
.........The cheap AGM batteries will not last under the bonnet......
Neither will the 'expensive' ones as the laws of nature apply just as much - as a quick search/read on 'Arrhenius equation' would reveal.
Since we're looking at a series string of 6 cells we cannot control every individual cell separately when recharging. This necessitates a slight over/equalisation charge at every charge cycle to make sure the weakest cell gets fully charged, while other ones are already 'full'. The chemistry inside an AGM is optimised for 25 degC. At this temperature the recharge characteristics of all cells in the string are at their closest match possible. If charging takes place outside this temperature band, there will be an increasing mismatch between some cells in their ability to absorb charge (and recombine all gasses back into water) meaning the battery will deteriorate more than necessary with every cycle.
And this is precisely where the liquid lead acid battery shines: it can take an overcharge especially at elevated temperatures, because it is 'allowed' to gas at atmospheric pressure. The resulting loss of water is easily taken care of by the operator at the next service check.
As to the price of AGM batteries, anything above $250 or so for 12V100Ah, I consider a total waste of money ;)
Check out ebay.
Hope this was of some help.
Best regards, mr.batteryvalue
AnswerID: 376361
Follow Up By: Maîneÿ . . .- Monday, Jul 27, 2009 at 08:32
You've 'no name' and what appears to be part of an email addy - 'mr.batteryvalue' - is it?
You say;
"As to the price of AGM batteries, *anything above $250* or so for 12V 100Ah, I consider a total waste of money"
So why not nominate what AGM battery the poster can buy for *under the $250* cap you mention, that has Australia wide warranties too, so he can make an informed decision, or better still, you please nominate the brand, model number etc for him, just so there's no confusion
I'm sure we all want to buy *quality 100 AH AGM's* for under $250 :-)
Maîneÿ . . .
FollowupID: 643753
Follow Up By: Bonz (Vic) - Thoughtfully- Monday, Jul 27, 2009 at 16:41
geez Mainey Calm down mate.
I think this info is quite useful, don't be fussed about the batteryvalue thing, it doesn't look like an ad to me, looks more like useful information.
What person in their right mind running a business would point someone to ebay? I searched and there's no user in there called mr.batteryvalue or battery* so that may scotch the conspiracy theory.
Just take a Bex and lie down mate
FollowupID: 643837
Follow Up By: Maîneÿ . . .- Monday, Jul 27, 2009 at 16:47
Bonz,
yes it very well could be usefull information, that's why I've asked:
""So why not nominate what AGM battery the poster can buy for *under the $250* cap you mention, that has Australia wide warranties too, so he can make an informed decision, or better still, you please nominate the brand, model number etc for him, just so there's no confusion
I'm sure we all want to buy *quality 100 AH AGM's* for under $250 :-) ""
The bex won't blend well with the Bourbon
Maîneÿ . . .
FollowupID: 643841
Follow Up By: Bonz (Vic) - Thoughtfully- Monday, Jul 27, 2009 at 16:49
Then dont drink the bourbon
FollowupID: 643842
Follow Up By: Maîneÿ . . .- Monday, Jul 27, 2009 at 16:57
I have to, I don't like to mix my drinks, and to wash the Bex down with water would defeat the purpose of the previous Bourbons :)
Maîneÿ . . .
FollowupID: 643844
Follow Up By: Bonz (Vic) - Thoughtfully- Monday, Jul 27, 2009 at 17:01
The Bex goes under your eyelids. Not down your drinking tube Mainey
FollowupID: 643845
Follow Up By: Maîneÿ . . .- Monday, Jul 27, 2009 at 17:04
sorry, I can't reply in a way that would not raise a few eyebrows
Maîneÿ . . .
FollowupID: 643846
Reply By: Member - Kiwi Kia - Monday, Jul 27, 2009 at 07:27
Personally, I believe that you are going to be better off buying a middle of the range ($) 'name' brand battery with a good warranty. I had an almost brand new battery give me problems and when I contacted the importer I was told to bring it to Dubbo (I was in Alice Springs) and it would be replaced for free. I now get my batteries from K-Mart as they have outlets all around Australia and they are not over priced. Batteries are consumables and have a limited life so I plan on useing them for 4 or 5 years and then expect to replace them.
KK
AnswerID: 376364
Follow Up By:- Monday, Jul 27, 2009 at 09:06
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule .
Forum Moderation Team
FollowupID: 643756
Follow Up By: Maîneÿ . . .- Monday, Jul 27, 2009 at 09:46
I don't sell on ebay
my AGM's carry the manufacturers 3 year warranty :-)
Maîneÿ . . .
FollowupID: 643768
Reply By: Drew Peacock (W.A) - Monday, Jul 27, 2009 at 09:20
Why not just say I sell batterys CHEAP on Ebay and mine are the best.
Why are your batterys so good?
If I have a problem in Darwin can I get it replace then and there?
