uniden uh065sx question
Submitted: Friday, Aug 21, 2009 at 18:49
zacc
hi all i have a pair of uniden uh065sx, the question ihave is one of the units has a constant busy signal display . will still transmit and recieve just has the bussy signal displayed . also has a his noise while standing still . tried adjusting squelch but to no avail . any answers ? cheers
Reply By: Michael ( Moss Vale NSW) - Friday, Aug 21, 2009 at 19:02
Does that model have an adjustable squelch knob?? Some of the uniden have a set squelch that is part of the transmit button, you hold it for 3 secs and it either locks or unlocks the squelch... its at the bottom of the transmit button... Michael
379907
Follow Up By: Michael ( Moss Vale NSW) - Friday, Aug 21, 2009 at 19:03
opps!! you have that under control... sorry Michael
647246
Reply By: Chunkz - Tuesday, Aug 25, 2009 at 13:55
Hi Zacc..
Are you using these radios in any 'extreme' conditions?
I had a similar problem a few weeks ago at the snow... we had 4 of these UH065s in use (plus two heavy duty Vertexs...)
Three of the unidens sat inside ski jackets where it was warm and another sat in the outer pocket. All had speaker/mics attached.
After about 4 hours, the one that was sitting in the "outside pocket" was constantly "busy" and other transmissions werent being received unless the signal strength was very strong.... The transmit button was still working and everyone else could receive those... The settings on all four were the same, but the other 3 seemed to work fine...
Once we got it back into the apartment where it was warm, it seemed to function normally again without having to adjust anything.
It behaved exactly the same the next day, so the only thing I was able to put it down to was the exposure to the cold temperatures... so it could possibly be an environmental thing.....
380425
