Low and High Beam Globes
Submitted: Thursday, Aug 20, 2009 at 19:19
ThreadID: 71648 Views:4523 Replies:5 FollowUps:2
What is the best brand of globes (hight and Low beam) that gives the brightest light, that I can put in a Landcruiser 100 series without having to change the standard factory wiring.
Reply By: Sand Man (SA) - Thursday, Aug 20, 2009 at 19:32
My research and applied experience has determined that Philips VisionPlus globes are very good.
For full technical details have a read of Daniel Stern Lighting
Bill.
Bill
AnswerID: 379727
Follow Up By: Sir Kev & Darkie - Thursday, Aug 20, 2009 at 19:40
I'll second that, I have used IPF globes as well and have found them to be overpriced for the quality of globe when compared to the Phillips ones.
Cheers Kev
Russell Coight:
FollowupID: 647120
Follow Up By: TerraFirma - Thursday, Aug 20, 2009 at 20:24
I'll 3rd that, I have the Phillips Vision Plus in a Landcruiser 100 series, made a big difference IMO.
FollowupID: 647128
Reply By: Members Paul and Melissa (VIC) - Thursday, Aug 20, 2009 at 20:05
German made Philips + whatever you like (30,50 and 80's) as i have the 80's in my 100 series and made a huge difference even though i thought the OEM's were pretty damn good too.they are standard wattages but have improved glass and reflectors in the globe. i also have used Tungsram in the past and had a good run with them also. apart from these i wouldnt use anything else.
AnswerID: 379733
Reply By: Member - Andrew L (QLD) - Thursday, Aug 20, 2009 at 21:42
Another vote for the Phillips in my 105 series.
AnswerID: 379757
Reply By: xxx - Thursday, Aug 20, 2009 at 22:55
I just bought a Xenon HID kit for $20 plus postage here.
It took about ten minutes to install each side. The old H1 low beam lights in the LX470 were pretty dim. The new 5000K HIDs are unbelievable, and are only 35W as opposed to 55W for the originals.
The cost is comparable to fitting the Phillips globes.
I am not sure what headlights the 100 series has- if it has H4 hi/lo beam globes the kit is $49.
AnswerID: 379777
Reply By: DIO - Friday, Aug 21, 2009 at 10:41
Phillips Crystal Vision
AnswerID: 379831