Are they a proven product?
Cheers Drew
I don't sell batterys
AnswerID: 376377
Follow Up By:- Monday, Jul 27, 2009 at 11:18
What I'm selling is not cheap, it's value for money.
When trying to go into detail about this in a previous post the moderation of this forum wouldn't let me post it.
Suffice to say, if you mistreat your battery in Darwin (like by pouring petrol over it and throwing a match at it) and it consequently spits the dummy on you, make sure to take a spare battery with you - or wait for the replacement coming in from Brissie.
And yes, I do sell a good product, and take extraordinary precautions ensuring your new battery won't let you down in Darwin that easily.
FollowupID: 643780
Follow Up By: Drew Peacock (W.A) - Monday, Jul 27, 2009 at 11:58
Why would I pour petrol over a battery and set it on fire?
So I take it that there is no other place I can take the battery to if it fails except send it back to you and wait a week for it to be returned.
1) Why are you batterys so good?
2) Are they a proven product?
FollowupID: 643786
Follow Up By: Maîneÿ . . .- Monday, Jul 27, 2009 at 16:31
Mr. Batteryvalue
Can you give just one (1) valid reason why you are NOT a "Business Member" on EO ?
Go legitimate, make money, make friends and reap the many benefits available here :)
Maîneÿ . . .
FollowupID: 643835
Follow Up By: Geoff (Newcastle, NSW) - Monday, Jul 27, 2009 at 18:02
Oh Mainey, the irony, the irony of that question!
Please duck into the bathroom and ask it of the mirror!
Geoff
Geoff,
FollowupID: 643855
Reply By: Member - shane (SA) - Monday, Jul 27, 2009 at 21:00
Thankyou for all replies, even though some were over my head.
So i have got out of this-
AGM's are no good under the bonnet
AGM's are more forgiving than lead acid.
Buy a battery with a nation warranty.
don't take bex with bourbon.
cheers. shane.
AnswerID: 376487
Follow Up By: oldtrack123 - Monday, Jul 27, 2009 at 21:19
Hi Shane
just one other thing to add to your list.
Like many things in this world ALL AGMS are not true deep cycle, just starting batterys.
So make sure what you are getting
FollowupID: 643888
Follow Up By: oldtrack123 - Monday, Jul 27, 2009 at 21:27
Shane
Previous post wording may be confusing, change "ALL" to "SOME"
AGMs more forgiving?? depends on what you mean , they do not like being overcharged. Same reason as under bonnet they dry out.
FollowupID: 643893
Follow Up By: Maîneÿ . . .- Monday, Jul 27, 2009 at 21:32
Shane,
add to that:
AGM Deep Cycle batteries are more *efficient* than conventional wetcell DC's of same AH capacity.
If you buy a good quality AGM DC battery you won't need to worry about a warranty claim, unless you stuff the battery yourself, after-all a 12v battery is just a 'plastic box' that contains some 'chemicals' and some 'lead' plates or lead composite material that creates a chemical reaction creating the Voltage.
In the lesser priced DC's they use lesser quality ascid and will probably weigh less, because they contain less lead = less performance characteristics, if it's 100 ah and under 30 KG it's a cheapie
Maîneÿ . . .
FollowupID: 643894
Follow Up By: viz - Monday, Jul 27, 2009 at 22:03
Wow - quite entertaining all these posts!
The AGM that I have under the bonnet is a marine deep cycle type (so it says on the side) and will start AND do deep cycle duties.
So far my observations are:
1. It is a very heavy battery for its size - heavier than I expected. Does that equal more lead??
2. It runs a eutectic fridge which is supposed to use about 20 amps/day and an inverter to run a laptop - on a stay in a campsite when the voltage was measured at the end of day one it was around 12.45 volts (from memory). I thought that was quite good for a 24 hour period of use and no charge.
3. The Bruiser was in the shop for a week getting fitted out and the start battery got flattened. Jumped by the AGM (aux) battery. Did not even blink.
It may well be that I paid too much for this battery compared to other prices - however I have had ELFs (Early Life Failures) in batteries before - and what I do not need is a failure in the worst possible place - the Simpson or similar, where I am going shortly...
viz
FollowupID: 643898
Reply By: Gronk - Tuesday, Jul 28, 2009 at 20:18
If I was going to put an aux battery in a 4x4 it would be a deep cycle wet cell (unless it was in the rear somewhere )
In a CT??....AGM....( especially if inside the CT ..or van.. ) Why ??......no maintenance.....
If it's like my CT....( charger is also inside the CT )....come home...plug in an extension lead... and 1 ( or 2 ) days later unplug it .....no checking....no watering...nothing......
AnswerID: 376598
Reply By: Member - shane (SA) - Tuesday, Jul 28, 2009 at 21:11
thanks all.
cheers Shane.
AnswerID: 376605
